here is the code I am trying to use. It is to run the Hollow Clock 2
// Please tune the following value if the clock gains or loses.
// Theoretically, standard of this value is 60000.
#define MILLIS_PER_MIN 15000 // milliseconcs per a minute
#define ROTATION_PERIOD_IN_MSEC 10000
// Motor and clock parameters
#define STEPS_PER_ROTATION 4096 // steps of a single rotation of motor
#define RATIO 15 // minutes per a rotation
#define LAP 65536 // value to avoid overflow of long int
// wait for a single step of stepper
int delaytime = 10;
// ports used to control the stepper motor
// if your motor rotate to the opposite direction,
// change the order as {4, 5, 6, 7};
int port[4] = {7, 6, 5, 4};
// sequence of stepper motor control
int seq[8][4] = {
{ LOW, HIGH, HIGH, LOW},
{ LOW, LOW, HIGH, LOW},
{ LOW, LOW, HIGH, HIGH},
{ LOW, LOW, LOW, HIGH},
{ HIGH, LOW, LOW, HIGH},
{ HIGH, LOW, LOW, LOW},
{ HIGH, HIGH, LOW, LOW},
{ LOW, HIGH, LOW, LOW}
void rotate(int step) {
static int phase = 0;
int i, j;
int delta = (step > 0) ? 1 : 7;
step = (step > 0) ? step : -step;
for (j = 0; j < step; j++) {
phase = (phase + delta) % 8;
for (i = 0; i < 4; i++) {
digitalWrite(port[i], seq[phase][i]);
delay(delaytime);
// power cut
digitalWrite(port[i], LOW);
pinMode(port[0], OUTPUT);
pinMode(port[1], OUTPUT);
pinMode(port[2], OUTPUT);
pinMode(port[3], OUTPUT);
pinMode(14, OUTPUT);
digitalWrite(14, LOW);
pinMode(16, INPUT_PULLUP);
long calc_step(long msec) {
return STEPS_PER_ROTATION * msec / MILLIS_PER_MIN / RATIO;
static long prev_msec, prev_pos;
long msec, pos;
if (digitalRead(16) == LOW) {
delaytime = 2; //fast rotation
rotate(20);
delaytime = 20; // resume
return;
msec = millis() % LAP;
if (msec < prev_msec) { // Laps around
msec += LAP; // hide lap around temporarily
if (msec >= prev_msec + ROTATION_PERIOD_IN_MSEC) { // do rotation
pos = calc_step(msec);
rotate(pos - prev_pos);
if (msec >= LAP) { // Laps around
msec %= LAP;
prev_pos = pos;
prev_msec = msec;
