Hi!
I'm trying to send simple messages over the cheap RF 433MHz kit.
Using RadioHead library's examples it works just fine. I can receive the msg in hex numbers.
The thing is when I change the msg. The receiver still receive the msg, but I can't see it in serial monitor.
The example codes are the following:
Transmitter:
// ask_transmitter.pde
// -*- mode: C++ -*-
// Simple example of how to use RadioHead to transmit messages
// with a simple ASK transmitter in a very simple way.
// Implements a simplex (one-way) transmitter with an TX-C1 module
// Tested on Arduino Mega, Duemilanova, Uno, Due, Teensy, ESP-12
#include <RH_ASK.h>
#ifdef RH_HAVE_HARDWARE_SPI
#include <SPI.h> // Not actually used but needed to compile
#endif
RH_ASK driver;
// RH_ASK driver(2000, 4, 5, 0); // ESP8266 or ESP32: do not use pin 11 or 2
// RH_ASK driver(2000, 3, 4, 0); // ATTiny, RX on D3 (pin 2 on attiny85) TX on D4 (pin 3 on attiny85),
#ifdef RH_HAVE_SERIAL
Serial.begin(9600); // Debugging only
#endif
if (!driver.init())
Serial.println("init failed");
#else
#endif
const char *msg = "hello";
driver.send((uint8_t *)msg, strlen(msg));
driver.waitPacketSent();
delay(200);
Receiver:
// ask_receiver.pde
// Simple example of how to use RadioHead to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
#include <RH_ASK.h>
#endif
RH_ASK driver;
#endif
if (!driver.init())
#else
#endif
uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
uint8_t buflen = sizeof(buf);
if (driver.recv(buf, &buflen)) // Non-blocking
int i;
// Message with a good checksum received, dump it.
driver.printBuffer("Got:", buf, buflen);
Does anyone have an idea why it's not working when I change the msg?
