SMART FIRE DETECTION ALARM SYSTEM(fdas) GSM project
hello guys!! I will have a smart fdas gsm-based project..Components are GSM module,microcontroller and 5 smoke/fire detectors.Please help me about it's system diagram and also the code...TIA:-)
. . . alternatively, you can post a link here to the data sheets of the main components you have purchased together with your ideas of how the system should perform and what you have already done (design and programming) to achieve that and state more specifically where you require help.
Use google as well to with a search phrase such as "arduino " to see if there are similar projects around.
Stefflus:
-Do lives other than your own depend on it?
Almost certainly. Even if he's the only occupant, the only one "immediately"* at risk, there is always the risk of the fire spreading to endanger others' lives. And it's well enough documented that small issues evolve into catastrophes due to a series of "insignificant"* oversights, technical failures and the likes, all conspiring under the control of our old friend Murphy.
  • however you define those terms :wink:
