I have a prop I am working on using a code I got online from Instructables.
It works very well, however the relay seems to be always active. I have it wired correctly with a 12v battery pos connected to common and NO going to the device.
Ideally the relay should activate for 5 seconds (connected to a 12v battery that powers a motorbike horn). But for some reason the relay is always on.
Can someone please take a look at the code and see what the issue is as I have modified and amended parts, and am hoping to use this prop on Saturday.
Thank you.
ADDITIONAL INFO
I have tested the relay on another project and it works fine. So I believe it is a code problem that I cannot figure out.
// Keypad - Version: Latest
#include <Keypad.h>
#include <Wire.h>
#define I2C_ADDR 0x27
#define LCD_COLUMNS 16
#define LCD_LINES 2
LiquidCrystal_I2C lcd(I2C_ADDR, LCD_COLUMNS, LCD_LINES);
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{ '1', '2', '3', 'a' },
{ '4', '5', '6', 'b' },
{ '7', '8', '9', 'c' },
{ '*', '0', '#', 'd' }
byte rowPins[ROWS] = {8, 7, 6, 5};
byte colPins[COLS] = {12, 11, 10, 9};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char codeInput[8];
byte time[4];
boolean refresh = true; //1 refresh one time...
char password[8];
int key = -1;
char lastKey;
char var;
boolean passwordEnable = false;
//Buttons for lcd shield
char BT_RIGHT = '4';
char BT_UP = 'a';
char BT_DOWN = 'b';
char BT_LEFT = '6';
char BT_SEL = 'd'; // Ok key
char BT_CANCEL = 'c';
char BT_DEFUSER = 'x'; // not implemented
//leds
const int REDLED = 3;
const int GREENLED = 2;
//RELAYPIN
boolean relayEnable = false;
const int RELAYPIN = 13;
const int RELAY_TIME = 5000;
//TIME INTS
int GAMEHOURS = 0;
int GAMEMINUTES = 45;
int BOMBMINUTES = 4;
int ACTIVATESECONDS = 5;
boolean endGame = false;
boolean sdStatus = false; //Search and Destroy game enable used in config
boolean saStatus = false; //same but Sabotage
boolean doStatus = false; //for Demolition
boolean start = true;
boolean defusing;
boolean cancel;
boolean soundEnable = true;
int tonepin = 4;
int alarmTone1 = 700;
int alarmTone2 = 2600;
int activeTone = 1330;
int errorTone = 100;
unsigned long iTime;
unsigned long timeCalcVar;
unsigned long redTime;
unsigned long yellowTime;
unsigned long iZoneTime;
byte team = 0; // 0 = neutral, 1 = yellow team, 2 = red team
int readVcc() {
#if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#elif defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
ADMUX = _BV(MUX5) | _BV(MUX0);
#else
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
#endif
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Start conversion
while (bit_is_set(ADCSRA, ADSC))
; // measuring
uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
uint8_t high = ADCH; // unlocks both
long result = (high << 8) | low;
result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
return result; // Vcc in millivolts
lcd.init();
lcd.backlight();
welcomeLCD();
welcomeSerial();
readVcc();
if (readVcc() >= 3800) {
lcd.setCursor(0, 0);
lcd.print("Voltage is:");
lcd.print(readVcc() / 1000.00);
lcd.print("v");
lcd.setCursor(0, 1);
lcd.print("Voltage Good!");
delay(3000);
if (readVcc() <= 3800) {
lcd.print("voltage is:");
lcd.print("v");
lcd.print("replace battery!");
delay(1000000);
welcomeLCD();
welcomeSerial();
//PinModes
pinMode(GREENLED, OUTPUT);
pinMode(REDLED, OUTPUT);
pinMode(RELAYPIN, OUTPUT);
// CONFIGURE THE BARS OF PROGRESS BAR
byte bar1[8] = {
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
B10000,
byte bar2[8] = {
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
byte bar3[8] = {
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
B11100,
byte bar4[8] = {
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
B11110,
byte bar5[8] = {
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
byte up[8] = {
B00000,
B00100,
B01110,
B11111,
B11111,
B00000,
B00000,
byte down[8] = {
B00000,
B00000,
B11111,
B11111,
B01110,
B00100,
B00000,
lcd.createChar(0, bar1);
lcd.createChar(1, bar2);
lcd.createChar(2, bar3);
lcd.createChar(3, bar4);
lcd.createChar(4, bar5);
lcd.createChar(5, up);
lcd.createChar(6, down);
menuPrincipal();
void keypadEvent(KeypadEvent key) {
switch (keypad.getState()) {
case RELEASED:
switch (key) {
case 'd':
defusing = false;
case 'c':
cancel = false;
case HOLD:
switch (key) {
case 'd':
defusing = true;
case 'c':
cancel = true;
boolean comparePassword() {
for (int i = 0; i < 8; i++) {
if (codeInput[i] != password[i]) return false;
return true;
//Set the password variable
void setCode() {
while (1) {
var = getNumber();
if (var != 'x') {
codeInput[i] = var;
if (i != 0) {
lcd.setCursor(i - 1, 1);
lcd.print("*");
lcd.print(var);
lcd.print(var);
tone(tonepin, 2400, 30);
void setCodeTime() {
timeCalcVar = millis();
while (1) {
if (ACTIVATESECONDS * 1000 + timeCalcVar - millis() <= 100) {
codeInput[i] = 'x';
lcd.setCursor(11, 0);
printTimeDom(ACTIVATESECONDS * 1000 + timeCalcVar - millis(), false);
var = getNumber();
if (var != 'x') {
codeInput[i] = var;
if (i != 0) {
lcd.print("*");
lcd.print(var);
lcd.print(var);
void setPass() {
while (1) {
var = getNumber();
if (var != 'x') {
password[i] = var;
if (i != 0) {
lcd.print("*");
lcd.print(var);
lcd.print(var);
void setNewPass() {
while (1) {
lcd.clear();
lcd.print("Enter New Pass");
setPass();
lcd.clear();
lcd.print("Retype Pass");
setCode();
if (comparePassword()) {
lcd.clear();
lcd.print("Password Set OK!");
delay(2000);
lcd.clear();
lcd.print("ERROR Dont Match!");
if (soundEnable) tone(tonepin, errorTone, 200);
delay(2000);
char getNumber() {
while (1) {
var = keypad.getKey();
if (var) { //
switch (var) {
case 'a':
return 'x';
case 'b':
return 'x';
case 'c':
return 'x';
case 'd':
return 'x';
case '*':
return 'x';
case '#':
return 'x';
default:
return var;
return 'x';
byte getRealNumber() {
while (1) {
var = keypad.waitForKey();
if (var) { //
switch (var) {
case '1':
return 1;
case '2':
return 2;
case '3':
return 3;
case '4':
return 4;
case '5':
return 5;
case '6':
return 6;
case '7':
return 7;
case '8':
return 8;
case '9':
return 9;
case '0':
return 0;
default:
return 11;
return 11;
char menu1[][15] = { "Bomb the Enemy", "Sabotage", "Domination", "Configuration" };
char menu2[][13] = { "Game Config", "Sound Config", "Relay Test", "Auto Test" };
// char *menu1[][] = { "Bomb the Enemy", "Sabotage", "Domination", "Configuration" };
// char *menu2[][] = { "Game Config", "Sound Config", "Relay Test", "Auto Test" };
char GAME_TIME[] = "Game Time:";
char BOMB_TIME[] = "Bomb Time:";
char ZERO_MINUTES[] = "00 minutes";
char ARM_TIME[] = "Arm Time:";
char ZERO_SECS[] = "00 seconds";
char ENABLE_SOUND[] = "Enable Sound?";
char YES_OR_NO[] = "A : Yes B : No";
char ENABLE_RELAYPIN[] = "Enable Relay?";
char ENABLE_CODE[] = "Enable Code Arm?";
char GAME_TIME_TOP[] = "GAME TIME";
char ARMING_BOMB[] = "ARMING BOMB";
char ENTER_CODE[] = "Enter Code";
char CODE_ERROR[] = "Code Error!";
char BOMB_ARMED[] = "BOMB ARMED";
char DETONATION_IN[] = "DETONATION IN";
char DISARMING[] = "DISARMING BOMB";
char DISARM[] = "DISARMING";
char GAME_OVER[] = " GAME OVER! ";
char DEFENDERS_WIN[] = " DEFENDERS WIN ";
char SABOTAGE_FAIL[] = "SABOTAGE FAIL!";
//##################MENUS###############################
void menuPrincipal() { //MAIN MENU
digitalWrite(GREENLED, LOW);
digitalWrite(REDLED, LOW);
saStatus = false;
sdStatus = false;
doStatus = false;
//Draw menu
lcd.clear();
int i = 0;
// HERE YOU CAN ADD MORE ITEMS ON THE MAIN MENU
lcd.print(menu1[i]);
lcd.setCursor(15, 1);
checkArrows(i, 2);
while (1) {
if (var == BT_UP && i > 0) {
i--;
lcd.clear();
checkArrows(i, 2);
delay(50);
if (var == BT_DOWN && i < 2) {
i++;
lcd.clear();
checkArrows(i, 2);
delay(50);
if (var == BT_SEL) {
lcd.clear();
switch (i) {
case 0:
sdStatus = true;
configQuickGame();
startGameCount();
search();
case 1:
saStatus = true;
configQuickGame();
startGameCount();
sabotage();
case 2:
doStatus = true;
configQuickGame();
startGameCount();
domination();
case 3:
config();
void config() {
//Draw menu
lcd.clear();
int i = 0;
lcd.print(menu2[i]);
checkArrows(i, 3);
while (1) {
i--;
lcd.clear();
checkArrows(i, 3);
delay(50);
if (var == BT_DOWN && i < 3) {
i++;
lcd.clear();
checkArrows(i, 3);
delay(50);
if (var == BT_CANCEL) {
menuPrincipal();
lcd.clear();
switch (i) {
case 0:
//gameConfigMenu();
case 1:
//soundConfigMenu();
case 2:
lcd.clear();
lcd.print("RELAYPIN ON!");
digitalWrite(RELAYPIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(4000); // wait for 4 second
lcd.clear();
lcd.print("RELAYPIN OFF!");
digitalWrite(RELAYPIN, LOW);
delay(2000);
config();
void configQuickGame() {
lcd.clear();
//GAME TIME
if (sdStatus || doStatus || saStatus) {
menu1:
lcd.clear();
lcd.print(GAME_TIME);
delay(100);
lcd.print("00:00 hh:mm");
lcd.cursor();
lcd.blink();
byte var2 = 0;
for (int i = 0; i < 4; i++) {
while (1) {
if (i == 2 && var2 == 0) {
lcd.print(":");
var2 = 1;
byte varu = getRealNumber();
if (varu != 11) {
time[i] = varu;
Serial.print(varu);
lcd.print(varu);
lcd.noCursor();
lcd.noBlink();
lcd.setCursor(13, 1);
lcd.print("ok?");
while (1) {
if (var == 'd')
GAMEMINUTES = ((time[0] * 600) + (time[1] * 60) + (time[2] * 10) + (time[3]));
if (var == 'c')
goto menu1;
lcd.clear();
//BOMB TIME
if (sdStatus || saStatus) {
menu2:
lcd.clear();
lcd.print(BOMB_TIME);
delay(100);
lcd.print(ZERO_MINUTES);
lcd.cursor();
lcd.blink();
for (int i = 0; i < 2; i++) {
while (1) {
if (varu != 11) {
time[i] = varu;
lcd.print(varu);
lcd.noCursor();
lcd.noBlink();
lcd.print("ok?");
while (1) {
if (var == 'd') //
BOMBMINUTES = ((time[0] * 10) + (time[1]));
if (var == 'c')
goto menu2;
lcd.clear();
lcd.clear();
//ARMING TIME
menu3:
lcd.clear();
lcd.print(ARM_TIME);
delay(100);
lcd.print(ZERO_SECS);
lcd.cursor();
lcd.blink();
while (1) {
if (varu != 11) {
time[i] = varu;
lcd.print(varu);
lcd.noCursor();
lcd.noBlink();
lcd.print("ok?");
while (1) {
if (var == 'd') // Accept
ACTIVATESECONDS = ((time[0] * 10) + (time[1]));
if (var == 'c') // Cancel or Back Button :')
goto menu3;
lcd.clear();
//sound??
if (sdStatus || saStatus || doStatus) {
lcd.clear();
lcd.print(ENABLE_SOUND);
lcd.print(YES_OR_NO);
while (1) {
if (var == 'a') {
soundEnable = true;
if (var == 'b') {
soundEnable = false;
lcd.clear();
lcd.print(ENABLE_RELAYPIN);
while (1) {
if (var == 'a') {
relayEnable = true;
if (var == 'b') {
lcd.clear();
lcd.print(ENABLE_CODE);
while (1) {
if (var == 'a') {
setNewPass();
passwordEnable = true;
if (var == 'b') {
void search() {
refresh = true;
lcd.clear();
//SETUP INITIAL TIME
int minutes = GAMEMINUTES - 1;
unsigned long iTime = millis(); // initialTime in millisec
unsigned long aTime;
//var='o';
//Starting Game Code
while (1) {
//If you fail disarm.
if (endGame) {
failSplash();
//Code for led blinking
timeCalcVar = (millis() - iTime) % 1000;
if (timeCalcVar >= 0 && timeCalcVar <= 50) digitalWrite(GREENLED, HIGH);
if (timeCalcVar >= 90 && timeCalcVar <= 130) digitalWrite(GREENLED, LOW);
lcd.setCursor(3, 0);
lcd.print(GAME_TIME_TOP);
aTime = millis() - iTime;
lcd.setCursor(3, 1);
//PRINT TIME ON LCD
printTime(minutes, aTime);
//Check If Game End
if (minutes - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) failSplash();
if ('d' == keypad.getKey() && passwordEnable) {
lcd.clear();
lcd.setCursor(2, 0);
lcd.print(ARMING_BOMB);
delay(1000); //a little delay to choose the password
lcd.clear();
lcd.print(ENTER_CODE);
setCodeTime(); // we need to set the comparation variable first it writes on codeInput[]
if (comparePassword()) destroy();
lcd.clear();
lcd.print(CODE_ERROR);
lcd.clear();
//Check If Is Activating
while (defusing && !passwordEnable) {
lcd.clear();
unsigned int percent = 0;
unsigned long xTime = millis(); //start disabling time
while (defusing) {
keypad.getKey();
percent = (millis() - xTime) / (ACTIVATESECONDS * 10);
drawBar(percent);
Serial.println(millis() - xTime);
if ((minutes - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) || minutes - aTime / 60000 > 4000000000) {
endGame = true;
timeCalcVar = (millis() - xTime) % 1000;
if (timeCalcVar >= 0 && timeCalcVar <= 40) {
digitalWrite(REDLED, HIGH);
if (soundEnable) tone(tonepin, alarmTone1, 200);
if (timeCalcVar >= 480 && timeCalcVar <= 520) {
if (soundEnable) tone(tonepin, alarmTone2, 200);
if (percent >= 100) {
destroy(); // jump to the next gamemode
lcd.clear();
void destroy() {
lcd.clear();
lcd.print(BOMB_ARMED);
int minutes = BOMBMINUTES - 1;
int LoudTone = 50;
//MAIN LOOP
while (1) {
if (endGame) {
explodeSplash();
//Led Blink
if (soundEnable) tone(tonepin, activeTone, LoudTone);
if (timeCalcVar >= 180 && timeCalcVar <= 220) {
//Sound
if (timeCalcVar >= 245 && timeCalcVar <= 255 && minutes - aTime / 60000 < 2 && soundEnable) tone(tonepin, activeTone, LoudTone);
if (timeCalcVar >= 495 && timeCalcVar <= 510 && minutes - aTime / 60000 < 4 && soundEnable) tone(tonepin, activeTone, LoudTone);
if (timeCalcVar >= 745 && timeCalcVar <= 760 && minutes - aTime / 60000 < 2 && soundEnable) tone(tonepin, activeTone, LoudTone);
if (minutes - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) < 10) LoudTone = 300;
lcd.setCursor(1, 0);
lcd.print(DETONATION_IN);
//Passed Time
////////HERE ARE THE TWO OPTIONS THAT ENDS THE GAME///////////
if (minutes - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) // Check if game ends
explodeSplash();
//print time
lcd.clear();
lcd.print(DISARMING);
delay(1000); //a little delay to think in the password
lcd.clear();
setCodeTime(); // we need to set the compare variable first
disarmedSplash();
lcd.clear();
lcd.clear();
if (defusing && !passwordEnable) // disarming bomb
lcd.clear();
lcd.print(DISARM);
while (defusing) {
keypad.getKey();
endGame = true;
if (timeCalcVar >= 0 && timeCalcVar <= 20) {
if (timeCalcVar >= 480 && timeCalcVar <= 500) {
unsigned long seconds = (millis() - xTime);
percent = seconds / (ACTIVATESECONDS * 10);
drawBar(percent);
//BOMB DISARMED GAME OVER
if (percent >= 100) disarmedSplash();
lcd.clear();
void sabotage() {
endGame = false;
refresh = true;
lcd.clear();
if (start) {
iTime = millis();
start = false;
while (1) {
if (endGame) {
failSplash();
//PRINT TIME ON LCD
//Check If Game End
if (minutes - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) {
failSplash();
//USED IN PASSWORD GAME
lcd.clear();
delay(10000); //a little delay to choose the password
lcd.clear();
destroySabotage();
lcd.clear();
lcd.clear();
keypad.getKey();
cls();
lcd.clear();
while (defusing) {
keypad.getKey();
//check if game time runs out during the disabling
if ((minutes - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) || minutes - aTime / 60000 > 4000000000)endGame = true;
unsigned long seconds = millis() - xTime;
percent = (seconds) / (ACTIVATESECONDS * 10);
drawBar(percent);
destroySabotage(); // jump to the next game mode
cls();
void destroySabotage() {
endGame = false;
lcd.clear();
int LoudTone = 50;
//MAIN LOOP
while (1) {
if (endGame) {
explodeSplash();
//Led Blink
//Sound
//Passed Time
////////TWO OPTIONS THAT ENDS THE GAME///////////
////TIME PASSED AND THE BOMB EXPLODES
failSplash();
//print time
//// SECOND OPTION: DISARMED BOMB
//IF IS A PASSWORD GAME
lcd.clear();
lcd.clear();
setCodeTime(); //compare variable first
//then compare
sabotage();
lcd.clear();
cls();
lcd.clear();
lcd.print(DISARM);
while (defusing) {
keypad.getKey();
endGame = true;
drawBar(percent);
//BOMB DISARMED RETURN TO SABOTAGE
if (percent >= 100)
lcd.clear();
lcd.print("Bomb Disarmed");
sabotage();
lcd.clear();
void domination() {
boolean showGameTime = true;
unsigned long a;
team = 0;
iZoneTime = 0;
aTime = 0;
redTime = 0;
yellowTime = 0;
int LoudTone = 50;
a = millis();
while (1)
if (endGame) {
gameOver();
keypad.getKey();
if (team == 1)digitalWrite(GREENLED, HIGH);
if (team == 2)digitalWrite(REDLED, HIGH);
if (timeCalcVar >= 50 && timeCalcVar <= 100)
if (team == 1)digitalWrite(GREENLED, LOW);
if (team == 2)digitalWrite(REDLED, LOW);
if (timeCalcVar >= 0 && timeCalcVar <= 40 && soundEnable)tone(tonepin, activeTone, LoudTone);
if (timeCalcVar >= 245 && timeCalcVar <= 255 && minutes - aTime / 60000 < 2 && soundEnable)tone(tonepin, activeTone, LoudTone);
if (timeCalcVar >= 495 && timeCalcVar <= 510 && minutes - aTime / 60000 < 4 && soundEnable)tone(tonepin, activeTone, LoudTone);
if (timeCalcVar >= 745 && timeCalcVar <= 760 && minutes - aTime / 60000 < 2 && soundEnable)tone(tonepin, activeTone, LoudTone);
//Help to count 3 secs
if (a + 2000 < millis()) {
a = millis();
showGameTime = !showGameTime;
cls();
if (showGameTime) { //THE SECOND IS /2
lcd.print("GAME TIME");
else if (!showGameTime) {
if (team == 0)lcd.print("NEUTRAL ZONE");
if (team == 1)lcd.print(" YELLOW ZONE");
if (team == 2)lcd.print(" RED ZONE");
if (team > 0) {
printTimeDom(millis() - iZoneTime, true);
//Check If Game End
gameOver();
//Check If IS neutral
while ((defusing || cancel) && team > 0)
cls();
if (team > 0)lcd.print("NEUTRALIZING...");
while (defusing || cancel)
endGame = true;
keypad.getKey();
if ( timeCalcVar >= 0 && timeCalcVar <= 20)
if (soundEnable)tone(tonepin, alarmTone1, 200);
if (soundEnable)tone(tonepin, alarmTone2, 200);
drawBar(percent);
if (percent >= 100)
if (team == 1) {
yellowTime += millis() - iZoneTime;
iZoneTime = 0;
if (team == 2) {
redTime += millis() - iZoneTime;
iZoneTime = 0;
team = 0;
cls();
//Capturing red
while (defusing && team == 0 )
cls();
if (team == 0)lcd.print(" CAPTURING ZONE");
while (defusing)
keypad.getKey();
endGame = true;
drawBar(percent);
if (percent >= 100)
team = 2;
iZoneTime = millis();
cls();
//getting to yellow zone
while (cancel && team == 0 )
cls();
while (cancel)
keypad.getKey();
endGame = true;
drawBar(percent);
if (percent >= 100)
team = 1;
cls();
void gameOver() {
if (team == 1)yellowTime += millis() - iZoneTime;
if (team == 2)redTime += millis() - iZoneTime;
while (!defusing) {
keypad.getKey();
if (defusing) {
keypad.getKey();
lcd.clear();
lcd.print("TIME OVER!");
//check who team win the base
if (yellowTime > redTime) {
//greenteam wins
lcd.print(" YELLOW TEAM WINS");
else {
//redteam wins
lcd.print(" RED TEAM WINS");
delay(3000);
keypad.getKey();
if (defusing) {
keypad.getKey();
cls();
lcd.print("Red Time:");
lcd.setCursor(5, 1);
printTimeDom(redTime, false);
delay(3000);
keypad.getKey();
if (defusing) {
cls();
lcd.print("Yellow Time:");
printTimeDom(yellowTime, false);
delay(3000);
keypad.getKey();
if (defusing) {
keypad.getKey();
cls();
delay(100);
lcd.print("Play Again?");
lcd.print("A : Yes B : No");
while (1)
if (var == 'a' ) {
cls();
domination();
if (var == 'b' ) {
menuPrincipal();
void explodeSplash() {
lcd.clear();
delay(100);
endGame = false;
lcd.print("TERRORISTS WIN");
lcd.setCursor(4, 1);
lcd.print("GAME OVER");
for (int i = 200; i > 0; i--) // this is the ultra hi definition explosion sound
tone(tonepin, i);
delay(20);
noTone(tonepin);
if (relayEnable) {
activateRelay();
delay(5000);
lcd.clear();
//end code
while (1) {
if (var == 'a') {
if (sdStatus) {
startGameCount();
search();
if (saStatus) {
saStatus = true;
startGameCount();
start = true;
sabotage();
if (var == 'b') {
menuPrincipal();
void failSplash() {
lcd.clear();
delay(100);
endGame = false;
lcd.print("TIME OUT");
tone(tonepin, i);
delay(20);
noTone(tonepin);
if (relayEnable) {
activateRelay();
delay(5000);
lcd.clear();
//end code
while (1) {
if (var == 'a') {
if (sdStatus) {
startGameCount();
search();
if (saStatus) {
saStatus = true;
startGameCount();
start = true;
sabotage();
if (var == 'b') {
menuPrincipal();
void disarmedSplash() {
endGame = false;
lcd.clear();
lcd.print("BOMB DISARMED");
delay(5000);
//end code
lcd.clear();
while (1) {
if (var == 'a') {
if (sdStatus) {
startGameCount();
search();
if (saStatus) {
saStatus = true;
startGameCount();
start = true;
sabotage();
if (var == 'b') {
menuPrincipal();
void drawBar(byte percent) {
//TODO: Optimize this code
int box = (8 * percent) / 10;
while (box >= 5) {
if (box >= 5) {
lcd.write(4);
box -= 5;
switch (box) {
case 0:
case 1:
lcd.write((uint8_t)0);
case 2:
lcd.write(1);
case 3:
lcd.write(2);
case 4:
lcd.write(3);
void cls() {
lcd.clear();
void printTime(unsigned long minutes, unsigned long aTiempo) {
timeCalcVar = minutes - aTiempo / 60000;
//Hours
if (timeCalcVar / 60 == 0 && refresh) {
lcd.clear();
refresh = false;
//delay(100);
Serial.println("!!!!");
if (timeCalcVar / 60 >= 1) {
if (timeCalcVar / 60 < 10) {
lcd.setCursor(2, 1);
lcd.print("0");
lcd.print(timeCalcVar / 60);
lcd.print(":");
//minutes
if (timeCalcVar % 60 < 10) {
lcd.print("0");
lcd.print(timeCalcVar % 60);
lcd.print(":");
//seconds
timeCalcVar = aTiempo / 1000;
if (59 - (timeCalcVar % 60) < 10) {
lcd.print("0");
lcd.print(59 - (timeCalcVar % 60));
lcd.print(":");
lcd.print(999 - (millis() % 1000));
void printTimeDom(unsigned long aTiempo, boolean showMillis) {
//minutes
if ((aTiempo / 60000) < 10) {
lcd.print("0");
lcd.print(aTiempo / 60000);
lcd.print(":");
//seconds
if (((aTiempo / 1000) % 60) < 10) {
lcd.print("0");
lcd.print((aTiempo / 1000) % 60);
if (showMillis) {
lcd.print(":");
lcd.print(999 - millis() % 1000);
void startGameCount() {
lcd.clear();
lcd.print("Ready to Begin");
lcd.print("Push ANY Button");
lcd.clear();
lcd.print("Starting Game");
for (int i = 5; i > 0; i--) {
tone(tonepin, 2000, 100);
lcd.print("in ");
lcd.print(i);
lcd.clear();
void checkArrows(byte i, byte maxx) {
if (i == 0) {
lcd.write(6);
if (i == maxx) {
lcd.setCursor(15, 0);
lcd.write(5);
if (i > 0 && i < maxx) {
lcd.write(6);
lcd.write(5);
void activateRelay() {
delay(RELAY_TIME);
void destroysabotage() {
lcd.clear();
lcd.print("Sabotage");
void destroydomination() {
lcd.clear();
lcd.print("Domination");
void welcomeSerial() {
Serial.println("RIGHT = 4");
Serial.println("UP = A");
Serial.println("DOWN = B");
Serial.println("LEFT = 6");
Serial.println("SELECT = D"); // OK key
Serial.println("CANCEL = C");
Serial.println("DEFUSE = X"); // not implemented
void welcomeLCD() {
lcd.print("AIRSOFT ONLINE JP");
lcd.print(" AIRSOFT BOMB");
keypad.setHoldTime(50);
keypad.setDebounceTime(50);
keypad.addEventListener(keypadEvent);
