And while stretching, slowly run a lit lighter or some other heat source up and down the bundle once or twice.
The isolation will soften, and set to its new position after cooling down.
After that, your twist is definitive
Takes a little practice to to find the right speed for the run, as to not melt and/or burn the isolation and prevent scorched spots on it.
And for larger bundles, make sure you reach all sides of it to get an even result.
larryd:
When making up a wiring harnesses, a comb can help keep wires parallel.
And if you use lots of cable ties a ty-rap gun is indispensable. Much faster than sidecutters, grips the cut ends so they don't fly all over, and doesn't leave those sharp little ends to scratch the back of your hands on.
I've been watching this thread since becoming aware of it a few few weeks ago; thanks to all for the contributions.
That said, I'm in the middle of rewriting some of my old code with some new found best practices. In doing so, I asked myself if a standard existed for declaring variables; meaning, I could simply look at HOW the variables were written, i.e. GLOBAL_CONSTANT, MyMethod, pMyPointer, etc., to determine the type as opposed to scrolling to where it was initially declared.
As I was writing the question on this thread, I decided to google it and found this.
