I'm using two Adafruit Feather M0 RFM69HCW as TX and RX nodes to transfer various data. The basic set-up, using a struct containing different data-types, works.
However, already on the TX node, when I serial plot the values read from the pin to which a potentiometer's wiper is connected, the values often jump, and thus a servo connected to the RX node, does not rotate smoothly.
I suspect it has something to do with the handshaking between TX and RX, but what is the cause and how can I prevent these often large jumps in values from occurring?
Should I not use RHReliableDatagram.h and instead send in a "simpler" or "brute force" kind of way with another RadioHead class that prevents the apparent "hickups" on the TX side?
Thanks a lot for some suggestions!
TX code sufficient to show the issue
#include <SPI.h>
#include <RH_RF69.h>
#include <RHReliableDatagram.h>
#define RF69_FREQ 915.0
#define DEST_ADDRESS 1
#define MY_ADDRESS 2
#if defined(ADAFRUIT_FEATHER_M0)
#define RFM69_CS 8
#define RFM69_INT 3
#define RFM69_RST 4
#endif
RH_RF69 rf69(RFM69_CS, RFM69_INT);
RHReliableDatagram rf69_manager(rf69, MY_ADDRESS);
const byte pinPotentiometer = A1;
struct nodeData // Struct to contain the data to be transmitted
bool momentaryswitch;
int potentiometer;
float sensor;
unsigned long counter;
} nodeTX; // The struct's variable list name
uint8_t bufTX[RH_RF69_MAX_MESSAGE_LEN];
pinMode(RFM69_RST, OUTPUT);
digitalWrite(RFM69_RST, LOW);
if (!rf69_manager.init())
Serial.println("RFM69 radio init failed");
while (1);
if (!rf69.setFrequency(RF69_FREQ))
Serial.println("setFrequency failed");
rf69.setTxPower(20, true);
uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
rf69.setEncryptionKey(key);
nodeTX.momentaryswitch = 1; // Some dummy data to transmit
nodeTX.potentiometer = 512;
nodeTX.sensor = 21.36;
nodeTX.counter = 0;
readPotentiometer ();
if (rf69_manager.sendtoWait((uint8_t *)&nodeTX, sizeof(nodeTX), DEST_ADDRESS))
uint8_t len = sizeof(bufTX);
uint8_t from;
if (rf69_manager.recvfromAckTimeout(bufTX, &len, 1000, &from))
bufTX[len] = 0;
Serial.println((char*)bufTX);
Serial.println("No reply RX -> TX");
Serial.println("TX -> RX failed (no ack)");
void readMomentarySwitch ()
void readPotentiometer ()
nodeTX.potentiometer = map(analogRead(pinPotentiometer), 0, 1023, 10, 170);
Serial.println(nodeTX.potentiometer);
void readSensor ()
void incrementCounter ()
Image showing the value jumps already on TX before being transmitted
