Hello everyone!
i'm doing a code for an automatic door...so I want to use the monitor serial, because i will put this code in an app.
so i code like this:
#include <Servo.h>
byte acao = 0;
Servo PortaoGaragem;
int pos = 0; // variavel de armanezamento da posição do servo //
// Portão Garagem //
// 1 => Abrir //
// 2 => Fechar //
PortaoGaragem.attach(9); // attach (anexar) referente ao pino que suporta o servo //
PortaoGaragem.write(0);
//Portão Garagem //
acao = 0;
if (Serial.available() > 0)
acao = Serial.read();
if (acao == 49 && pos < 10) //1 = abrir
Serial.println("abrir");
for (pos = 0; pos <= 80; pos += 1)
PortaoGaragem.write(pos);
delay(50);
acao = 1;
acao = 1;
if (Serial.available() > 1)
if (acao == 1 && pos < 80) //2 = fechar
Serial.println("fechar");
for (pos = 80; pos <= 0; pos +=1)
delay(50);
acao = 1;
but the monitor serial have been reading just "abrir" (1) and not "fechar" (2).
what i can do?
LarryD
August 14, 2022, 6:08pm
2
byte acao = 0;
You might want to change this to char .
How are you sending 1 (acao == 1) on you serial monitor ?
why cant i use "byte acao = 0; "?
in my serial monitor i'm seendig 1 to open de door, look:
//Portão Garagem //
acao = 0;
delay(50);
i'm not seendig acao == 1 or acao == 2, just "1"...and i'd like to use "2" to close the door.
LarryD
August 14, 2022, 6:45pm
4
Google ASCII
char acao = ‘0’;
//Portão Garagem //
acao = ‘0’;
if (acao == ‘1’ && pos < 10) //1 = abrir
delay(50);
well, the problem is here yet.
the problem is, when i send "1" to my serial monitor, the servo goes from 0º to 80º twice. and when i send 2 the servo goes from 80º to 0º.
the servo isn't respecting may command, that would be "1" to open//abrir or "2" to close//fechar.
LarryD
August 14, 2022, 7:41pm
6
#include <Servo.h>
char acao;
int pos; // variavel de armanezamento da posição do servo //
pinMode(9, OUTPUT);
// 1 => Abrir //
// 2 => Fechar //
pos = 0;
} //END of setup()
while (Serial.available() > 0)
if (acao == '1' || acao == '2')
if (acao == '1' && pos == 0)
acao = '0';
for (pos = 0; pos < 80; pos = pos + 1)
delay(50);
if (acao == '2' && pos == 80)
acao = '0';
for (pos = 80; pos > 0; pos = pos - 1)
delay(50);
} //END of loop()
wow it worked!!! thanks xD
i'll study more about this "while", well i think that this whille allowed the if w/ break.
this topic is cloosed XD
