Smoothing values from capacitive sensor?
Hi all,
I'm working on a project that utilizes a capacitive sensor as a rudimentary distance sensor with a wider range (rather than the cone provided by a standard I.R. distance sensor).
I'm having some trouble getting the values to be consistent and smooth out - the values returned jump around a lot and sometimes don't stay in the same general range, even when I leave my hand in the same exact spot.
I'm using Paul Badger's CapSense library, in a hardware set up as shown in the following image
http://dm.risd.edu/~pbadger/PhysComp/pmwiki/uploads/Devices/CapsenseSens9.jpg
I have the Arduino plugged in through a USB connection to my laptop, which is plugged in to a wall socket.
I tried using the Smoothing code found on the Arduino playground (http://www.arduino.cc/en/Tutorial/Smoothing), but I'm still getting some jumpy values and it seems to be less sensitive when I put my hand close, compared to when I don't use the Smoothing code.
Here is the base code I'm using to grab values:
#include <CapSense.h>
 * CapitiveSense Library Demo Sketch
 * Paul Badger 2008
 * Uses a high value resistor e.g. 10M between send pin and receive pin
 * Resistor effects sensitivity, experiment with values, 50K - 50M. Larger resistor values yield larger sensor values.
 * Receive pin is the sensor pin - try different amounts of foil/metal on this pin
 * Best results are obtained if sensor foil and wire is covered with an insulator such as paper or plastic sheet
CapSense   cs_4_2 = CapSense(4,2);        // 10M resistor between pins 4 & 2, pin 2 is sensor pin, add wire, foil
        // pin 2 is sensor pin, add wire, foil
        //  pin 4 is the receiver pin
//CapSense   cs_4_5 = CapSense(4,5);        // 10M resistor between pins 4 & 6, pin 6 is sensor pin, add wire, foil
//CapSense   cs_4_8 = CapSense(4,8);        // 10M resistor between pins 4 & 8, pin 8 is sensor pin, add wire, foil
    cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
    long start = millis();
    long total1 =  cs_4_2.capSense(30);
    //    long total2 =  cs_4_5.capSense(30);
    //    long total3 =  cs_4_8.capSense(30);
    Serial.print(millis() - start);        // check on performance in milliseconds
    Serial.print("\t");                    // tab character for debug windown spacing
    Serial.println(total1);                  // print sensor output 1
    //    Serial.print("\t");
    //    Serial.print(total2);                  // print sensor output 2
    //    Serial.println(total3);                // print sensor output 3
    delay(10);                             // arbitrary delay to limit data to serial port
Any help with this would be greatly appreciated. Thanks again!
Hi.
I'm just starting to work with the CapSense Library myself. On thought occurs to me, have you tried changing the sampling from 30 to 60? Also, adjusting the delay may show some differences. These are just untested ideas!
Forrest
