my following code is not showing any output to the serial monitor. My arrangement is accurate. I am using rfid rc522 module ,
#include <SPI.h>
#include <MFRC522.h>
constexpr uint8_t RST_PIN = D3; // Configurable, see typical pin layout above
constexpr uint8_t SS_PIN = D4; // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
/* Set the block to which we want to write data */
/* Be aware of Sector Trailer Blocks */
int blockNum = 2;
/* Create an array of 16 Bytes and fill it with data */
/* This is the actual data which is going to be written into the card */
byte blockData [16] = {"Himanshu_Sharma"};
/* Create another array to read data from Block */
/* Legthn of buffer should be 2 Bytes more than the size of Block (16 Bytes) */
byte bufferLen = 18;
byte readBlockData[18];
MFRC522::StatusCode status;
/* Initialize serial communications with the PC */
/* Initialize SPI bus */
SPI.begin();
/* Initialize MFRC522 Module */
mfrc522.PCD_Init();
Serial.println("Scan a MIFARE 1K Tag to write data...");
/* Prepare the ksy for authentication */
/* All keys are set to FFFFFFFFFFFFh at chip delivery from the factory */
for (byte i = 0; i < 6; i++)
key.keyByte[i] = 0xFF;
/* Look for new cards */
/* Reset the loop if no new card is present on RC522 Reader */
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
/* Select one of the cards */
if ( ! mfrc522.PICC_ReadCardSerial())
return;
Serial.print("\n");
Serial.println("**Card Detected**");
/* Print UID of the Card */
Serial.print(F("Card UID:"));
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
Serial.print("\n");
/* Print type of card (for example, MIFARE 1K) */
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
Serial.println(mfrc522.PICC_GetTypeName(piccType));
/* Call 'WriteDataToBlock' function, which will write data to the block */
Serial.print("\n");
Serial.println("Writing to Data Block...");
WriteDataToBlock(blockNum, blockData);
/* Read data from the same block */
Serial.print("\n");
Serial.println("Reading from Data Block...");
ReadDataFromBlock(blockNum, readBlockData);
/* If you want to print the full memory dump, uncomment the next line */
//mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
/* Print the data read from block */
Serial.print("\n");
Serial.print("Data in Block:");
Serial.print(blockNum);
Serial.print(" --> ");
for (int j=0 ; j<16 ; j++)
Serial.write(readBlockData[j]);
Serial.print("\n");
void WriteDataToBlock(int blockNum, byte blockData[])
/* Authenticating the desired data block for write access using Key A */
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, blockNum, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK)
Serial.print("Authentication failed for Write: ");
Serial.println(mfrc522.GetStatusCodeName(status));
return;
Serial.println("Authentication success");
/* Write data to the block */
status = mfrc522.MIFARE_Write(blockNum, blockData, 16);
Serial.print("Writing to Block failed: ");
return;
Serial.println("Data was written into Block successfully");
void ReadDataFromBlock(int blockNum, byte readBlockData[])
/* Authenticating the desired data block for Read access using Key A */
Serial.print("Authentication failed for Read: ");
return;
/* Reading data from the Block */
status = mfrc522.MIFARE_Read(blockNum, readBlockData, &bufferLen);
Serial.print("Reading failed: ");
return;
Serial.println("Block was read successfully");
I tested your code using an Arduino UNO.
I changed the SS and RST pins to UNO pins.
I blocked the recording function so it doesn't record anything on my tag.
It worked and printed:
**Card Detected**
Card UID: XX XX XX XX I deleted my tag number from here
PICC type: MIFARE 1KB
Data in Block:2 -->
Now I tested it with the ESP8266 and it worked, but I kept the recording functions blocked so as not to record on my tag.
Below is the printout and the code I used with the recording function blocked.
(line 96).
PS: Check if your serial monitor is correctly configured at 9600 BPS.
Printout:
8Y⸮a⸮⸮e⸮H⸮S⸮⸮⸮Scan a MIFARE 1K Tag to write data...
**Card Detected**
Data in Block:2 -->
Your code slightly organized.....
#include <SPI.h>
int blockNum = 2;
SPI.begin();
mfrc522.PCD_Init();
for (byte i = 0; i < 6; i++) {
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
Serial.print("\n");
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print("\n");
Serial.print("\n");
Serial.print("\n");
Serial.print("\n");
for (int j = 0 ; j < 16 ; j++)
Serial.print("\n");
if (status != MFRC522::STATUS_OK) {
return;
else {
//status = mfrc522.MIFARE_Write(blockNum, blockData, 16);
return;
else {
void ReadDataFromBlock(int blockNum, byte readBlockData[]){
return;
else {
return;
else {
