ESP8266 and RC522 not working
I am using rc522 for the first time with esp8266 I used some codes to read a rfid card but it doesn't work when I try it with an arduino it works just fine!
I don't really know what's the problem if anyone would help me it would be great!
Start by posting your full sketch, using code tags when you do
Have you taken into account that the ESP8266 is a 3.3V device ? What voltage does the RC522 work at and how is it powered ?
check esp8266-pinout-reference-gpios and Arduino_MFRC522v2#pin-layout
#include <SPI.h>
#include <MFRC522.h>
//GPIO 0 --> D3
//GPIO 2 --> D4
#define RST_PIN	5 // RST-PIN for RC522 - RFID - SPI - Modul GPIO5
#define SS_PIN	4
//const uint8_t RST_PIN = D3;
//const uint8_t SS_PIN = D4;
MFRC522 mfrc522(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
/* Be aware of Sector Trailer Blocks */
int blockNum = 4;
/* Create array to read data from Block */
/* Length of buffer should be 4 Bytes
more than the size of Block (16 Bytes) */
byte bufferLen = 18;
byte readBlockData[18];
MFRC522::StatusCode status;
  //Initialize serial communications with PC
  //Initialize SPI bus
  SPI.begin();
  //Initialize MFRC522 Module
  mfrc522.PCD_Init();
  Serial.println("Scan a MIFARE 1K Tag to write data...");
 * loop() function
  /* Prepare the ksy for authentication */
  /* All keys are set to FFFFFFFFFFFFh at chip delivery from the factory */
  for (byte i = 0; i < 6; i++){
    key.keyByte[i] = 0xFF;
  /* Look for new cards */
  /* Reset the loop if no new card is present on RC522 Reader */
  if ( ! mfrc522.PICC_IsNewCardPresent()){return;}
  /* Select one of the cards */
  if ( ! mfrc522.PICC_ReadCardSerial()) {return;}
  Serial.print("\n");
  Serial.println("**Card Detected**");
  /* Print UID of the Card */
  Serial.print(F("Card UID:"));
  for (byte i = 0; i < mfrc522.uid.size; i++){
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i], HEX);
  Serial.print("\n");
  /* Print type of card (for example, MIFARE 1K) */
  Serial.print(F("PICC type: "));
  MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
  Serial.println(mfrc522.PICC_GetTypeName(piccType));
  byte buffer[18];
  byte len;
  //wait until 20 seconds for input from serial
  Serial.setTimeout(20000L);
  //MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
  Serial.println(F("---------------------------------------"));
  Serial.println(F("Enter Student ID, ending with #"));
  len = Serial.readBytesUntil('#', (char *) buffer, 16);
  //add empty spaces to the remaining bytes of buffer
  for (byte i = len; i < 16; i++) buffer[i] = ' ';
  blockNum = 4;
  WriteDataToBlock(blockNum, buffer);
  ReadDataFromBlock(blockNum, readBlockData);
  dumpSerial(blockNum, readBlockData);
  Serial.println(F("Enter First Name, ending with #"));
  blockNum = 5;
  Serial.println(F("Enter Last Name, ending with #"));
  blockNum = 6;
  Serial.println(F("Enter Phone Number, ending with #"));
  blockNum = 8;
  Serial.println(F("Enter Address, ending with #"));
  blockNum = 9;
 * Writ() function
void WriteDataToBlock(int blockNum, byte blockData[])
   //Serial.print("Writing data on block ");
   //Serial.println(blockNum);
  /* Authenticating the desired data block for write access using Key A */
  status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, blockNum, &key, &(mfrc522.uid));
  if (status != MFRC522::STATUS_OK){
    Serial.print("Authentication failed for Write: ");
    Serial.println(mfrc522.GetStatusCodeName(status));
    return;
  else {
    //Serial.print("Authentication OK - ");
  /* Write data to the block */
  status = mfrc522.MIFARE_Write(blockNum, blockData, 16);
  if (status != MFRC522::STATUS_OK) {
    Serial.print("Writing to Block failed: ");
    return;
  else {
    //Serial.println("Write OK");
 * ReadDataFromBlock() function
void ReadDataFromBlock(int blockNum, byte readBlockData[])
   //Serial.print("Reading data from block ");
  for (byte i = 0; i < 6; i++) {
  /* Authenticating the desired data block for Read access using Key A */
   Serial.print("Authentication failed for Read: ");
   return;
  else {
  /* Reading data from the Block */
  status = mfrc522.MIFARE_Read(blockNum, readBlockData, &bufferLen);
    Serial.print("Reading failed: ");
    return;
  else {
    //readBlockData[16] = ' ';
    //readBlockData[17] = ' ';
    //Serial.println("Read OK");
 * dumpSerial() function
void dumpSerial(int blockNum, byte blockData[])
  Serial.print("\n");
  Serial.print("Data saved on block");
  Serial.print(blockNum);
  Serial.print(": ");
  for (int j=0 ; j<16 ; j++){
    Serial.write(readBlockData[j]);
  Serial.print("\n");
  //Empty readBlockData array
  for( int i = 0; i < sizeof(readBlockData);  ++i )
   readBlockData[i] = (char)0; //empty space
It is powered by 3.3v from ESP8266 itself as my module supports 3.3v
Not working "WARNING: Communication failure, is the MFRC522 properly connected?
Scan PICC to see UID, SAK, type, and data blocks...".
if I run code of post 4 on a NodeMCU ESP8266 with the following pins
#define SCK   14    // D5
#define MISO  12    // D6
#define MOSI  13    // D7
#define CS    15    // D8 RFID-RC522 SDA pin
#define RST   0     // D3
I changed two lines of your code
#define RST_PIN	0 //5 // RST-PIN for RC522 - RFID - SPI - Modul GPIO5
#define SS_PIN	15 //4
I get
**Card Detected**
Card UID: C0 FF 62 1A
PICC type: MIFARE 1KB
Not working and the led on the rfid module isn't enough bright @horace
how do you power the RC522? I connect
ESP8266 GND to RC522 GND
ESP8266 3.3V to RC522 3.3V (the power pin on the RC522 is labeled 3.3V)
the LED on the RC522 is then bright
could your RC522 require 5Volts? if so you then require a level converter to connect it to the ESP8266
see @UKHeliBob comment in post 2
It goes bright when I connect the pins but after the code runs or as soon as I press reset it is dim then forever until I remove the power pin of rfid and connect again.
Can you share me the code and photo of connections if possible?
and even if I remove the power supply of the rfid it doesnt care the led brightness stays the same.
when testing your program of post 4 I changed the two lines
I also ran a program using the MFRC522v2 library
// MFRC522v2 File>Examples>MFRC522v2>Custom_SPI for the ESP8266
 * Example showing how to read data from a PICC to serial.
 * This is a MFRC522 library example; for further details and other examples see: https://github.com/OSSLibraries/Arduino_MFRC522v2
 * Example sketch/program showing how to read data from a PICC (that is: a RFID Tag or Card) using a MFRC522 based RFID
 * Reader on the Arduino SPI interface.
 * When the Arduino and the MFRC522 module are connected (see the pin layout below), load this sketch into Arduino IDE
 * then verify/compile and upload it. To see the output: use Tools, Serial Monitor of the IDE (hit Ctrl+Shft+M). When
 * you present a PICC (that is: a RFID Tag or Card) at reading distance of the MFRC522 Reader/PCD, the serial output
 * will show the ID/UID, type and any data blocks it can read. Note: you may see "Timeout in communication" messages
 * when removing the PICC from reading distance too early.
 * If your reader supports it, this sketch/program will read all the PICCs presented (that is: multiple tag reading).
 * So if you stack two or more PICCs on top of each other and present them to the reader, it will first output all
 * details of the first and then the next PICC. Note that this may take some time as all data blocks are dumped, so
 * keep the PICCs at reading distance until complete.
 * @license Released into the public domain.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
 * Not found? For more see: https://github.com/OSSLibraries/Arduino_MFRC522v2#pin-layout
#include <MFRC522v2.h>
#include <MFRC522DriverSPI.h>
#include <MFRC522DriverPinSimple.h>
#include <MFRC522Debug.h>
// RC522 RFID connections  NodeMCU ESP8266
#define RST   0     // D3
// ESP8266 GND to RC522 GND
// ESP8266 3.3V to RC522 3.3V (the power pin on the RC522 is labeled 3.3V)
MFRC522DriverPinSimple ss_pin(15); // Create pin driver. See typical pin layout above.
SPIClass &spiClass = SPI; // Alternative SPI e.g. SPI2 or from library e.g. softwarespi.
const SPISettings spiSettings = SPISettings(SPI_CLOCK_DIV4, MSBFIRST, SPI_MODE0); // May have to be set if hardware is not fully compatible to Arduino specifications.
MFRC522DriverSPI driver{ss_pin, spiClass, spiSettings}; // Create SPI driver.
MFRC522 mfrc522{driver}; // Create MFRC522 instance.
  Serial.begin(115200); // Initialize serial communications with the PC for debugging.
  while (!Serial);      // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4).
  //spiClass.begin(SCK, MISO, MOSI, CS);  // set up SPI pins
  //driver.init();
  mfrc522.PCD_Init();   // Init MFRC522 board.
  MFRC522Debug::PCD_DumpVersionToSerial(mfrc522, Serial);	// Show details of PCD - MFRC522 Card Reader details.
	Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
	if ( !mfrc522.PICC_IsNewCardPresent() || !mfrc522.PICC_ReadCardSerial()) {
		return;
  MFRC522Debug::PICC_DumpToSerial(mfrc522, Serial, &(mfrc522.uid));
a run gave
Card UID: C0 FF 62 FF
Card SAK: 08
Sector Block   0  1  2  3   4  5  6  7   8  9 10 11  12 13 14 15  AccessBits
  15     63   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         62   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         61   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         60   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  14     59   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
Card UID: 15 64 FD FF
Card SAK: 08
         58   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
can you help me with this how is it possible that after even disconnecting the power supply 3.3v and gnd from rfid the brightness remains the same. How is it possible? please help me with this @horace .
if I disconnect the RC522 3.3V line the LED goes dim (taking power via the SCK, MISO, etc pins) and goes bright when I reconnect the 3.3V
I assume you connect the RC522 3.3V to the ESP8266 3.3V ? are you powering anything else from the ESP8266
are you sure your RC522 is a 3.3V version - it appears there are 5V versions - see using-an-rfid-module-with-an-esp8266
otherwise you may have poor connections (jumper wires are an endless source of problems) or even a faulty RC522
hey as soon as I connect the rst pin to 3.3v it works not properly but atleast show the version and card uid not the blocks. could you please help me with this issue?
@horace @UKHeliBob
Problem solved by purchasing a new MRFC522.
But I still don't get that if my old module works with arduino then why not ESP8266?
Special thanks to @horace & @UKHeliBob for helping me and for their time.
possibly the old RC522 was a 5V version would not work with the 3.3V ESP8266
