Setting pin modes in a custom library
Hello, I am currently trying to set two input pins for a wireless project I am working on and everything works except the read switch function no matter what pin I set it to read on the server ESP8266 NodeMCU it always reads off GPIO 0. I have tried everything I can think of but I'm assuming I messed something up in the library I created. Any help would be very much appreciated!
CPP File
#include "Arduino.h"
#include "ReadSensors.h"
ReadSensors::ReadSensors(int pin, int pin1){
_pin = pin;
_pin1 = pin1;
  void ReadSensors::pinSetup(){
    pinMode(_pin, INPUT);
    pinMode(_pin1, INPUT_PULLUP);
  int ReadSensors::readSwitch() {
    int _switchState = digitalRead(_switchPin);
    return _switchState;
  float ReadSensors::readSensor(){
    float _sensorValue = analogRead(_pin);
    return _sensorValue;
.h file
#ifndef ReadSensors_h
#define ReadSensors_h
class ReadSensors
public:
ReadSensors(int pin, int pin1);
    void pinSetup();
    int readSwitch(void);
    float readSensor(void);
private:
int _switchPin;
int _pin;
int _pin1;
float _sensorValue;
int _switchState;
#endif
Server code
#include <ReadSensors.h>
#include <ESP8266WiFi.h>
#include "ESPAsyncWebServer.h"
// Set your access point network credentials
const char* ssid = "ESP8266-Access-Point";
const char* password = "123456789";
ReadSensors ReadSensors(A0, 9);
const int Relay1 = 5;
const int Relay2 = 4;
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readTemp() {
return String(ReadSensors.readSwitch());
//return String(1.8 * bme.readTemperature() + 32);
String readHumi() {
return String(ReadSensors.readSensor());
//String readPres() {
//return String(bme.readPressure() / 100.0F);
void setup(){
// Serial port for debugging purposes
pinMode(Relay1, OUTPUT);
pinMode(Relay2, OUTPUT);
// Setting the ESP as an access point
Serial.print("Setting AP (Access Point)…");
// Remove the password parameter, if you want the AP (Access Point) to be open
WiFi.softAP(ssid, password);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readTemp().c_str());});
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readHumi().c_str());});
//server.on("/pressure", HTTP_GET, [](AsyncWebServerRequest *request){
//request->send_P(200, "text/plain", readPres().c_str());
// Start server
server.begin();
void loop(){
int switchState = ReadSensors.readSwitch();
float sensorValue = ReadSensors.readSensor();
Serial.print("Switch State: ");
Serial.println(switchState);
Serial.print("Sensor Value: ");
Serial.println(sensorValue);
if(switchState == 1 || sensorValue <= 300){
digitalWrite(Relay1, HIGH);
digitalWrite(Relay2, HIGH);
else{
digitalWrite(Relay1, LOW);
digitalWrite(Relay2, LOW);
delay(200);
Please edit your code and add in code tags.
In general, you can't use Arduino functions like pinMode() in constructors, because constructors are executed at the very start of a program, before other important "peripheral initialization" stuff has happened.
I can't tell for sure whether that's what has happened in your code, or not, due to the formatting.
The general "fix" is to have a separate "begin" member function that must be explicitly called from Arduino-level code (eg in setup())
DON'T use pinMode() on a pin used only for analogRead().
You have THREE pin variables but you only initialize two of them. Then you use the third.
