Code Help for Buzzer Timing & relay
I have made a "Bomb Game" for airsoft and I want to have the detonation relay link to other items on a separate power that only activates on the "failsplash" but not sure how to wire it as I have not used a single channel relay before.
But the main issue is that when the timer is counting, I want the tonepin (buzzer) to beep every second, however it just makes inconsistent and weird tones. I am not sure what is wrong.
I have attached the code below.
Thank you
#include <Wire.h>
#include <Keypad.h>
// #include <LiquidCrystal.h>
 Arduino Bomb Pro
 The circuit:
 * More info at : http://airsoft-online-japan.com/
 If you need some help mail me to airsoftonlinejapan@gmail.com
 created 25,Aug, 2023
 Modified 26, AUG 2023
 by Ben (Airsoft Online Japan)
// LiquidCrystal lcd(7, 6, 5, 4, 3, 2); // SPI connection
// LiquidCrystal_I2C lcd(0x38,16,2); // old I2C
#define I2C_ADDR 0x27  // new address... 0x38 does not work
#define LCD_COLUMNS 16
#define LCD_LINES 2
LiquidCrystal_I2C lcd(I2C_ADDR, LCD_COLUMNS, LCD_LINES);
const byte ROWS = 4;  //four rows
const byte COLS = 4;  //three columns
char keys[ROWS][COLS] = {
  { '1', '2', '3', 'a' },
  { '4', '5', '6', 'b' },
  { '7', '8', '9', 'c' },
  { '*', '0', '#', 'd' }
byte rowPins[ROWS] = {
  // 12, 13, A5, A4 // old pins
  12, 11, 10, 9  // new pins
};               //connect to the row pinouts of the keypad
byte colPins[COLS] = {
  // A3, A2, A1, A0 // old pins
  8, 7, 6, 5  // new pins
};            //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char codeInput[8];
byte time[4];
boolean refresh = true;  //1 refresh one time...
char password[8];
int key = -1;
char lastKey;
char var;
boolean passwordEnable = false;
//Buttons for lcd shield
char BT_RIGHT = '4';
char BT_UP = 'a';
char BT_DOWN = 'b';
char BT_LEFT = '6';
char BT_SEL = 'd';  // Ok key
char BT_CANCEL = 'c';
char BT_DEFUSER = 'x';  // not implemented
//leds
const int REDLED = 11;
const int GREENLED = 10;
const int BLUELED = 14;
//RELAYPIN
boolean relayEnable = false;
const int RELAYPIN = 13;
//IS VERY IMPORTANT THAT YOU TEST THIS TIME. BY DEFAULT IS IN 1 SEC. THAT IS NOT TOO MUCH. SO TEST IT!
const int RELAY_TIME = 5000;
//TIME INTS
int GAMEHOURS = 0;
int GAMEMINUTES = 45;
int BOMBMINUTES = 4;
int ACTIVATESECONDS = 5;
boolean endGame = false;
boolean sdStatus = false;  //Search and Destroy game enable used in config
boolean saStatus = false;  //same but Sabotage
boolean doStatus = false;  //for Demolition
boolean start = true;
boolean defusing;
boolean cancelando;
// SOUND TONES
boolean soundEnable = true;
int tonepin = 8;  // Pin 13 for the sound
int alarmTone1 = 700;
int alarmTone2 = 2600;
int activeTone = 1330;
int errorTone = 100;
unsigned long iTime;
unsigned long timeCalcVar;
unsigned long redTime;
unsigned long yellowTime;
unsigned long iZoneTime;  //initial time for zone
byte team = 0;            // 0 = neutral, 1 = yellow team, 2 = red team
  // lcd.begin(16, 2); // SPI
  lcd.init();
  lcd.backlight();
  welcomeLCD();
  welcomeSerial();
  //PinModes
  pinMode(GREENLED, OUTPUT);
  pinMode(REDLED, OUTPUT);
  pinMode(RELAYPIN, OUTPUT);
  // CONFIGURE THE BARS OF PROGRESS BAR
  byte bar1[8] = {
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
  byte bar2[8] = {
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
  byte bar3[8] = {
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
  byte bar4[8] = {
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
  byte bar5[8] = {
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
  byte up[8] = {
    B00000,
    B00100,
    B01110,
    B11111,
    B11111,
    B00000,
    B00000,
  byte down[8] = {
    B00000,
    B00000,
    B11111,
    B11111,
    B01110,
    B00100,
    B00000,
  lcd.createChar(0, bar1);
  lcd.createChar(1, bar2);
  lcd.createChar(2, bar3);
  lcd.createChar(3, bar4);
  lcd.createChar(4, bar5);
  lcd.createChar(5, up);
  lcd.createChar(6, down);
  menuPrincipal();
void keypadEvent(KeypadEvent key) {
  switch (keypad.getState()) {
    case RELEASED:
      switch (key) {
        case 'd':
          defusing = false;
        case 'c':
          cancelando = false;
    case HOLD:
      switch (key) {
        case 'd':
          defusing = true;
        case 'c':
          cancelando = true;
//This fuction compare codeInput[8] and password[8] variables
boolean comparePassword() {
  for (int i = 0; i < 8; i++) {
    if (codeInput[i] != password[i]) return false;
  return true;
//Set the password variable
void setCode() {
  lcd.setCursor(0, 1);
    while (1) {
      var = getNumber();
      if (var != 'x') {
        codeInput[i] = var;
        if (i != 0) {
          lcd.setCursor(i - 1, 1);
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
        tone(tonepin, 2400, 30);
void setCodeTime() {
  timeCalcVar = millis();
    while (1) {
      if (ACTIVATESECONDS * 1000 + timeCalcVar - millis() <= 100) {
        codeInput[i] = 'x';
      lcd.setCursor(11, 0);
      printTimeDom(ACTIVATESECONDS * 1000 + timeCalcVar - millis(), false);
      var = getNumber();
      if (var != 'x') {
        codeInput[i] = var;
        if (i != 0) {
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setPass() {
    while (1) {
      var = getNumber();
      if (var != 'x') {
        password[i] = var;
        if (i != 0) {
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setNewPass() {
  while (1) {
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Enter New Pass");
    setPass();
    lcd.clear();
    lcd.print("Retype Pass");
    setCode();
    if (comparePassword()) {
      lcd.clear();
      lcd.print("Password Set OK!");
      delay(2000);
      lcd.clear();
      lcd.print("ERROR Dont Match!");
      if (soundEnable) tone(tonepin, errorTone, 200);
      delay(2000);
//Whait until a button is pressed is is a number return the number 'char' if not return x
char getNumber() {
  while (1) {
    var = keypad.getKey();
    if (var) {  //
      switch (var) {
        case 'a':
          return 'x';
        case 'b':
          return 'x';
        case 'c':
          return 'x';
        case 'd':
          return 'x';
        case '*':
          return 'x';
        case '#':
          return 'x';
        default:
          return var;
    return 'x';
byte getRealNumber() {
  while (1) {
    var = keypad.waitForKey();
    if (var) {  //
      switch (var) {
        case '1':
          return 1;
        case '2':
          return 2;
        case '3':
          return 3;
        case '4':
          return 4;
        case '5':
          return 5;
        case '6':
          return 6;
        case '7':
          return 7;
        case '8':
          return 8;
        case '9':
          return 9;
        case '0':
          return 0;
        default:
          return 11;
    return 11;
char menu1[][15] = { "Search&Destroy", "Sabotage", "Domination", "Configuration" };
char menu2[][13] = { "Game Config", "Sound Config", "Relay Test", "Auto Test" };
// char *menu1[][] = { "Search&Destroy", "Sabotage", "Domination", "Configuration" };
// char *menu2[][] = { "Game Config", "Sound Config", "Relay Test", "Auto Test" };
char GAME_TIME[] = "Game Time:";
char BOMB_TIME[] = "Bomb Time:";
char ZERO_MINUTES[] = "00 minutes";
char ARM_TIME[] = "Arm Time:";
char ZERO_SECS[] = "00 seconds";
char ENABLE_SOUND[] = "Enable Sound?";
char YES_OR_NO[] = "A : Yes B : No";
char ENABLE_RELAYPIN[] = "Enable Relay?";
char ENABLE_CODE[] = "Enable Code Arm?";
char GAME_TIME_TOP[] = "GAME TIME";
char ARMING_BOMB[] = "ARMING BOMB";
char ENTER_CODE[] = "Enter Code";
char CODE_ERROR[] = "Code Error!";
char BOMB_ARMED[] = "BOMB ARMED";
char DETONATION_IN[] = "DETONATION IN";
char DISARMING[] = "DISARMING BOMB";
char DISARM[] = "DISARMING";
char GAME_OVER[] = " GAME OVER! ";
char DEFENDERS_WIN[] = " DEFENDERS WIN ";
char SABOTAGE_FAIL[] = "SABOTAGE FAIL!";
//void getConfig(){
////Check first time
//if (EEPROM.read(0)!= 1){
////write default config values
////RELAY_TIME = EEPROM.read(1) * 1000 ;
//##################MENUS###############################
void menuPrincipal() {  //MAIN MENU
  digitalWrite(GREENLED, LOW);
  digitalWrite(REDLED, LOW);
  //   if we start a new game from another we need to restart propertly this variables
  saStatus = false;
  sdStatus = false;
  doStatus = false;
  //Draw menu
  lcd.clear();  //clear lcd and set cursor to 0,0
  int i = 0;
  // HERE YOU CAN ADD MORE ITEMS ON THE MAIN MENU
  lcd.print(menu1[i]);
  lcd.setCursor(15, 1);
  checkArrows(i, 2);
  while (1) {
    if (var == BT_UP && i > 0) {
      i--;
      lcd.clear();
      checkArrows(i, 2);
      delay(50);
    if (var == BT_DOWN && i < 2) {
      i++;
      lcd.clear();
      checkArrows(i, 2);
      delay(50);
    if (var == BT_SEL) {
      lcd.clear();
      switch (i) {
        case 0:
          sdStatus = true;
          configQuickGame();
          startGameCount();
          search();
        case 1:
          saStatus = true;
          configQuickGame();
          startGameCount();
          sabotage();
        case 2:
          doStatus = true;
          configQuickGame();
          startGameCount();
          domination();
        case 3:
          config();
void config() {
  //Draw menu
  lcd.clear();
  int i = 0;
  lcd.print(menu2[i]);
  checkArrows(i, 3);
  while (1) {
      i--;
      lcd.clear();
      checkArrows(i, 3);
      delay(50);
    if (var == BT_DOWN && i < 3) {
      i++;
      lcd.clear();
      checkArrows(i, 3);
      delay(50);
    if (var == BT_CANCEL) {
      menuPrincipal();
      lcd.clear();
      switch (i) {
        case 0:
          //gameConfigMenu();
        case 1:
          //soundConfigMenu();
        case 2:
          lcd.clear();
          lcd.print("RELAYPIN ON!");
          digitalWrite(RELAYPIN, HIGH);  // turn the LED on (HIGH is the voltage level)
          delay(4000);                   // wait for 4 second
          lcd.clear();
          lcd.print("RELAYPIN OFF!");
          digitalWrite(RELAYPIN, LOW);
          delay(2000);
          config();
void configQuickGame() {
  lcd.clear();
  //GAME TIME
  if (sdStatus || doStatus || saStatus) {
menu1:
    lcd.clear();
    lcd.print(GAME_TIME);
    delay(100);
    lcd.print("00:00 hh:mm");
    lcd.cursor();
    lcd.blink();
    byte var2 = 0;
    for (int i = 0; i < 4; i++) {
      while (1) {
        if (i == 2 && var2 == 0) {
          lcd.print(":");
          var2 = 1;
        byte varu = getRealNumber();
        if (varu != 11) {
          time[i] = varu;
          Serial.print(varu);
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.setCursor(13, 1);
    lcd.print("ok?");
    //zona donde pasamos los items a
    //redibujar
    while (1) {
      if (var == 'd')  // Accept
        GAMEMINUTES = ((time[0] * 600) + (time[1] * 60) + (time[2] * 10) + (time[3]));
      if (var == 'c')  // Cancel or Back Button :')
        goto menu1;
    lcd.clear();
  //BOMB TIME
  if (sdStatus || saStatus) {
menu2:
    lcd.clear();
    lcd.print(BOMB_TIME);
    delay(100);
    lcd.print(ZERO_MINUTES);
    lcd.cursor();
    lcd.blink();
    for (int i = 0; i < 2; i++) {
      while (1) {
        if (varu != 11) {
          time[i] = varu;
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.print("ok?");
    //redibujar
    while (1) {
      if (var == 'd')  //
        BOMBMINUTES = ((time[0] * 10) + (time[1]));
        goto menu2;
    lcd.clear();
  lcd.clear();
  //ARMING TIME
menu3:
    lcd.clear();
    lcd.print(ARM_TIME);
    delay(100);
    lcd.print(ZERO_SECS);
    lcd.cursor();
    lcd.blink();
      while (1) {
        if (varu != 11) {
          time[i] = varu;
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.print("ok?");
    //redibujar
    while (1) {
        ACTIVATESECONDS = ((time[0] * 10) + (time[1]));
        goto menu3;
    lcd.clear();
  //sound??
  if (sdStatus || saStatus || doStatus) {
    lcd.clear();
    lcd.print(ENABLE_SOUND);
    lcd.print(YES_OR_NO);
    while (1) {
      if (var == 'a') {
        soundEnable = true;
      if (var == 'b') {
        soundEnable = false;
  //Activate RELAY at Terrorist game ends??? Boom!
    lcd.clear();
    lcd.print(ENABLE_RELAYPIN);
    while (1) {
      if (var == 'a') {
        relayEnable = true;
      if (var == 'b') {
  //You Want a password enable-disable game?
    lcd.clear();
    lcd.print(ENABLE_CODE);
    while (1) {
      if (var == 'a') {
        setNewPass();
        passwordEnable = true;
      if (var == 'b') {
  //Continue the game :D
void search() {
  refresh = true;
  lcd.clear();
  //SETUP INITIAL TIME
  int minutos = GAMEMINUTES - 1;
  unsigned long iTime = millis();  //  initialTime in millisec
  unsigned long aTime;
  //var='o';
  //Starting Game Code
  while (1) {  // this is the important code, is a little messy but works good.
    //If you fail disarm.
    if (endGame) {
      failSplash();
    //Code for led blinking
    timeCalcVar = (millis() - iTime) % 1000;
    if (timeCalcVar >= 0 && timeCalcVar <= 50) digitalWrite(GREENLED, HIGH);
    if (timeCalcVar >= 90 && timeCalcVar <= 130) digitalWrite(GREENLED, LOW);
    lcd.setCursor(3, 0);
    lcd.print(GAME_TIME_TOP);
    aTime = millis() - iTime;
    lcd.setCursor(3, 1);
    //PRINT TIME ON LCD
    printTime(minutos, aTime);
    //###########################CHECKINGS##################
    //Check If Game End
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) failSplash();
    //Serial.println(keypad.getKey());
    //USED IN PASSWORD GAME
    if ('d' == keypad.getKey() && passwordEnable) {
      lcd.clear();
      lcd.setCursor(2, 0);
      lcd.print(ARMING_BOMB);
      delay(1000);  //a little delay to choose the password
      lcd.clear();
      lcd.print(ENTER_CODE);
      setCodeTime();  // we need to set the comparation variable first it writes on codeInput[]
      //then compare :D
      if (comparePassword()) destroy();
      lcd.clear();
      lcd.print(CODE_ERROR);
      lcd.clear();
    //Check If Is Activating
    while (defusing && !passwordEnable) {
      lcd.clear();
      unsigned int percent = 0;
      unsigned long xTime = millis();  //start disabling time
      while (defusing) {
        keypad.getKey();
        percent = (millis() - xTime) / (ACTIVATESECONDS * 10);
        drawBar(percent);
        //check if game time runs out during the disabling
        Serial.println(millis() - xTime);
        if ((minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) || minutos - aTime / 60000 > 4000000000) {
          endGame = true;
        timeCalcVar = (millis() - xTime) % 1000;
        if (timeCalcVar >= 0 && timeCalcVar <= 40) {
          digitalWrite(REDLED, HIGH);
          if (soundEnable) tone(tonepin, alarmTone1, 200);
        if (timeCalcVar >= 480 && timeCalcVar <= 520) {
          if (soundEnable) tone(tonepin, alarmTone2, 200);
        if (percent >= 100) {
          destroy();  // jump to the next gamemode
      lcd.clear();
void destroy() {
  lcd.clear();
  lcd.print(BOMB_ARMED);
  int minutos = BOMBMINUTES - 1;
  int largoTono = 50;
  //MAIN LOOP
  while (1) {
    if (endGame) {
      explodeSplash();
    //Led Blink
      if (soundEnable) tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 180 && timeCalcVar <= 220) {
    //Sound
    if (timeCalcVar >= 245 && timeCalcVar <= 255 && minutos - aTime / 60000 < 2 && soundEnable) tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 495 && timeCalcVar <= 510 && minutos - aTime / 60000 < 4 && soundEnable) tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 745 && timeCalcVar <= 760 && minutos - aTime / 60000 < 2 && soundEnable) tone(tonepin, activeTone, largoTono);
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) < 10) largoTono = 300;
    lcd.setCursor(1, 0);
    lcd.print(DETONATION_IN);
    //Passed Time
    ////////HERE ARE THE TWO OPTIONS THAT ENDS THE GAME///////////
    ////TIME PASED AWAY AND THE BOMB EXPLODES
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0)  // Check if game ends
      explodeSplash();
    //print time
    //// SECOND OPTION: YOU PRESS DISARMING BUTTON
    //IF IS A PASSWORD GAME
      lcd.clear();
      lcd.print(DISARMING);
      delay(1000);  //a little delay to think in the password
      lcd.clear();
      setCodeTime();  // we need to set the compare variable first
      //then compare :D
        disarmedSplash();
      lcd.clear();
      lcd.clear();
    if (defusing && !passwordEnable)  // disarming bomb
      lcd.clear();
      lcd.print(DISARM);
      while (defusing) {
        keypad.getKey();
          endGame = true;
        if (timeCalcVar >= 0 && timeCalcVar <= 20) {
        if (timeCalcVar >= 480 && timeCalcVar <= 500) {
        unsigned long seconds = (millis() - xTime);
        percent = seconds / (ACTIVATESECONDS * 10);
        drawBar(percent);
        //BOMB DISARMED GAME OVER
        if (percent >= 100) disarmedSplash();
      lcd.clear();
void explodeSplash() {
  lcd.clear();
  delay(100);
  endGame = false;
  lcd.print("TERRORISTS WIN");
  lcd.setCursor(4, 1);
  lcd.print("GAME OVER");
  for (int i = 200; i > 0; i--)  // this is the ultra hi definition explosion sound xD
    tone(tonepin, i);
    delay(20);
  noTone(tonepin);
  if (relayEnable) {
    activateRelay();
  delay(5000);
  lcd.clear();
  //end code
  lcd.print("Play Again?");
  lcd.print("A : Yes B : No");
  while (1) {
    if (var == 'a') {
      //We have two options, search & destroy and sabotage play again options so!
      if (sdStatus) {
        startGameCount();
        search();
      if (saStatus) {
        saStatus = true;
        startGameCount();
        start = true;  //to set iTime to actual millis() :D
        sabotage();
    if (var == 'b') {
      menuPrincipal();
void failSplash() {
  lcd.clear();
  delay(100);
  endGame = false;
  lcd.print("TIME OUT");
    tone(tonepin, i);
    delay(20);
  noTone(tonepin);
  if (relayEnable) {
    activateRelay();
  delay(5000);
  lcd.clear();
  //end code
  while (1) {
    if (var == 'a') {
      //We have two options, search & destroy and sabotaje play again options so!
      if (sdStatus) {
        startGameCount();
        search();
      if (saStatus) {
        saStatus = true;
        startGameCount();
        sabotage();
    if (var == 'b') {
      menuPrincipal();
void disarmedSplash() {
  endGame = false;
    lcd.clear();
    lcd.print("BOMB DISARMED");
    lcd.print("MILITARY WINS");
    delay(5000);
  //end code
  lcd.clear();
  while (1) {
    if (var == 'a') {
      if (sdStatus) {
        startGameCount();
        search();
      if (saStatus) {
        saStatus = true;
        startGameCount();
        sabotage();
    if (var == 'b') {
      menuPrincipal();
void drawBar(byte porcent) {
  //TODO: Optimize this code
  int box = (8 * porcent) / 10;
  while (box >= 5) {
    if (box >= 5) {
      lcd.write(4);
      box -= 5;
  switch (box) {
    case 0:
    case 1:
      lcd.write((uint8_t)0);
    case 2:
      lcd.write(1);
    case 3:
      lcd.write(2);
    case 4:
      lcd.write(3);
void cls() {
  lcd.clear();
void printTime(unsigned long minutos, unsigned long aTiempo) {
  timeCalcVar = minutos - aTiempo / 60000;
  //Hours
  if (timeCalcVar / 60 == 0 && refresh) {
    lcd.clear();
    refresh = false;
    //delay(100);
    Serial.println("!!!!");
  if (timeCalcVar / 60 >= 1) {
    if (timeCalcVar / 60 < 10) {
      lcd.setCursor(2, 1);
      lcd.print("0");
      lcd.print(timeCalcVar / 60);
    lcd.print(":");
  //minutes
  if (timeCalcVar % 60 < 10) {
    lcd.print("0");
    lcd.print(timeCalcVar % 60);
  lcd.print(":");
  //seconds
  timeCalcVar = aTiempo / 1000;
  if (59 - (timeCalcVar % 60) < 10) {
    lcd.print("0");
    lcd.print(59 - (timeCalcVar % 60));
  lcd.print(":");
  //this not mach with real time, is just a effect, it says 999 because millis%1000 sometimes give 0 LOL
  lcd.print(999 - (millis() % 1000));
void printTimeDom(unsigned long aTiempo, boolean showMillis) {
  //minutes
  if ((aTiempo / 60000) < 10) {
    lcd.print("0");
    lcd.print(aTiempo / 60000);
  lcd.print(":");
  //seconds
  if (((aTiempo / 1000) % 60) < 10) {
    lcd.print("0");
    lcd.print((aTiempo / 1000) % 60);
  if (showMillis) {
    lcd.print(":");
    lcd.print(999 - millis() % 1000);
void startGameCount() {
  lcd.clear();
  lcd.print("Ready to Begin");
  lcd.print("Push ANY Button");
  keypad.waitForKey();  //if you press a button game start
  lcd.clear();
  lcd.print("Starting Game");
  for (int i = 5; i > 0; i--) {  // START COUNT GAME INIT
    lcd.setCursor(5, 1);
    tone(tonepin, 2000, 100);
    lcd.print("IN ");
    lcd.print(i);
  lcd.clear();
void checkArrows(byte i, byte maxx) {
  if (i == 0) {
    lcd.write(6);
  if (i == maxx) {
    lcd.setCursor(15, 0);
    lcd.write(5);
  if (i > 0 && i < maxx) {
    lcd.write(6);
    lcd.write(5);
void activateRelay() {
  delay(RELAY_TIME);
void sabotage() {  // search and destroy function is search();
  // function unknown - placed here for compiling
  lcd.clear();
  lcd.print("Sabotage");
void domination() {  // search and destroy function is search();
  lcd.clear();
  lcd.print("Domination");
void welcomeSerial() {
  Serial.println("RIGHT  = 4");
  Serial.println("UP     = A");
  Serial.println("DOWN   = B");
  Serial.println("LEFT   = 6");
  Serial.println("SELECT = D");  // OK key
  Serial.println("CANCEL = C");
  Serial.println("DEFUSE = X");  // not implemented
void welcomeLCD() {
  lcd.print("AIRSOFT ONLINE JP");  // you can add your team name or someting cool
  lcd.print(" AIRSOFT BOMB");  // you can add your team name or someting cool
  keypad.setHoldTime(50);
  keypad.setDebounceTime(50);
  keypad.addEventListener(keypadEvent);
Please don't make us go looking for your code. Post it here according to the forum guidelines.
Please read the forum guidelines to see how to properly post code and some information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in a code block.
I have thank you
