Showing a video on OLED I2C
Hi, I am making a project which shows a video on my OLED (I2C) Screen. I got this to work out, by displaying each frame one by one, but it blinks a lot and it has an FPS of about 1. I need about 30 fps, and also now I am only able to store 18 frames in the code, any more than that is too much for the Arduino. I have an SD card reader as well. Thanks
Start by posting your current sketch using code tags when you do
okok
I2C is not ideally suited to high frame rates.
Try SPI instead
That means you can transfer bits by the I2C clock rate, 1Mbps maximum, or 400kbps or 100kbps. Now divide that rate by the number of pixels on your screen, and by the number of (color) bits per pixel.
Ok maybe 10 FPS is ok, but it don't want that flickering
Do you have the code?
What code? Insert in the formula your I2C clock frequency, color format and pixels on your screen and calculate the maximum frame rate yourself.
Can you explain please??
Obviously I cannot explain it to you. If you provide the required information about your OLED display then I can do the calculation for you:
  • I2C clock frequency
  • bits per pixel
  • pixels on screen
Assuming 100kHz your 128x64 bit display supports 12 fps at most. That's one limit, the other is the speed at which you can provide the pixels. For 12 fps the rate is 100k byte per second.
Your maths are wrong. The Adafruit_SSD1306 library uses 400kHz. The 128x64 buffer requires 1024 bytes. e.g. 1024 * 9 * 2.5us = 23.04ms
So if everything was perfect, you could get 43.4 FPS. 30FPS is achievable.
A monochrome "video" sounds pretty horrible. But an animated line drawing or silhouette can look quite good.
If you store each frame in the buffer format, you simply blit one frame after another. Either straight from PROGMEM or via memcpy_P() to the library SRAM buffer.
You can store 16 frames in a Uno PROGMEM. i.e. a limited animation.
Or store 200 frames in a Mega2560 PROGMEM. i.e. a longer animation.
An ARM or ESP32 can store a lot of frames.
Yes, SPI interface is much faster than the 400kHz I2C interface.
But any hope of transferring frames from SD Card will be fairly slow on Uno or Mega2560.
David.
Not only monochrome (blue) but also binary (dark/bright) without a grayscale.
I am amazed by how good a 16-grayscale can look. I suppose that we are accustomed to black and white photography.
In years to come, a younger generation will have only seen colour photos and colour movies.
All the same, cartoons, line drawings, ... can look ok. Even on a 128x64 pixel display.
David.
Here's a video:
Wooa please explain I'm a kid and Newbie
And this video took about 99% of Arduino Uno's Memory
here's the code
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RESET);
const unsigned char epd_bitmap_ezgif_frame_001 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x20, 0x04, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x60, 0x06, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0x87, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xe3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xe3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-002', 128x64px
const unsigned char epd_bitmap_ezgif_frame_002 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x20, 0x04, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0x87, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0x87, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-003', 128x64px
const unsigned char epd_bitmap_ezgif_frame_003 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0x83, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x83, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80
// 'ezgif-frame-004', 128x64px
const unsigned char epd_bitmap_ezgif_frame_004 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0x83, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0xc1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0xe1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc7, 0xe1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xe1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-005', 128x64px
const unsigned char epd_bitmap_ezgif_frame_005 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x20, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x83, 0xc1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-006', 128x64px
const unsigned char epd_bitmap_ezgif_frame_006 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-007', 128x64px
const unsigned char epd_bitmap_ezgif_frame_007 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x60, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0f, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x1f, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-008', 128x64px
const unsigned char epd_bitmap_ezgif_frame_008 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x20, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x20, 0x04, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x20, 0x06, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x60, 0x06, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x60, 0x07, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-009', 128x64px
const unsigned char epd_bitmap_ezgif_frame_009 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x20, 0x07, 0xcf, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x60, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x60, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0f, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-010', 128x64px
const unsigned char epd_bitmap_ezgif_frame_010 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe8, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x20, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x20, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x83, 0xe1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0f, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x1f, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xf1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xf1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-011', 128x64px
const unsigned char epd_bitmap_ezgif_frame_011 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x1f, 0xdf, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x7f, 0x87, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xff, 0x83, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x07, 0xe0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf9, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0x83, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xc1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0xe1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xfe, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-012', 128x64px
const unsigned char epd_bitmap_ezgif_frame_012 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x1e, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x1e, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x1e, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x3f, 0x80, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x3f, 0x80, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xfe, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x40, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xe1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xfe, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-013', 128x64px
const unsigned char epd_bitmap_ezgif_frame_013 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0xfc, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x7e, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x3e, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x3c, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x3c, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x78, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x78, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf9, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x40, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x40, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xe0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe7, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xfc, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xfe, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-014', 128x64px
const unsigned char epd_bitmap_ezgif_frame_014 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0xf8, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x70, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x71, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0xf1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x80, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xe0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc7, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xef, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0x8f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-015', 128x64px
const unsigned char epd_bitmap_ezgif_frame_015 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0x8f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x8f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x87, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xc7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0xc7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0x80, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0x87, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8f, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xfe, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xff, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0x87, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0xc7, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-016', 128x64px
const unsigned char epd_bitmap_ezgif_frame_016 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xc3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf1, 0x80, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc7, 0xc0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0x9f, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-017', 128x64px
const unsigned char epd_bitmap_ezgif_frame_017 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xe0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xfc, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xf8, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xf0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x80, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// 'ezgif-frame-018', 128x64px
const unsigned char epd_bitmap_ezgif_frame_018 [] PROGMEM = {
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xe0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0xf0, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xf8, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x7f, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x7e, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xfc, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xe0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x83, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
// Array of all bitmaps for convenience. (Total bytes used to store images in PROGMEM = 124800)
const int epd_bitmap_allArray_LEN = 120;
const unsigned char* epd_bitmap_allArray[120] = {
  epd_bitmap_ezgif_frame_003,
  epd_bitmap_ezgif_frame_004,
  epd_bitmap_ezgif_frame_005,
  epd_bitmap_ezgif_frame_006,
  epd_bitmap_ezgif_frame_007,
  epd_bitmap_ezgif_frame_008,
  epd_bitmap_ezgif_frame_009,
  epd_bitmap_ezgif_frame_010,
  epd_bitmap_ezgif_frame_011,
  epd_bitmap_ezgif_frame_012,
  epd_bitmap_ezgif_frame_013,
  epd_bitmap_ezgif_frame_014,
  epd_bitmap_ezgif_frame_015,
  epd_bitmap_ezgif_frame_016,
  epd_bitmap_ezgif_frame_017,
  epd_bitmap_ezgif_frame_018,
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  display.clearDisplay(); display.drawBitmap(0, 0,   epd_bitmap_ezgif_frame_001, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_002, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_003, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_004, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_005, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_006, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_007, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_008, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_009, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_010, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_011, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_012, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_013, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_014, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_015, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_016, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_017, 128, 64, WHITE); display.display();
display.clearDisplay(); display.drawBitmap(0, 0, epd_bitmap_ezgif_frame_018, 128, 64, WHITE); display.display();}
Finally, one part is done, now it's not flickering. I removed the display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
part and now it's great
Here's the video:
https://vimeo.com/646741773
