Hello,
Looking for some help in finding where I've gone wrong in controlling a mechanical eye project.
I'm following the "Compact Eye" animatronic from Will Cogley and I'm not sure if my issues lies with wiring or something else.
Issue - When I have everything wired up, except power for the motors the code constantly reports "329" in the serial monitor as the received input without any input from me. When I supply motor power I can move the connected joystick to affect the input from the X axis only but it means the servos are always fighting to move from whatever is forcing the "329" input. The only time I can get this input to stop is when I disconnect the "VCC" connection of the servo driver from the 5 volt rail on the breadboard I have it connected to but then I cannot test further since the servo driver is disconnected.
Any guidance is appreciated and the hardware, code and wiring diagram is below. Thanks!
Hardware
- Arduino Uno R3
- Adafruit PCA9685 16 Channel Servo driver
- HiLetgo Game Joystick
- potentiometer
- momentary tactile button
Wiring
Code
// Nilheim Mechatronics Simplified Eye Mechanism Code
// Make sure you have the Adafruit servo driver library installed >>>>> https://github.com/adafruit/Adafruit-PWM-Servo-Driver-Library
// X-axis joystick pin: A1
// Y-axis joystick pin: A0
// Trim potentiometer pin: A2
// Button pin: 2
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN 140 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 520 // this is the 'maximum' pulse length count (out of 4096)
uint8_t servonum = 0;
int xval;
int yval;
int lexpulse;
int rexpulse;
int leypulse;
int reypulse;
int uplidpulse;
int lolidpulse;
int trimval;
const int analogInPin = A0;
int sensorValue = 0;
int outputValue = 0;
int switchval = 0;
Serial.println("8 channel Servo test!");
pinMode(analogInPin, INPUT);
pinMode(2, INPUT);
pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
delay(10);
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulselength = 1000000; // 1,000,000 us per second
pulselength /= 60; // 60 Hz
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000000; // convert to us
pulse /= pulselength;
Serial.println(pulse);
// pwm.setPWM(n, 0, pulse);
xval = analogRead(A1);
lexpulse = map(xval, 0, 1023, 270, 390);
rexpulse = lexpulse;
switchval = digitalRead(2);
yval = analogRead(A0);
leypulse = map(yval, 0, 1023, 280, 400);
reypulse = map(yval, 0, 1023, 400, 280);
trimval = analogRead(A2);
trimval = map(trimval, 320, 580, -40, 40);
uplidpulse = map(yval, 0, 1023, 280, 420);
uplidpulse += (trimval - 40);
uplidpulse = constrain(uplidpulse, 280, 400);
lolidpulse = map(yval, 0, 1023, 410, 280);
lolidpulse += (trimval / 2);
lolidpulse = constrain(lolidpulse, 280, 400);
pwm.setPWM(0, 0, lexpulse);
pwm.setPWM(1, 0, leypulse);
pwm.setPWM(2, 0, rexpulse);
pwm.setPWM(3, 0, reypulse);
if (switchval == HIGH) {
pwm.setPWM(4, 0, 240);
pwm.setPWM(5, 0, 240);
else if (switchval == LOW) {
pwm.setPWM(4, 0, uplidpulse);
pwm.setPWM(5, 0, lolidpulse);
Serial.println(lexpulse);
delay(5);
