SFM-v1.7 led don't work
Hello,
Having purchased a fingerprint reader (https://fr.aliexpress.com/item/1005001568024522.html)
but i don't have any led
Can you help me?
Schematics:
code:
  This is an example sketch for our optical Fingerprint sensor with LED ring
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit finger detect test");
  // set the data rate for the sensor serial port
  finger.begin(115200);
  delay(5);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
void loop()                     // run over and over again
  // LED fully on
  finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_RED);
  delay(250);
  finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_BLUE);
  delay(250);
  finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_PURPLE);
  delay(250);
  // flash red LED
  finger.LEDcontrol(FINGERPRINT_LED_FLASHING, 25, FINGERPRINT_LED_RED, 10);
  delay(2000);
  // Breathe blue LED till we say to stop
  finger.LEDcontrol(FINGERPRINT_LED_BREATHING, 100, FINGERPRINT_LED_BLUE);
  delay(3000);
  finger.LEDcontrol(FINGERPRINT_LED_GRADUAL_ON, 200, FINGERPRINT_LED_PURPLE);
  delay(2000);
  finger.LEDcontrol(FINGERPRINT_LED_GRADUAL_OFF, 200, FINGERPRINT_LED_PURPLE);
  delay(2000);
Datasheets:
https://x2robotics.ca/uart-capacitive-fingerprint-sensor-kit-sfm-v-1-7
Are you missing any connections? They show a white wire that must always be powered.
I connected pin 3, 4, 5 and 6 but 1 are 2 are not necessary?
I don't know. I'd email the seller. Reading the description says it must be wired but the wiring diagram shows otherwise.
You just said the LED didn't light up, are you also not getting serial data? Maybe you have a bad part???
The seller don't reply and I watched in internet.. The fingerprint work well but not the led
Connect pin 1 and see what happens.
Nothing more
Open it up and test the LED manually or return it.
