Software Serial to Software Serial
I've modified the basic example TwoPortReceive on my Arduino Uno so that instead of the two serial ports just listening, they speak to each other.
#include <SoftwareSerial.h>
SoftwareSerial portOne(10, 11);
SoftwareSerial portTwo(8, 9);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // Start each software serial port
  portOne.begin(9600);
  portTwo.begin(9600);
  portOne.listen();
  Serial.println("Sending data from portOne:");
  // while there is data coming in, read it
  // and send to the hardware serial port
  portOne.println("Hi there from portOne!");
  Serial.println("Reading data from portTwo:");
  while (portOne.available() > 0) {
    char inByte = portOne.read();
    Serial.write(inByte);
  // blank line to separate data from the two ports:
  // Now listen on the second port
  portTwo.listen();
  Serial.println("Sending data from portTwo:");
  // and send to the hardware serial port:
  portOne.println("Hi there from portTwo!");
  Serial.println("Reading data from portOne:");
I have port 11 wired to 8 and port 10 wired to 9. What I would expect is that portOne will transmit over port 11 to port8. portTwo will read this data and print it to the Serial console, and vice versa.
Unfortunately, no data is received.
Another working example of this here: SoftwareSerialRemoteExample - ArduinoInfo
I see that code, but it doesn't exactly help... Software Serial Tx simply isn't working.
I set up the code as simply as possible in a new example:
// software serial #1: RX = digital pin 10, TX = digital pin 11
  while (!Serial) {
  portOne.listen();
  Serial.println("Sending data from Tx 11");
  portOne.println("Hi there from 11!");
  Serial.println("Reading data from 10:");
And I wired 10 to 11. 10 is not received any data transmitted by 11, but if I hook 10 up to TX(1) it receives data.
Here is my wiring for the two setups, just to see what's going on. Does this seem like a hardware problem, or are there any troubleshooting steps that I can follow through with?
Is there anything inherent in software serial communications that would prevent two on the same chip from communicating?
My current experience is that Software Serial Tx does not work in any capacity at the moment.
Attached two photos..
Google Photos
Google Photos
You can't send from one instance of Software Serial to another instance on the same Arduino. Only one instance can work at any one time. Software Serial is a very poor imitation of Hardware Serial.
...R
Should I be able to transmit from Software Serial Tx to Software Serial Rx using the same Software Serial object?
Should I be able to transmit from Software Serial Tx to Hardware Serial Rx(0) ?
Right now I can't seem to do either of these, although it seems like I should be able to.
ryanauger95:
No.
Yes. But it seems completely pointless.
...R
