Hello, I am a beginner and working my way through the Arduino projects book up to Project 03 - Love-o-Meter.
I have followed all instructions and my Serial Monitor readings are all over the place and showing minus temperatures. Other forums I've read from people that have problems with the readings at least show that their readings are consistent but I'm not sure where to start with fixing the problem.
When I touch the temperature TMP36 input nothing changes with the readings or any lights on the board. I've tried editing the code and changing the base temperature but I don't think its anything to do with the code.
I am using a MacBook Pro 2.3 GHz Intel Core i5 - and power is connected via USB port.
Is there something obvious here that I am doing wrong or is there an issue with the sensor?
Thank you in advance ![]()
11:22:09.565 -> Sensor: 84, Volts: 0.41, degrees C: -8.98
11:22:09.601 -> Sensor: 67, Volts: 0.33, degrees C: -17.29
11:22:09.637 -> Sensor: 25, Volts: 0.12, degrees C: -37.79
11:22:09.705 -> Sensor: 57, Volts: 0.28, degrees C: -22.17
11:22:09.741 -> Sensor: 83, Volts: 0.41, degrees C: -9.47
11:22:09.774 -> Sensor: 49, Volts: 0.24, degrees C: -26.07
11:22:09.843 -> Sensor: 27, Volts: 0.13, degrees C: -36.82
11:22:09.881 -> Sensor: 76, Volts: 0.37, degrees C: -12.89
11:22:09.914 -> Sensor: 71, Volts: 0.35, degrees C: -15.33
11:22:09.982 -> Sensor: 26, Volts: 0.13, degrees C: -37.30
11:22:10.014 -> Sensor: 52, Volts: 0.25, degrees C: -24.61
11:22:10.051 -> Sensor: 84, Volts: 0.41, degrees C: -8.98
11:22:10.085 -> Sensor: 55, Volts: 0.27, degrees C: -23.14
11:22:10.159 -> Sensor: 26, Volts: 0.13, degrees C: -37.30
11:22:10.197 -> Sensor: 71, Volts: 0.35, degrees C: -15.33
11:22:10.231 -> Sensor: 75, Volts: 0.37, degrees C: -13.38
11:22:10.299 -> Sensor: 29, Volts: 0.14, degrees C: -35.84
11:22:10.336 -> Sensor: 48, Volts: 0.23, degrees C: -26.56
11:22:10.369 -> Sensor: 84, Volts: 0.41, degrees C: -8.98
11:22:10.438 -> Sensor: 60, Volts: 0.29, degrees C: -20.70
11:22:10.473 -> Sensor: 26, Volts: 0.13, degrees C: -37.30
11:22:10.508 -> Sensor: 66, Volts: 0.32, degrees C: -17.77
11:22:10.543 -> Sensor: 79, Volts: 0.39, degrees C: -11.43
11:22:10.615 -> Sensor: 34, Volts: 0.17, degrees C: -33.40
11:22:10.649 -> Sensor: 43, Volts: 0.21, degrees C: -29.00
11:22:10.682 -> Sensor: 84, Volts: 0.41, degrees C: -8.98
11:22:10.751 -> Sensor: 64, Volts: 0.31, degrees C: -18.75
11:22:10.788 -> Sensor: 30, Volts: 0.15, degrees C: -35.35
11:22:10.822 -> Sensor: 63, Volts: 0.31, degrees C: -19.24
11:22:10.889 -> Sensor: 81, Volts: 0.40, degrees C: -10.45
11:22:10.926 -> Sensor: 41, Volts: 0.20, degrees C: -29.98
11:22:10.959 -> Sensor: 42, Volts: 0.21, degrees C: -29.49
11:22:11.029 -> Sensor: 83, Volts: 0.41, degrees C: -9.47
11:22:11.066 -> Sensor: 69, Volts: 0.34, degrees C: -16.31
11:22:11.101 -> Sensor: 31, Volts: 0.15, degrees C: -34.86
11:22:11.134 -> Sensor: 59, Volts: 0.29, degrees C: -21.19
11:22:11.205 -> Sensor: 83, Volts: 0.41, degrees C: -9.47
11:22:11.242 -> Sensor: 53, Volts: 0.26, degrees C: -24.12
