hey,
i've got already project and i just need to add to it by function (not in the loop area),
gate that will open (from 180 degrees to 90 - rotate 90 degrees left) wait for few seconds and then close back (90 degrees to 180 - rotate 90 degrees right) .
its a little demo to a parking system, and i looking to built a gate.
it need to be small and easy to build.
thank you
i need help by thinking what kind of motor is the best for the project,
i tried to work with servo motor but i feel that its hard to adjust him to go 90 degrees and 180 degrees perfectly.
in the other hand, i think that with servo motor i can rotate him to left and the to right without any other device.
so i need to know, maybe i got the wrong servo kind. how servo motor work for you?
can i trust him to move exactly 90 degrees to left and then 90 to right?
You probably need to use google to learn the details about how servos work before starting your project. How you will use a servo in your project will determine weather a servo will be appropriate or have the accuracy you desire.
