I think that this example is a bit awkward, in that is in the digital section but uses force sensitive resistors and analogRead().
It does turn the analog readings into digital decisions with threshold
...but it doesn't seem like a natural part of the digital section.
A 3-button keyboard might be a natural extension of a one-button setup, but the force sensitive resistors and thresholding logic distract from that. Also, with the for loops, it might be a good example in the control section.
Additionally, the comments seem to be confused about "three" sensors versus "to analog in 0 through 5":
Showing all 6 buttons on analog 0 though 5 to ground would help highlight the utility of arrays and for loops for duplicated circuitry.
For instance:
https://wokwi.com/projects/427049511998951425
// https://wokwi.com/projects/427049511998951425
// Using an array of buttons
// Adapted from Arduino Built-in example Keyboard
// https://wokwi.com/projects/409953647477353473
// Code from https://docs.arduino.cc/built-in-examples/digital/toneKeyboard
// Other simulations https://forum.arduino.cc/t/wokwi-simulations-for-arduino-built-in-examples/1304754
Keyboard
Plays a pitch that changes based on a button press
circuit:
- five buttons from ground to A0 to A5
- 8 ohm speaker on digital pin 8
modified 2025-04-01
created 21 Jan 2010
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/toneKeyboard
#include "pitches.h"
const int numberOfKeys = 6;
const int pressedLevel = LOW; // reading of the keys that generates a note
// notes to play, corresponding to the keys:
int notes[] = {
NOTE_D4, NOTE_E4, NOTE_C4, NOTE_C3, NOTE_G3, NOTE_C3
const int buttons[] = {
A0, A1, A2, A3, A4, A5
for (int thisKey = 0; thisKey < numberOfKeys; thisKey++) {
pinMode(buttons[thisKey], INPUT_PULLUP);
// get a sensor reading:
int sensorReading = digitalRead(buttons[thisKey]);
// if the sensor is pressed:
if (sensorReading == pressedLevel) {
// play the note corresponding to this sensor:
tone(8, notes[thisKey], 20);
For someone working through the digital examples, an array of digitalRead() buttons might be an easier next step.
Or if the toneKeyboard example is meant to demonstrate reading force sensitive resistors with analogRead() and tone(), why not make the force sensitive resistors alter the tones, rather than transform it into a digital signal?
For example:
for (int thisSensor = 0; thisSensor < 3; thisSensor++) {
int sensorReading = analogRead(thisSensor);
// if the sensor is pressed hard enough:
if (sensorReading > threshold) {
tone(8, map(sensorReading,threshold,1023,notes[thisSensor],notes[(thisSensor+1)%3]), 20);
