It is connected to 5V, ground and 0 analog. I have put the sensor into a box to try and achieve a stable reading.
Why would the returned value still change? When I put my hand in the box the reading does jump - which is great, but how can I achieve a more stable reading when there is no activity?
How much variation in reading are you seeing when in stable condition? Many use 'software filtering' where you take say 8 analog input readings in a row adding them together and then divide by 8 to get a smoother value.
I have now picked up the arduino smoother sketch which seems to run ok. I did have a few lines in my original sketch which would only return exceptional values. How do I add the extra lines?
// Define the number of samples to keep track of. The higher the number,
// the more the readings will be smoothed, but the slower the output will
// respond to the input. Using a constant rather than a normal variable lets
// use this value to determine the size of the readings array.
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int inputPin = A0;
// initialize serial communication with computer:
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
readings[index] = analogRead(inputPin);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.println(average);
This is the detail I need to include -
int value = analogRead(sensePin);
if (value > 400 || value < 300)
Serial.println(value);
Please use [ code] tags for code -> it is the # button
Try this, fixed a small bug too see below.
long total = 0; // the running total
int counter = 0;
int inputPin = A0;
for (int i = 0; i< numReadings; i++) readings[i] = 0;
total -= readings[index];
total += readings[index];
index++;
counter = max(counter, index);
if (index >= numReadings) index = 0;
average = total / counter;
if (average> 400 || average< 300)
Problem with the code was that the first numReadings the average is too low because of the division by numReadings...
