I'm having trouble finding definitive documentation that says pins 2 (Rx) and 3 (Tx), may, or may not, be used for SoftwareSerial at 115200 baud
I have a fully working project with a BLE module on Hardware serial, but want to move it to SoftwareSerial because on the finished project I won't be able to disconnect the BLE for program upload. I'll also be able to use the serial monitor if needed.
Here is the code, which works fine if Hardware Serial is defined, but does not work on SoftwareSerial.
-- LED Strip Controller --
This source code of graphical user interface
has been generated automatically by RemoteXY editor.
To compile this code using RemoteXY library 2.3.3 or later version
download by link http://remotexy.com/en/library/
To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
- for ANDROID 4.1.1 or later version;
- for iOS 1.2.1 or later version;
This source code is free software; you can REDistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
#include <EEPROM.h> // used for saving settings
// RemoteXY include library //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__SOFTSERIAL
#include <SoftwareSerial.h>
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL_RX 2
#define REMOTEXY_SERIAL_TX 3
#define REMOTEXY_SERIAL_SPEED 115200
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,4,0,6,0,124,0,8,26,0,
1,2,72,51,21,8,24,31,83,97,
118,101,0,4,128,1,19,98,10,134,
134,4,128,1,32,98,10,204,204,65,
4,2,50,9,9,65,2,14,50,9,
9,65,1,26,50,9,9,65,7,42,
50,9,9,129,0,10,48,3,4,16,
82,0,129,0,21,48,3,4,16,71,
0,129,0,34,48,3,4,16,66,0,
129,0,50,48,7,4,16,77,105,120,
0,129,0,2,1,5,3,16,77,105,
110,0,129,0,93,1,5,3,16,77,
97,120,0,4,128,1,6,98,10,1,
1 };
// this structure defines all the variables of your control interface
struct {
// input variable
uint8_t save_button; // =1 if button pressed, else =0
int8_t GRN; // =0..100 slider position
int8_t BLU; // =0..100 slider position
int8_t RED; // =0..100 slider position
// output variable
uint8_t RED_led_r; // =0..255 LED Red brightness
uint8_t GRN_led_g; // =0..255 LED Green brightness
uint8_t BLU_led_b; // =0..255 LED Blue brightness
uint8_t RGB_led_r; // =0..255 LED Red brightness
uint8_t RGB_led_g; // =0..255 LED Green brightness
uint8_t RGB_led_b; // =0..255 LED Blue brightness
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
// EEPROM Addresses
#define SETTINGS_ID "LED STRIP V1"
#define SETTINGS_ADDRESS 64
// Arduino Pins
// PWM Outputs
const byte pin_RED = 11; // RED Channel (PWM)
const byte pin_GRN = 10; // GRN Channel (PWM)
const byte pin_BLU = 9; // BLU Channel (PWM)
// Define the settings udt
typedef struct udt_Settings {
uint8_t RED; // 0 to 255
uint8_t GRN; // 0 to 255
uint8_t BLU; // 0 to 255
char id[19]; // this is last to catch structure changes
//Create the settings data of type udt_Settings
udt_Settings settings;
#ifdef REMOTEXY_MODE__SOFTSERIAL
SoftwareSerial mySerial = SoftwareSerial(REMOTEXY_SERIAL_RX,REMOTEXY_SERIAL_TX);
#endif
RemoteXY_Init ();
pinMode (pin_RED, OUTPUT);
pinMode (pin_GRN, OUTPUT);
pinMode (pin_BLU, OUTPUT);
pinMode (REMOTEXY_SERIAL_RX, INPUT);
pinMode (REMOTEXY_SERIAL_TX, OUTPUT);
// connect to the serial port
mySerial.begin(REMOTEXY_SERIAL_SPEED);
#endif
#ifndef REMOTEXY_MODE__SOFTSERIAL
#endif
// retrieve settings from EEPROM
settingsLOAD();
// initialise start-up settings if not present
if (strcmp(settings.id, SETTINGS_ID) != 0) {
settings.RED = 127; // half brightness
settings.GRN = 127; // half brightness
settings.BLU = 127; // half brightness
strcpy(settings.id, SETTINGS_ID);
settingsSAVE();
RemoteXY.RED = settings.RED;
RemoteXY.GRN = settings.GRN;
RemoteXY.BLU = settings.BLU;
} // end setup
// LOOP
RemoteXY_Handler ();
// PWM Control (inverted, due to P-channel MOSFET drive)
analogWrite(pin_RED, map(RemoteXY.RED, 100, 0, 0, 255));
analogWrite(pin_GRN, map(RemoteXY.GRN, 100, 0, 0, 255));
analogWrite(pin_BLU, map(RemoteXY.BLU, 100, 0, 0, 255));
// control screen LEDs
RemoteXY.RED_led_r = map(RemoteXY.RED, 0, 100, 0, 255);
RemoteXY.GRN_led_g = map(RemoteXY.GRN, 0, 100, 0, 255);
RemoteXY.BLU_led_b = map(RemoteXY.BLU, 0, 100, 0, 255);
RemoteXY.RGB_led_r = map(RemoteXY.RED, 0, 100, 0, 255);
RemoteXY.RGB_led_g = map(RemoteXY.GRN, 0, 100, 0, 255);
RemoteXY.RGB_led_b = map(RemoteXY.BLU, 0, 100, 0, 255);
// respond to the Save button
if (RemoteXY.save_button) {
RemoteXY.save_button = 0;
// turn the LEDs off for visual indication
analogWrite(pin_RED,255);
analogWrite(pin_GRN,255);
analogWrite(pin_BLU,255);
settings.RED = RemoteXY.RED;
settings.GRN = RemoteXY.GRN;
settings.BLU = RemoteXY.BLU;
settingsSAVE();
delay(50);
} // void(loop)
// Save settings to EEPROM
void settingsSAVE() {
byte EEPROMAddress = SETTINGS_ADDRESS;
const byte* pointer = (const byte*)(const void*)&settings;
for (unsigned int i = 0; i < sizeof(settings); i++) EEPROM.write(EEPROMAddress++, *pointer++);
} // void settingsSAVE()
// Load settings from EEPROM
void settingsLOAD() {
byte* pointer = (byte*)(void*)&settings;
for (unsigned int i = 0; i < sizeof(settings); i++) *pointer++ = EEPROM.read(EEPROMAddress++);
} // void settingsLOAD()
