Simulate servo
Given the price of powerful servomotors, is there not an Arduino assembly that simulates the electronic part of the servo ? For a simple DC 18v drill motor.
Example: I buy powerful drill motors and I buy components then build/make myself electronic of the servo to control this simple motor ? (Abt 50 kg.)
Can I use a tiny arduino to simulate a servo ?(+ a DC booster) Are there any diagrams for this ?
Thanks a lot. :0)
Sy.
Do a Google search for wiper motor servo.
Wiper ! Lol ! excellent suggestion ! I watched it's simple but not very accurate. What I would like is rather the electronic scheme, otherwise I can buy a big servomotor and copy the circuit board but that would not be honest. Or buy somewhere a printed circuit all done but I do not know if it exists ... Yes ? No ?
Else thanks a lot.
Sy.
Buy the whole drill and look into the switch. They have 4 or 5 speeds, don't they? Have your Arduino hijack the switch. Add a gearbox and an encoder. Done!
Sylvain_Jeanneton:
Post a link to the specific thing that you watched
In what way is it not sufficiently accurate?
Is a regular hobby servo sufficiently accurate (recognizing that it is not powerful enough) ?
If you fix a regular 10k potentiometer to the output shaft you should have no problem getting behaviour as good as a regular servo.
...R
If you have a motor, motor driver and some sort of encoder then yes you can create a DIY
servomotor using an Arduino. Typically a PID loop library would be used to take the error input (which
might be position error, or might be speed error), and produce the drive value to pass on to the motor
driver board/shield.
A grounding in the basics of control theory is useful for doing this, but you can just experiment and learn
hands-on (just don't start off with a huge motor, its better to have something you can physically interact
with without injury(!))
