Servo help
I have finally got 4 servo motors.
5 volts.
http://www.ebay.com.au/itm/281080712509?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
(at a cheaper price)
Anyway, got them, got the SERVO sketch and tried one.
External power added.
NOTHING.
It uses pin 9 as the output.... So that is the second pin (from the right) on the second row (from the left) looking at the arduino with the USB to the LEFT.
Correct?
The 3 wires are RED, BROWN and ORANGE.
Lovely how they aren't explained what is what.
From what I gather:
BROWN - Power, NEGATIVE.
RED - Power, POSITIVE. (5 volts)
YELLOW - Signal.
Anyone please?
Anyone please?
Please what? What are you using for an external power supply and how do you have it wired? What code are you using?
lost_and_confused:
Are we to assume you mean the "sweep" sketch?
lost_and_confused:
Did you connect the Arduino's ground to the servo/external supply ground?
lost_and_confused:
From what I gather:
YELLOW - Signal.
That should be correct.
(Strange, I am not getting notifications of replies.)
Yes, the SWEEP sketch.
The external power supply is connected to the ..... external power connector of the arduino.
So wouldn't the two power supply grounds be connected?
Oh, I also tried moving the control line around to adjacent pins. Still nothing.
I don't think that is pin 9! But again you don't say which Arduino your using?? Don't seem to be a Uno or Nano, with a pin-9 in that position.
It uses pin 9 as the output.... So that is the second pin (from the right) on the second row (from the left) looking at the arduino with the USB to the LEFT. Correct?
All Arduino pins are usually very clearly marked and numbered, no need to guess!! The 3 cables are usually BLK/BWN for GND, RED for 5v, and the signal Orange/Yellow.
If you code is OK? and we can't see it, then the pin number is wrong, or you have a wiring problem?
Do not power the servo from the Arduino, use a seperate power supply or batteries, do connect both GND's
It seems there's a fault with the system, no one is getting any notifications at the moment, or so I'm told...
Hope it helps, Regards.
Mel.
The servos need an external power supply like below, not thru the arduino.
Just looked at one of my circuit projects,, It might be the pulses should be in the range of
0 to 1 or 2 ms.
so,,
repeating 50 to 100 times per second may be something like right.
I'd have to get out the scope to verify things,, (don't know if it works now).
Repeating more quickly has the servo respond quickly, repeating more slowly might save power/cpu time.
RParker:
0 to 1 or 2 ms.
so,,
Not quite: 1 to 2ms, with 1.5 as "neutral" or 90 degrees, and yes 50Hz is the normal repeat. You can change the repeat by changing the value of REFRESH_INTERVAL in servo.h from its standard 20ms. Pic attached is a scope trace from a servo attached with the default pulse of 1.5ms at 50Hz.
