Serial read not reflecting changes written to com port
Hi All
I'm having difficulty getting the Arduino serial output to update based on the data sent to the com port.
When I send the first instruction the Arduino responds as expected.
I then send a new instruction with different data and the Arduino returns the information related to the first instruction, not the new data.
I am sending the the instruction from a winforms app (C#) and reading the data back into the same app.
This is the received string from the app
#A800010001500004000000000051\n
These are the values returned by the Arduino based on the above
Dir: A
Max Speed: 8000
Speed: 1000
Accel: 1500
Step: 00400
Angle: 000
Rotations: 000005
Abort: 1
Rotations as int: 5
If i change my command to
#B800010001500004000000000051\n
The returned data does not reflect the change to the first char following the #
#include <AccelStepper.h>
AccelStepper motor(1, 2, 12); //1 = Driver mode, 2 = Pulse pin, 12 = direction pin
//-----For Serial Read-----
const byte buffSize = 30;
char serialCommand[buffSize];
const char endMarker = '\n';
byte bytesRecvd = 0;
bool readBuffer;
bool writeOutValues;
char cDir[2];
char cMaxSpeed[5];
char cSpeed[5];
char cAngle[4];
char cAccel[5];
char cStepsPerRev[6];
char cRotations[7];
char cAbortFlag[2];
  writeOutValues = false;
  Serial.println("Starting Motor Driver V1.0");
  readSerial();
  serialData();
void readSerial()
  if (Serial.available() == 0) {
    return;
  char myChar = Serial.read();
  if (myChar == '#')
    readBuffer = true;
    serialCommand[0] = '\0';
  //Set a start char and check if present
  if (readBuffer == true)
    if (myChar != endMarker) {
      serialCommand[bytesRecvd] = myChar;
      bytesRecvd ++;
      if (bytesRecvd == buffSize) {
        bytesRecvd = buffSize - 1;
    else { // myChar is the endMarker
      serialCommand[bytesRecvd] = 0;
  if (myChar == endMarker)
    readBuffer = false;
    writeOutValues = true;
void serialData()
  if (writeOutValues == true)
    cDir[0]= '\0';
    cMaxSpeed[0]= '\0';
    cSpeed[0]= '\0';
    cAccel[0]= '\0';
    cStepsPerRev[0]= '\0';
    cAngle[0]= '\0';
    cRotations[0]= '\0';
    cAbortFlag[0]= '\0';
    Serial.println("Serial data function has been executed");
    Serial.print("Command: ");
    Serial.println(serialCommand);
    cDir[0] = serialCommand[1];
    Serial.print("Dir: ");
    Serial.println(cDir);
    cMaxSpeed[0] = serialCommand[2];
    cMaxSpeed[1] = serialCommand[3];
    cMaxSpeed[2] = serialCommand[4];
    cMaxSpeed[3] = serialCommand[5];
    Serial.print("Max Speed: ");
    Serial.println(cMaxSpeed);
    cSpeed[0] = serialCommand[6];
    cSpeed[1] = serialCommand[7];
    cSpeed[2] = serialCommand[8];
    cSpeed[3] = serialCommand[9];
    Serial.print("Speed: ");
    Serial.println(cSpeed);
    cAccel[0] = serialCommand[10];
    cAccel[1] = serialCommand[11];
    cAccel[2] = serialCommand[12];
    cAccel[3] = serialCommand[13];
    Serial.print("Accel: ");
    Serial.println(cAccel);
    cStepsPerRev[0] = serialCommand[14];
    cStepsPerRev[1] = serialCommand[15];
    cStepsPerRev[2] = serialCommand[16];
    cStepsPerRev[3] = serialCommand[17];
    cStepsPerRev[4] = serialCommand[18];
    Serial.print("Step: ");
    Serial.println(cStepsPerRev);
    cAngle[0] = serialCommand[19];
    cAngle[1] = serialCommand[20];
    cAngle[2] = serialCommand[21];
    Serial.print("Angle: ");
    Serial.println(cAngle);
    cRotations[0] = serialCommand[22];
    cRotations[1] = serialCommand[23];
    cRotations[2] = serialCommand[24];
    cRotations[3] = serialCommand[25];
    cRotations[4] = serialCommand[26];
    cRotations[5] = serialCommand[27];
    int  n;
    n = atoi(cRotations);
    Serial.print("Rotations: ");
    Serial.println(cRotations);
    cAbortFlag[0] = serialCommand[28];
    Serial.print("Abort: ");
    Serial.println(cAbortFlag);
    Serial.print("Rotations as int: ");
    Serial.println(n);
Any help that you can give would be much appreciated.
Can’t see anything that ever resets bytesRecvd = 0.
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
pcbbc, I hadn't spotted that one
Robin2, somehow I managed to miss that example.
Thanks both
Dave
