Am using SIM7600X 4G HAT with Arduino Uno
I follow to manual to Power up the module and it works well, The NET light flashing.
But when I connect to Arduino Uno and use DigitalPin 2 write (High -> Delay500ms -> Low) for "power on pulse" it doesn't work, The NET light still not flashing.
My code:
#include <Waveshare_SIM7600.h>
// Pin definition
int POWERKEY = 2;
char phone_number[] = "XXX"; //Store the phone number you want to call
sim7600.PowerOn(POWERKEY);
sim7600.PhoneCall(phone_number);
code from Waveshare (Waveshare_SIM7600.h):
/**************************Power on Sim7x00**************************/
void Sim7x00::PowerOn(int PowerKey = powerkey){
uint8_t answer = 0;
// checks if the module is started
answer = sendATcommand("AT", "OK", 2000);
if (answer == 0)
Serial.print("Starting up...\n");
pinMode(PowerKey, OUTPUT);
// power on pulse
digitalWrite(PowerKey, HIGH);
digitalWrite(PowerKey, LOW);
// Stuck in below loop because Send AT command and no response ///////
// Becuase NET light not flashing (not connect) //////////////////////
// waits for an answer from the module
while (answer == 0) { // Send AT every two seconds and wait for the answer
delay(5000);
while ((sendATcommand("AT+CREG?", "+CREG: 0,1", 500) || sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0)
