Hi.
Do need some help please
Having trouble with my servos and joystick
Have two joysticks connected to four servos
Problem when moving one joystick three of the servos move
Have them connected through Sensor shield with external power supply 5V
#include <meArm.h>
#include <Wire.h>
/* meArm IK joysticks - York Hackspace May 2014
* Using inverse kinematics with joysticks
* Uses two analogue joystcks (two pots each)
* First stick moves gripper forwards, backwards, left and right
* Second stick moves gripper up, down, and closes and opens.
* I used Sparkfun thumbstick breakout boards, oriented 'upside down'.
* Pins:
* Arduino Stick1 Stick2 Base Shoulder Elbow Gripper
* GND GND GND Brown Brown Brown Brown
* 5V VCC VCC Red Red Red Red
* A0 HOR
* A1 VER
* A2 HOR
* A3 VER
* 11 Yellow
* 10 Yellow
* 9 Yellow
* 6 Yellow
//#include "meArm.h"
#include <Servo.h>
int basePin = 12;
int shoulderPin = 9;
int elbowPin = 6;
int gripperPin = 3;
int xdirPin = 0;
int ydirPin = 1;
int zdirPin = 4;
int gdirPin = 3;
meArm arm;
arm.begin(basePin, shoulderPin, elbowPin, gripperPin);
float dx = map(analogRead(xdirPin), 0, 1023, -5.0, 5.0);
float dy = map(analogRead(ydirPin), 0, 1023, 5.0, -5.0);
float dz = map(analogRead(zdirPin), 0, 1023, 5.0, -5.0);
float dg = map(analogRead(gdirPin), 0, 1023, 5.0, -5.0);
if (abs(dx) < 1.5) dx = 0;
if (abs(dy) < 1.5) dy = 0;
if (abs(dz) < 1.5) dz = 0;
if (!(dx == 0 && dy == 0 && dz == 0))
arm.goDirectlyTo(arm.getX() + dx, arm.getY() + dy, arm.getZ() + dz);
if (dg < -3.0)
arm.closeGripper();
else if (dg > 3.0)
arm.openGripper();
delay(50);
