Hello,
I'm a beginner using Arduino, I'm trying to have a one axis camera stabilizer working for a motorcycle, starting from an existing tutorial which you can find here :
With some help from the autor I've been able to compile and upload correctly the following code :
// 2 servo planar stabilization system
// wp
// Jan 2016
// Based on Jeff Rowber's work found at
// https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/MPU6050.cpp
// Use at your own risk.
// This code is placed under the MIT License (MIT)
// Copyright (c) 2016 woojay poynter
//Permission is hereby granted, free of charge, to any person obtaining a copy
//of this software and associated documentation files (the "Software"), to deal
//in the Software without restriction, including without limitation the rights
//to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
//copies of the Software, and to permit persons to whom the Software is
//furnished to do so, subject to the following conditions:
//The above copyright notice and this permission notice shall be included in all
//copies or substantial portions of the Software.
//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
//IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
//FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
//AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
//LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
//OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
//SOFTWARE.
// Servo Connection
// BROWN - gnd
// red - 5v
// yellow - d10 (pwm on Sero 1)
// - d11 (servo 2)
// MPU Connection
// VCC - 5v
// GND - GND
// SCL - A5 (w/ 10k PuR)
// SDA - A4 (w/ 10k PuR)
// INT - D2 (not used)
#include <Servo.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
#define LED_PIN 13
bool blinkState = true;
Servo Servo1; // First Servo off the chassis
Servo Servo2; // Second Servo off the chassis
int Servo1Pos = 0;
int Servo2Pos = 0;
float mpuPitch = 0;
float mpuRoll = 0;
float mpuYaw = 0;
// define MPU instance
MPU6050 mpu; // class default I2C address is 0x68; specific I2C addresses may be passed as a parameter here
// MPU control/status vars
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
// relative ypr[x] usage based on sensor orientation when mounted, e.g. ypr[PITCH]
#define PITCH 1 // defines the position within ypr[x] variable for PITCH; may vary due to sensor orientation when mounted
#define ROLL 2 // defines the position within ypr[x] variable for ROLL; may vary due to sensor orientation when mounted
#define YAW 0 // defines the position within ypr[x] variable for YAW; may vary due to sensor orientation when mounted
My current mounting is exactly the same as described in the tutorial, using two 9g servos :
But, as soon as I connect the board to a power source (from my computer or an external USB power source, once again as shown in the tutorial) .. nothing happens
The servos should begin rotating to calibrate, then rotate when moving the MPU6050 chip
Maybe I'm missing something in the code that I should modify ?
Could somebody please help me with this ?
Thank you very much
