Serial Printing problems
Hi All, can someone please try and point out what I'm doing wrong! I'm trying to print out the heart rate that I'm detecting and passing into Arduino. I can't get it to print properly and I've tried everything!
int heart = 12; //digital pin being used
int heartDetect=0; // detects the value of digital pin 12
int heartRate = 0; // Assigned the value of heartDetect added to itself over a period of time.
int time = 20000; // The time value that I'm using.
extern volatile unsigned long timer0_overflow_count; //Sets the timer
  Serial.begin(300);//need to use a slow serial
  pinMode(heart, INPUT);//declare pin 12 as an INPUT
  heartDetect = digitalRead(heart); //heartDetect is assigned the value of pin 12
  if (timer0_overflow_count < time){ //If it's less than 20 seconds
    heartRate = heartRate + heartDetect; //Add the value of heartRate to itself plus the value of heartDetect
    //Serial.print("  ");
    //Serial.print(heartRate, DEC);
    //Serial.print(0, BYTE);
  else if (timer0_overflow_count > time){ //else If it's over 20 seconds
    Serial.print(" ");
    Serial.print(heartRate, DEC); //print out the value of heartRate
    timer0_overflow_count = 0; //reset the timer
    heartRate = 0; //reset heartRate
For some reason, the only way I can get the value of 'heartRate' to print to serial in the 'else if' statement is to un-comment the serial.print() lines within the 'if' statement. If I don't do this i get a random value assigned to heartRate.
I only want the value of 'heartRate' to be printed to the serial every 20 seconds. I would really appreciate any comments if you have an idea of how I could get around this problem. Thanks,
Tom
At a glance I don't see you setting "timer0_overflow_count" to any thing besides 0.
Unfortunately that doesn't make any difference. Even if I say;
"else if (timer0_overflow_count == 20000){"
is still doesn't work! Thanks anyway. Any other suggestions?
I think what your code is doing is counting how many times through the loop that the heart pin was high. This will undoubtedly overflow your variable and look like a random number. You probably mean to count how many times it switches from 0 to 1.
You might also wish to initialize time to timer0_overflow_count+20000. It doesn't have to start at zero, it will be ticking away during program initialization.
where would I put "timer0_overflow_count+20000"? Would it go in the if statement? I want to read off the value every 20 seconds. Thanks so much for getting back to me. I've been working all day on this!
You should really be using millis() instead of timer0_overflow_count (which is an internal variable).
In any case, what is it you're trying to count? That is, what's hooked up to pin 12?
I'm trying to read the values sent by an LED that blinks on and off whenever a pulse is detected. I can see this value as long as I print it out in the void loop(). If I just tell it to print out to serial after a particular time it gives me a random number, sometimes with a - before it which doesn't make sense at all!
I've tried all of the above suggestions and no matter what I do it just doesn't work! Could it be a bug? Thanks to everyone who's helped so far. Are there any other suggestions? :cry:
I believe jims is right. You want to count the number of times the pin changes from low to high (or vice-versa). Instead, you're counting the number of times through the loop() that the pin is high. You need to remember the previous state of the pin and only increment heartDetect if the most recent reading is different than the previous one.
Thanks for getting back to me - again! How would I go about doing this roughly? I've only just started coding in Arduino!
IT WORKS!!! ;D ;D ;D ;D ;D
Thanks so much to everyone who helped me out! It was what Jims suggested. I thought I was doing what was suggested in the first place and I wasn't at all. After Mellis re-suggested it I had a look at the code again and it turned out I wasn't doing it at all! I also scrapped the timer0_overflow_count system I was using and went back to Millis(). Thanks again,
Tom
