Here is a video of it so far. http://www.youtube.com/watch?v=LZ-nfHzsGeM
It's an extremely simple platform, just 2 modified nine gram servos I got from Ebay for $2.50 each and a $2 Bluetooth Dongle.
Charley
Here is the Sketch
#include <WiiRemote.h>
#include <Servo.h>#define STEERING_ANGLE_MAX 160
#define STEERING_ANGLE_MIN 20
#define STEERING_ANGLE_CENTER 90
#define STEERING_ANGLE_STEP 5
Servo Left_servo; // create servo object to control a servo
Servo Right_servo;
int deg1;
int a;
WiiRemote wiiremote;void setup()
{wiiremote.init();
Left_servo.attach(6); // attaches the servo on pin 3 & 6 to the servo objects
Right_servo.attach(3);}
void loop(){
wiiremote.task(&myapp);
}void myapp(void) {
int steering_angle = getSteeringAngle();
}int getSteeringAngle(void) {
double rad; // y accel setup
double deg; // y accel setup
double rad2; // X accel setup
double deg2; // X accel setuprad = acos((double) wiiremote.Report.Accel.Y);
deg = rad * 180.0 / PI;rad2 = acos((double) wiiremote.Report.Accel.X);
deg2 = rad2 * 180.0 / PI;
/* clipping */
if (deg2 > STEERING_ANGLE_MAX) { deg2 = STEERING_ANGLE_MAX; }
else if (deg2 < STEERING_ANGLE_MIN) { deg2 = STEERING_ANGLE_MIN; }if (deg > STEERING_ANGLE_MAX) { deg = STEERING_ANGLE_MAX; }
else if (deg < STEERING_ANGLE_MIN) { deg = STEERING_ANGLE_MIN; }if (deg2 >= 85 && deg2 <= 95) { Left_servo.detach(); //eliminates drift at servo center position
Right_servo.detach(); }if (deg2 > 90) { a = deg2 - 90; //Inverts output to reverse right servo
deg1 = 90 - a;
else if (deg2 < 90) {a = 90 - deg2;
deg1 = 90 + a;
}if (deg >= 80 && deg <= 100) {
Left_servo.write(deg2);
Right_servo.write(deg1);
else if (deg < 80) {
Left_servo.write(90);
else if (deg > 100) {
Right_servo.write(90);
