Simple I2C Test - not working
I have this simple setup to test I2C communication. Both resistors are 4.7K
The master send a byte every 100ms. I do get 0 for the result of the Wire.endTransmission()
The slave just says 'rec from wire' when the receive event fires. It works - but just one time. If I reset the slave it works one time. Anyone see what I a doing wrong?
Master Code:
#include <Wire.h>
unsigned long currentMillis;//time at the start of each loop
unsigned long lastWireTime = 0UL;
  Wire.begin(); //no address for master
  currentMillis = millis();
  if(currentMillis - lastWireTime > 100UL){
    lastWireTime = currentMillis;
    Wire.beginTransmission(2);
    Wire.write(1);
    byte res = Wire.endTransmission();//sends the buffer - return of 0 = success
Slave Code:
#include <Wire.h>
  Wire.begin(2);
  Wire.onReceive(receiveFromWire);
void receiveFromWire(int numBytes)
  Serial.println("rec from wire");
  while(1 < Wire.available()) {
    byte rec = Wire.read();
    Serial.println("rec");
Try these sketches (tested between UNO and MEGA):
Master Codes:
#include <Wire.h>
 // Serial.print("OK");
  //currentMillis = millis();
  if (millis() - lastWireTime >= 1000UL)
    lastWireTime = millis();
    Wire.write(1);
    if (res != 0)
      Serial.print("I2C Bus Communication Problem...!");
      while (1); //wait for ever
      Serial.println("Slave Found on I2C Bus.");
Slave Codes:
#include <Wire.h>
volatile bool flag = false;
byte rec;
  Wire.begin(2);
  if(flag == true)
    Serial.println(rec);
    flag = false;
  //Serial.println("rec from wire");
  //while (1 < Wire.available()) {
    rec = Wire.read();
    //Serial.println("rec");
    flag = true;
Thank you. Why comment out the println's though - I mean how do you know it's working otherwise? I got it working by changing the while(1 < Wire.available()) to while(Wire.available() > 0)
However, I'm don't really understand why it works now. I realize it's doing the Wire.read() now though, but I didn't know it had to. That's why I had the first println outside of the while loop. Does whatever is sent NEED to be read, otherwise the slave is not freed up?
