Simple robot finger
I've done a robot finger with a few servos and arduino.
check video here: - YouTube
can you post some more info about this
it looks really cool
the magic is done by a flexible sensor i bought on sparkfun.com
the code is very simple, read the sensor output, and encode to 0-180 degrees.
code and wiring diagram? :slight_smile:
Ok here is the code:
#include <Servo.h>
int smoothAnalog(byte pin, int samples) {
  unsigned long result = 0;
  int tmp;
  for(tmp = 0; tmp < samples; tmp++)
    result += analogRead(pin);
  return result/samples;
float get_range_size(float min, float max) {
  if (max < 0.0)
    return -min + max;
    return max - min;
float value_to_range(int value, float input_min, float input_max, float output_min, float output_max) {
  int tmp;
  float input_range_size, output_range_size;
  input_range_size = get_range_size(input_min, input_max);
  output_range_size = get_range_size(output_min, output_max);
  if (value < input_min)
    value = input_min;
  if (value > input_max)
    value = input_max;
  return (((float)(value-input_min)*output_range_size)/input_range_size) + output_min;
Servo servo;
  servo.attach(2);
  int value;
  value = smoothAnalog(0, 20);
  servo.write((int)value_to_range(value, 700, 850, -90, 90));  // empiric values
  Servo::refresh();
  delay(10);
and the diagram:
thnx :slight_smile:
ops, i forgot to say, that i connected 2 servos at the same control pin, and the video is the result.
u need to add 2 flex sensors that control each part of the finger knuckle.. i hope u know what i mean :slight_smile:
cool idea!
I was just wondering what kind of servo brackets those were and where you got them. thx!
