Hello everyone,
I'm working on a project using the SIM800L module to establish a GPRS connection. Despite exhaustive testing and troubleshooting, I'm unable to attach the module to the network. Here's a detailed summary of what I've done so far:
- Hardware Setup:
- Verified power supply: I'm using a stable 5V supply with sufficient current.
- Antenna: Connected and properly positioned.
- SIM card: Inserted and works perfectly in a mobile phone for data connection.
- Software and AT Commands:
- I'm able to communicate with the module and receive responses.
- AT commands like
AT,AT+CSQ, andAT+CREG?returnOKresponses. - Signal strength is good (
+CSQ: 31,0). - APN settings are correct:
AT+CSTT="java.claro.com.br","claro","claro". - The main issue:
AT+CGATT=1consistently returnsERROR.
- Attempts to Resolve:
- Tried different power supplies and capacitors for stability.
- Ensured correct APN settings matching the carrier.
- Moved to different locations to ensure network availability.
- Verified that the SIM card has an active data plan and isn't locked.
Here are some typical responses from the module:
OK
AT+CREG?
+CREG: 0,0
OK
AT+CGATT=1
ERROR
ERROR
Based on my understanding, the +CREG: 0,0 indicates that the module is not registered to the network. I've tried manually registering with AT+COPS=1,2,"72405", but this also results in an error.
Has anyone faced a similar issue or could provide insights into potential solutions? Any help or suggestions would be greatly appreciated!
Thank you in advance!
Best regards, Milton Tofetti
