I bought recently 3 servos SG90 and just tested them with the code to swing the arm from one side to the other.
One of the servos works perfectly fine as it should but the other 2 servos do not move at all. What could be wrong here?
Are they blocked any way? Is there a procedure to unblock them?
Can you please post your code?
Can you please post some images of your project?
So we can see your component layout?
Have you swapped servos around to check if it is a circuit/software or servo problem?
