Hi guys i am starting a new project and quite new to arduino. I got a M0 board which i believe there's rtc in it. I have gotten the rtc running on my serial monitor but i was wondering if there is a possibility to display the running of the rtc on the serial monitor to my OLED display.
My oled display is directly connected to the m0 board and it uses spi.
ckaixu:
... i was wondering if there is a possibility to display the running of the rtc on the serial monitor to my OLED display.
The answer is yes, it is possible. Get a library that is compatible with your OLED and run some examples. I expect one of the examples will show how to print text to the display.
And it has nothing to do with "putting serial monitor on the OLED".
The information exists in variables. You can tell it to print those variables to serial. You can also tell it to display those variables on the OLED. They are two completely different instructions.
You're not passing information to the serial monitor, and THEN taking it from serial monitor to the OLED.
