Serious Noob question, please help!!
Hi all, OK well this seems to be such a noob question that I can't find anything online about it. I would like to control 1 servo and on small DC motor via serial input, I have 2 sample sketches (see below), which control a servo and motor individually but have no idea how to put them together so that I can control the motor and servo together.
Any Help would be greatly appreciated. I have add the 2 sketches below.
Thanks in advance
Servo Controller:
int servoPin = 7;            // R/C  Servo connected to digital pin
int myAngle;                 // angle of the servo (roughly in degrees) 0-180
int pulseWidth;              // function variable
int val;                     // variable used to store data from serial port
void servoPulse(int servoPin, int myAngle) {
  pulseWidth = (myAngle * 9) + 700;  // converts angle to microseconds
  digitalWrite(servoPin, HIGH);       // set servo high
  delayMicroseconds(pulseWidth);      // wait a very small amount
  digitalWrite(servoPin, LOW);        // set servo low
  delay(20);                          // refresh cycle of typical servos (20 ms)
  pinMode(servoPin, OUTPUT);          // set servoPin pin as output
  Serial.begin(19200);                 // connect to the serial port
  Serial.println("Servo Serial Simple ready");
  val = Serial.read();      // read the serial port
  // if the stored value is a single-digit number, blink the LED that number
  if (val >= '0' && val <= '9' ) {
    val = val - '0';       // convert from character to number
    val = val * (180/9);   // convert from number to degrees
    Serial.print("moving servo to ");
    Serial.print(val,DEC);
    for( int i=0; i<50; i++ ) {
      servoPulse(servoPin, val);
DC Motor Controller:
int motorPin = 9;
int val = 0; // variable to store the data from the serial port
pinMode(motorPin,OUTPUT); // declare the motor's pin as output
Serial.println("Welcome to SerialMotorSpeed!");
Serial.println("Enter speed number 0-9:");
void loop () {
val = 28 * val; // convert from 0-9 to 0-255 (almost)
Serial.print("Setting speed to ");
Serial.println(val);
analogWrite(motorPin,val);
Moderator edit: OP, you can finish off, and put the DC controller code in a code box.
Please use the code button when posting code:
You can try this way, change '0' to '9' on the DC motor into something else, say 'A' to 'J' so when you type in characters such as 'J' the DC motor runs and the servo is not affected.
Then you just combine the setup() from the two programs and save goes with loop() and everything outside these two functions. Give it a try.
Any particular reason for not using the servo library?
H Guys.
AWOL I will check out the servo library, in all honesty I thought that only controlled the servo but I am very new to this so will research that option.
Luidr, thanks will have a look, it is that whole bit about joining the two sketches into one that has me confused. Tried combining them with no success but at the moment it really is shooting in the dark with all this coding work at least until I have some more experience, will have to read up on that one.
Thanks guys
I can understand noobs need more help but don't expect to get spoon-fed for everything. You should try combining the code yourself and see how your way works/not-works and how the following code works fine. Tested with my servo and an LED. I can't find my transistors. It's holidays!
int motorPin = 9;
  if (val >= 'A' && val <= 'J' ) {
    val = val - 'A';       // convert from character to number
    val = 25 * val;        // convert from 0-9 to 0-255 (almost)
Liudr thanks for the help and taking the time, but like said in my reply I am willing to read up on these things and don't expect to be spoon fed.
Figured it out not to long after I reposted.
regards
Good for you! Combining two codes in general is difficult to do. I suggest you make an attempt and post both the separate codes and your attempt of combination if you have trouble getting the combined code to work.
