I recently bought an LCSC-16 that is a servo controller for 16 servos but I can't find any tutorial or place where someone shows or explains how to use it has 2 big VCC and ground connectors the 16 pins for the servos and 4 pins for ground, VCC, RT, and TX did someone knows how this works?
Yeah, we know - you told us on your other topic
Sorry I thought that the other one get deleted because I didn't find it sorry
I recently bought an LCSC-16, 16 channel servo motor controller for Arduino but I have a problem because I'm trying to find any video or tutorial that teaches how to use it, it just has the 16 wires for the servos 2 big VCC, and ground connectors and 4 pins for another VCC, ground, RT, and TX did someone knows anything about this?
Would this be the device?
LCSC - 16 16 channel servo motor controller + USB cable
- Control of the power supply: 4-5.5 V DC
- Servo power: 4.5-6 v DC
- As many as 16 channel independent servo control channel
- Support serial port (TTL/USART interface), or supporting the use of USB cable, USB interface to realize control
- Support on the market most of the PWM signal control of the servo
- Built-in test equipment functions, automatic identification serial port , without setting
- PCB size: 42.5 (mm) x42.5 (mm)
Address: Room 301, Building No.3, Guole Technopark, Lirong Road, Dalang Street, Longhua District, Shenzhen 518110, China.
Mobile: +86-18927473783
E-mail: helen@chinalctech.com/helen@lctech-inc.com
Aliexpress store name: China Lctech Store :https://www.aliexpress.com/store/5434130
Skype: chinalctech
WeChat: china-lctech
QQ: 2408710089
Follow this 16-channel servo driver page:
https://wiki.keyestudio.com/Ks0258_keyestudio_16-channel_Servo_Motor_Drive_Shield
And this one:
https://www.mouser.com/datasheet/2/737/adafruit-16-channel-pwm-slash-servo-shield-932749.pdf
Yeah sorry that's the exact one
Have you attached a terminal to the tx/rx/gnd pins? The "reverse engineering" links are about finding data from the uart port.
How did I do that?
@juanespinosachessal, please do not cross-post. Threads merged.
The links explain, but here, from your comm port to the LCSC-16
RX<--TX
TX-->RX
GND---GND
Start minicom/hyperterm/kermit and select the comm port... then tap a few times on the return/enter key.
Ok thanks, I'm gonna try that
