I'm trying to use the Web editor for an IoT project, but when I try to include the library
#include <Servo.h>
I get the following eror message
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:uPesy_wroom --build-cache-path /tmp --output-dir /tmp/654265440/build --build-path /tmp/arduino-build-3FB57BAB7B2088FCFFF2C58B89DCF85C /tmp/654265440/LED_first_try_dec19a
In file included from /tmp/654265440/LED_first_try_dec19a/LED_first_try_dec19a.ino:18:
/home/builder/Arduino/libraries/servoesp32_1_1_1/src/Servo.h:67:81: error: call to non-'constexpr' function 'const _Tp& std::min(const _Tp&, const _Tp&) [with _Tp = int]'
static const int TIMER_RESOLUTION = std::min(16, SOC_LEDC_TIMER_BIT_WIDE_NUM);
/home/builder/Arduino/libraries/servoesp32_1_1_1/src/Servo.h: In member function 'T ServoTemplate<T>::mapTemplate(T, T, T, T, T) const':
/home/builder/Arduino/libraries/servoesp32_1_1_1/src/Servo.h:256:28: error: 'is_floating_point_v' is not a member of 'std'
if constexpr (std::is_floating_point_v<T>) {
/home/builder/Arduino/libraries/servoesp32_1_1_1/src/Servo.h:256:28: note: suggested alternative: 'is_floating_point'
is_floating_point
/home/builder/Arduino/libraries/servoesp32_1_1_1/src/Servo.h:256:49: error: expected primary-expression before '>' token
/home/builder/Arduino/libraries/servoesp32_1_1_1/src/Servo.h:256:50: error: expected primary-expression before ')' token
Multiple libraries were found for "WiFi.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFi
Not used: /home/builder/opt/libraries/wifi_1_2_7
Not used: /home/builder/opt/libraries/nina_wi_fi_1_0_1
Not used: /home/builder/opt/libraries/wifinina_1_8_14
Not used: /home/builder/opt/libraries/wifiespat_1_4_3
Not used: /home/builder/opt/libraries/seeed_arduino_rpcwifi_1_0_6
Not used: /home/builder/opt/libraries/indhilib_3_0_5
Not used: /home/builder/opt/libraries/da16200_wi_fi_library_for_arduino_1_1_0
Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1
Multiple libraries were found for "WiFiClientSecure.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFiClientSecure
Multiple libraries were found for "Servo.h"
Used: /home/builder/opt/libraries/servoesp32_1_1_1
Not used: /home/builder/opt/libraries/microbitv2_hhs_0_1_6
Not used: /home/builder/opt/libraries/esp32_esp32s2_analogwrite_5_0_2
Not used: /home/builder/opt/libraries/servo_1_2_1
Not used: /home/builder/opt/libraries/evive_2_0_3
Not used: /home/builder/opt/libraries/rokitsmart_1_0_9
Not used: /home/builder/opt/libraries/printoo_library_1_0_2
Not used: /home/builder/opt/libraries/xmc_servo_1_0_1
Error during build: exit status 1
Any help would be appreciated
