Connect Arduino Uno to SIM 7070G
Hello Guys, i am new here and registered in this forum to ask for help.
I bought an SIM 7070G from Waveshare and an Arduino Uno (Original). I am not able to connect them to get simple At commands through serial monitors done and also cant use any codes to power a simple led.
I wired D10 as Tx to Rxd on the gsm and D11 as Rx to Txd. I connected ground between them.
I can communicate with the GSM through putty that works finde. I just got it working 1 time but after taking it on and of from power it wont work.
I hope i finde some help
I power the Arduino through my pc and die SMs7070G ist connected to a 5v power supply with 2A output
Perhaps if you read the pinned post 'How to get the most from the forum' you will be in a better position to post the information needed by the helpers to look at your problem. Last I checked none of us is a mind reader.
#include <SoftwareSerial.h>
SoftwareSerial simSerial(8, 9); // RX = D9, TX = D8
  Serial.begin(9600);           // Für Monitor
  simSerial.begin(9600);      // SIM7070G Standard-Baudrate
  delay(2000);
  Serial.println("🟢 Teste SIM7070G...");
  simSerial.println("AT");
  if (simSerial.available()) {
    Serial.write(simSerial.read());
  if (Serial.available()) {
    simSerial.write(Serial.read());
This is the code i am using to get a simple ok from the at command but i dont get any answers from the sim7070g
But in your code you used a pins 8 & 9
Sorry that was just for testing other pins. I changed the pins and then the wires.
I got some comunication with the gsm. If i boot it ther serial monitor shows rdy
RDY
+CFUN: 1
+CPIN: READY
SMS Ready
then i can send 1 or maybe 2 times AT. And the Answer is ok. Then no more answers no matter wich at command
What does the documentation say? Perhaps the device is waiting for some other command that you are not sending.
