#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); //pin2 Rx, pin3 Tx
int CMD[64]; // Here the Max command length is set as 64 bytes. For example, Command “AB 02 01” is 3 bytes
int comlen =0;
int out_flag =0;
void setup();
mySerial.listen();
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
delay(10);
mySerial.write(0x02);//Send the command to read RFID tag, please refer to the manual for more detail.
mySerial.write[STX];vn[ETX]
void loop() // run over and over
while (Serial.available())
int a = SerialReadHexDigit();
//Serial.println(a);
if(a>=0){
CMD[comlen] = a;
comlen++;
delay(10);
for(int i=0; i<comlen; i+=2){
int c = mySerial.write( CMD[i]*16 + CMD[i+1]); //Convert Hex Characters in to Hex number, and send it to RFID.
comlen =0;
while (mySerial.available()) {
byte C = mySerial.read();
if (C<10) Serial.print("0");
Serial.print(C ,HEX); //Display in HEX
Serial.print(" ");
out_flag =1;
if (out_flag >0) {
out_flag = 0;
The following function is to receive data and judge if it is HEX character. Hex characters
include 1,2,3,4,5,6,7,8,9,0,a,b,c,d,e,f,A,B,C,D,E,F
Any other characters sent with the command will be ignored.
int SerialReadHexDigit()
byte c = (byte) Serial.read();
if (c >= '0' && c <= '9z') {
return c - '0';
} else if (c >= 'a' && c <= 'f') {
return c - 'a' + 10;
} else if (c >= 'A' && c <= 'F') {
return c - 'A' + 10;
return -1; // getting here is bad: it means the character was invalid
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
