Serial terminal software that has more features than bray's terminal
Hello everybody,
I want to repeat what is written in the title:
I am searching for a serial terminal software that has more features than bray's terminal version 2013.
So what functions / features does bray's terminal have?
  • pre-definable request / response
  • macros (repeatable with specifiying an interval)
  • scripting
If you take the time to not only post the name of the serial terminal software but a feature list like above I appreciate that very much.
It would help to know which extra features you are looking for rather than us just posting a list of alternative serial monitors
bray's terminal scans for COM-Ports on startup. But is unable to re-scan if the software is already running. There is a scan for COM-port-function but you only see a message
"access denied"
I assume (= not knowing) this is caused by the age of the software 2013
So the feature is
  • always successfully re-scanning the available com-ports
  • start a new logfile once per hour, once per 24 hours
What do you want to happen if a COM port becomes available or unavailable ?
if it becomes available ideal: optional activating a popup-message found "COM-Port #"
or COM-port will be found on button "scan for COM-Ports"
if a COM-Port becomes unavailable ideal: popup-message COM-Port # not available
at least deactivated, greyed out or something similar
I imagine that an emulator with a script language may well be able to do what you describe. Many, many years ago I used a terminal emulator named Reflection 4, which has a script language, albeit using what amounts to BASIC, to run performance tests on a mainframe system and it did all that I needed and more
