I'm outputting Serial.println(Wifi.status); from my ESP8266 when it is trying to connect to a WIFI hub.
- I'm getting a return of 6 when the device is trying to connect.
- I believe that I'm getting a return of 3 when it connects
- 1 when it cannot connect (I've modified the SSID to a non existent station in the ESP)
- 4 when it cannot connect due to a bad password
I have found this reference https://www.arduino.cc/en/Reference/WiFiStatus however it would be handy if there is any official documentation explaining what these return codes mean.
Is there anything available?
...Surfer Tim gives an informative response here:
http://forum.arduino.cc/index.php?topic=162674.0
You can always find these kinds of things in the source code:
typedef enum {
WL_NO_SHIELD = 255, // for compatibility with WiFi Shield library
WL_IDLE_STATUS = 0,
WL_NO_SSID_AVAIL = 1,
WL_SCAN_COMPLETED = 2,
WL_CONNECTED = 3,
WL_CONNECT_FAILED = 4,
WL_CONNECTION_LOST = 5,
WL_DISCONNECTED = 6
} wl_status_t;
You could write your own function to print it:
const char* wl_status_to_string(wl_status_t status) {
switch (status) {
case WL_NO_SHIELD: return "WL_NO_SHIELD";
case WL_IDLE_STATUS: return "WL_IDLE_STATUS";
case WL_NO_SSID_AVAIL: return "WL_NO_SSID_AVAIL";
case WL_SCAN_COMPLETED: return "WL_SCAN_COMPLETED";
case WL_CONNECTED: return "WL_CONNECTED";
case WL_CONNECT_FAILED: return "WL_CONNECT_FAILED";
case WL_CONNECTION_LOST: return "WL_CONNECTION_LOST";
case WL_DISCONNECTED: return "WL_DISCONNECTED";
Serial.println(wl_status_to_string(WiFi.status()));
Pieter
Thats a nice way of doing it! Thanks.
Hey guys,
I just wanted to let you know what I found out how the WiFi.status() behaves in different cases:
- if wifi is visible:
WiFi.begin() >> WL_DISCONNECTED >> WL_CONNECTED
if wifi then disappears:
WL_DISCONNECTED >> WL_NO_SSID_AVAIL
- if wifi is not visible:
WiFi.begin() >> WL_DISCONNECTED >> WL_NO_SSID_AVAIL
if wifi then appears:
I never found an occasion where WiFi.status() is WL_CONNECTION_LOST.
Here is the code with which I tested this (with ESP8266):
#include <ESP8266WiFi.h>
char ssid[] = "YourSSID"; // your network SSID (name)
char pass[] = "YourPW"; // your network password
pinMode(BUILTIN_LED, OUTPUT);
digitalWrite(BUILTIN_LED, LOW);
if (Serial.available() > 0) {
String input;
input = Serial.readStringUntil('\n');
if (input[0] == 'c') {
WiFi.begin(ssid, pass);
Serial.println("connecting...");
else if (input[0] == 'd') {
WiFi.disconnect();
Serial.println("disconnecting...");
if (WiFi.status() == WL_IDLE_STATUS) { // when not connected to a network, but powered on
digitalWrite(BUILTIN_LED, !digitalRead(BUILTIN_LED));
Serial.println("WL_IDLE_STATUS");
else if (WiFi.status() == WL_CONNECTED) {
Serial.print("WL_CONNECTED ");
else if (WiFi.status() == WL_NO_SSID_AVAIL) {
digitalWrite(BUILTIN_LED, HIGH);
Serial.println("WL_NO_SSID_AVAIL");
else if (WiFi.status() == WL_CONNECT_FAILED) {
Serial.println("WL_CONNECT_FAILED");
else if (WiFi.status() == WL_CONNECTION_LOST) {
Serial.println("WL_CONNECTION_LOST");
else if (WiFi.status() == WL_DISCONNECTED) {
Serial.println("WL_DISCONNECTED");
else {
Serial.print("unknown status: ");
Serial.println(WiFi.status());
delay(200);
About WiFi.status() is WL_CONNECTION_LOST, did you try switch off your wifi rooter ?
PieterP:
const char* wl_status_to_string(int status) {
Very nice code example. The enum appears to have changed at some point so the function definition needs to replace wl_status_t with int per above.
