Has anyone found a working library compatible with arduino zero for those cheap (ebay) 1.3 inch IIC OLED displays based on the SH1106 chip ?
The Adafruit library supports only the SD1306 chip and while some people tried to modify it to also support the SH1106, I couldn't find a working example so far.
You can try https://github.com/prenticedavid/Adafruit_SH1106_kbv
It is a private library that is not available through the Library Manager. But it works on Arduino Zero / M0 (and most other platforms)
David.
Thanks for the input.
It appears that library supports only SPI displays or am I mistaken....?
No, it supports any valid hardware I2C, any valid hardware SPI, any bit-banged SPI.
It uses exactly the same constructors as Adafruit_SSD1306
It defaults to the standard Wire or SPI
The examples are for the standard Wire
Surely you would just install it. Run the examples. If you have a problem, you would report it in your message.
If you don't want to use this library, you delete the directory.
David.
thanks!
I managed to get it working now!
I have a sample code download on my website if that helps.
Which is the website?
Sorry, I was sure clicking the profile showed the link!!!
Here you go: https://www.bezelsanddisplays.co.uk/
Thanks!
Which is Adafruit_SH1106.h library included in the test code?
