SolarCalculator library for Arduino
I made this library for a personal project and thought it might be useful to others:
It provides functions to calculate:
  • Sunrise, sunset, solar noon, and twilight (dawn and dusk)
  • Sun's (geocentric) equatorial coordinates (RA/Dec, and distance)
  • Sun's (topocentric) horizontal coordinates (Az/El, corrected for atmospheric refraction)
  • Equation of time, i.e. difference between sundials and clocks
Header file: SolarCalculator.h
The Az/El angles combined with rise & set times could be useful for solar tracking applications.
I'll be happy to discuss the details of the implementation, if interested.
PS. I'm working on a similar library for the Sun, Moon, and planets.
Being able to calculate sun rise/set will go well with my solar powered weather station. Thanks for posting.
I noticed that doubles are used, on a Uno those would just be floats and on an ESP32 those would be 64bit floating point numbers. On a ESP32 is a 64bit floating point number necessary?
"Calculate the Sun's equatorial coordinates (right ascension and declination)" <<<< Thanks! Pre-positing of the solar cells in anticipation of the morning sun is something that has been a work in progress for me.
Ah I see the note at the bottom:
" * Arduino's single precision floating numbers have the equivalent of 24 * log10(2) ≈ 7.22 significant digits. Although this is generally not sufficient for mathematical astronomy (Meeus, 1998), it is sufficient for our solar calculations." which answers my question.
Just to clarify:
Double precision is not necessary in almost all cases, but it's best practice to do the intermediate calculations as precisely as possible, then store the final result in the type/format of your choice.
For example, in my application, I store sunrise/sunset times as unsigned long.
The cases where double precision may be necessary (for intermediate calculations) is when the Julian century becomes large. For every power of 10 centuries before or after the year 2000, you will essentially lose 1 significant digit.
You could also use the horizontal coordinates (azimuth and elevation) directly, which take into account atmospheric refraction.
Along with pre-positioning the motors for the next day, I can now power down the sun finding circuit. Keeping the sun finder circuit powered off till the calculated sunrise, reducing power consumption by not having to constantly seek the sun and false power ups of the motors from stray light sources.
When I use this code:
double sunrise;  // Sunrise, in hours (UTC)
double transit;  // Solar noon, in hours (UTC)
double sunset;   // Sunset, in hours (UTC)
double dawn;     // Civil dawn, in hours (UTC)
double dusk;     // Civil dusk, in hours (UTC)
const float time_zone = -7.0f;
void fSolarCalculations ( )
  // Location
  double latitude = 43.618881;
  double longitude = -116.215019;
// Calculate the times of sunrise, transit and sunset (UTC)
  calcSunriseSunset( rtc.getYear(), rtc.getMonth(), rtc.getDay(), latitude, longitude, transit, sunrise, sunset );
  // Calculate the times of civil dawn and dusk (UTC)
  calcCivilDawnDusk( rtc.getYear(), rtc.getMonth(), rtc.getDay(), latitude, longitude, transit, dawn, dusk);
  transit += time_zone;
  sunrise += time_zone;
  sunset  += time_zone;
  dawn    += time_zone;
  dusk    += time_zone;
  log_i( "sunrise %s sunset %s dawn %s dusk %s", SolarTimeFormat(sunrise).c_str(), SolarTimeFormat(sunset).c_str() , SolarTimeFormat(dawn).c_str(), SolarTimeFormat(dusk).c_str() );
} //void fSolarCalculations ( )
String SolarTimeFormat( double h  )
  String temp = "";
  int m = int(round(h * 60));
  int hours = (m / 60) % 24;
  int minutes = m % 60;
  temp = String(hours + time_zone) + ":" + String(minutes);
  return temp;
I get [I][ESP32_Chappie_Inside_THP_1.ino:182] fSolarCalculations(): sunrise 0.00:28 sunset 10.00:29 dawn -1.00:57 dusk 10.00:59. Which I know is incorrect.
Was wondering where I am going wrong with my use attempt?
Here is the entire code of the test project:
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection infor for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <driver/adc.h>
#include "esp32-hal-ledc.h"
#include <HardwareSerial.h>
#include <SimpleKalmanFilter.h>
#include "MHZ19.h"
#include <ESP32Time.h>
#include <SolarCalculator.h>
ESP32Time rtc;
MHZ19 myMHZ19;
Adafruit_BME680 bme( GPIO_NUM_5 ); // use hardware SPI, set GPIO pin to use
//Adafruit_ST7789 tft = Adafruit_ST7789( TFT_CS     , TFT_DC    , TFT_MOSI   , TFT_SCLK   , TFT_RST     );
Adafruit_ST7789 tft   = Adafruit_ST7789( GPIO_NUM_15, GPIO_NUM_0, GPIO_NUM_13, GPIO_NUM_14, GPIO_NUM_22 );
WiFiClient   wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
#define evtDoParticleRead     ( 1 << 0 ) // declare an event
#define evtWaitForBME         ( 1 << 1 )
#define evtParseMQTT          ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
QueueHandle_t xQ_WindChillDewPoint;
QueueHandle_t xQ_eData; // environmental data to be displayed on the screen
struct stu_eData
  float  Temperature = 0.0f;
  float  Pressure    = 0.0f;
  float  Humidity    = 0.0f;
  float  IAQ         = 0.0f; // Index Air Quality
  float  RM0         = 0.0f; // Remaining Moisture from sensor 0
  float  PM2         = 0.0f; // particles in air
  float  WS          = 0.0f; // wind speed
  String WD          = "";   // wind direction
  float  RF          = 0.0f; // rainfall
  float  WSV         = 0.0f; // weather station volts
  float  WSC         = 0.0f;  // weather station current
  float  WSP         = 0.0f;  // weather station power
  float  WindChill   = 0.0f; //windchill
  float  DewPoint    = 0.0f;   //dew point or dew index
} x_eData; // environmental data
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
const float oGasResistanceBaseLine = 149598.0f;
int mqttOK = 0;
int CO2    = 0;
volatile bool TimeSet = false;
esp_timer_handle_t oneshot_timer; //veriable to store the hardware timer handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_PublishPM;
SemaphoreHandle_t sema_mqttOK;
//serial(2) = pin25 RX, pin26 TX
HardwareSerial co2Serial ( 2 );
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR oneshot_timer_callback( void* arg )
  BaseType_t xHigherPriorityTaskWoken;
  xEventGroupSetBitsFromISR( eg, evtDoParticleRead, &xHigherPriorityTaskWoken );
} //void IRAM_ATTR oneshot_timer_callback( void* arg )
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
  int i = 0; // extract payload
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  co2Serial.begin( 9600 , SERIAL_8N1, 25, 26 ); // pin25 RX, pin26 TX
  x_eData.WD.reserve(50);
  x_message.topic.reserve( payloadSize );
  xQ_WindChillDewPoint = xQueueCreate( 1, sizeof(stu_eData) );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  xQ_eData    = xQueueCreate( 1, sizeof(stu_eData) ); // sends a queue copy of the structure
  sema_PublishPM = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_PublishPM );
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  ledcSetup( 4, 12000, 8 ); // ledc: 4  => Group: 0, Channel: 2, Timer: 1, led frequency, resolution  bits
  ledcAttachPin( GPIO_NUM_12, 4 );   // gpio number and channel
  ledcWrite( 4, 0 ); // write to channel number 4
  eg = xEventGroupCreate(); // get an event group handle
  // output mode
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_OUTPUT; // set gpio mode
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_4) ); //bit mask of the pins to set
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  gpio_set_level( GPIO_NUM_4, LOW); // set air particle sensor trigger pin to LOW
  // input mode
  io_cfg = {}; // reinitialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) | (1ULL << GPIO_NUM_27)  ); //bit mask of the pins to set, assign gpio number to be configured
  // set up A:D channels, refer: https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36
  // https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html?highlight=hardware%20timer High Resoultion Timer API
  esp_timer_create_args_t oneshot_timer_args = {}; // initialize High Resoulition Timer (HRT) configuration structure
  oneshot_timer_args.callback = &oneshot_timer_callback; // configure for callback, name of callback function
  esp_timer_create( &oneshot_timer_args, &oneshot_timer ); // assign configuration to the HRT, receive timer handle
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 7000,  NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 15000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( DoTheBME680Thing, "DoTheBME280Thing", 20000, NULL, 5, NULL, 1);
  xTaskCreatePinnedToCore( fDoParticleDetector, "fDoParticleDetector", 6000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoTheDisplayThing, "fDoTheDisplayThing", 23000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fScreenBlanking, "fScreenBlanking", 2000, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fGetCO2, "fGetCO2", 4500, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fParseDewPointWindChill, "fParseDewPointWindChill", 4500, NULL, 2, NULL, 1 );
} //void setup()
  // Location
  dawn    += time_zone;
  dusk    += time_zone;
  String temp = "";
  return temp;
  250-400ppm Normal background concentration in outdoor ambient air
  400-1,000ppm  Concentrations typical of occupied indoor spaces with good air exchange
  1,000-2,000ppm  Complaints of drowsiness and poor air.
  2,000-5,000 ppm Headaches, sleepiness and stagnant, stale, stuffy air. Poor concentration, loss of attention, increased heart rate and slight nausea may also be present.
  5,000 Workplace exposure limit (as 8-hour TWA) in most jurisdictions.
  >40,000 ppm Exposure may lead to serious oxygen deprivation resulting in permanent brain damage, coma, even death.
void fParseDewPointWindChill( void *pvParameters )
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  struct stu_message px_message;
  String sDewPoint = "";
  String sWindChill = "";
  sDewPoint.reserve( payloadSize );
  sWindChill.reserve( payloadSize );
  for (;;)
    if ( xQueueReceive(xQ_WindChillDewPoint, &px_message, portMAX_DELAY) == pdTRUE )
      sDewPoint = px_message.payload;
      int commaIndex = sDewPoint.indexOf(',');
      sWindChill.concat ( sDewPoint.substring(0, commaIndex) );
      sDewPoint.remove( 0, (commaIndex + 1) );
      x_eData.WindChill = sWindChill.toFloat();
      x_eData.DewPoint = sDewPoint.toFloat();
      sDewPoint = "";
      sWindChill = "";
    //log_i( " high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete( NULL );
void fGetCO2 ( void *pvParameters )
  uint64_t TimePastKalman  = esp_timer_get_time();
  myMHZ19.begin( co2Serial );
  myMHZ19.autoCalibration();
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 1000; //delay for mS
  SimpleKalmanFilter KF_CO2( 1.0f, 1.0f, .01f );
  for ( ;; )
    KF_CO2.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f );
    CO2 = KF_CO2.updateEstimate( myMHZ19.getCO2() ); // apply simple Kalman filter
    xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
    MQTTclient.publish( topicCO2, String(CO2).c_str() );
    xSemaphoreGive( sema_MQTT_KeepAlive );
    // process wind chill and dew point
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
} //void fMHZ19B ( void *pvParameters )
void fScreenBlanking( void *pvParameters )
  int       TimeOfPause = 10000 * 1000;
  uint64_t  PauseStartTime = esp_timer_get_time();
  bool      Pause = false;
  const int brightness = 250;
  int       countUpDown = brightness;
  for ( ;; )
    if (!Pause )
      //if motion detect then show display otherwise blank display
      if ( !(gpio_get_level( GPIO_NUM_27)) )
        for ( countUpDown; countUpDown-- > 0; )
          ledcWrite( 4, countUpDown ); // write to channel number 4, dim backlight
          vTaskDelay( 7 );
        Pause = true;
        ledcWrite( 4, brightness );
      // still detecting movement reset blanking pause time
      if ( gpio_get_level( GPIO_NUM_27) )
        PauseStartTime = esp_timer_get_time(); // extend pause blanking time
      if ( (esp_timer_get_time() - PauseStartTime) >= TimeOfPause )
        Pause = false;
    vTaskDelay( 250 );
} //void fScreenBlanking( void *pvParameters )
void fparseMQTT( void *pvParameters )
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
      mqttOK = 0;
      if ( px_message.topic == topicRemainingMoisture_0 )
        x_eData.RM0  = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindSpeed )
        x_eData.WS = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindDirection )
        x_eData.WD = "";
        x_eData.WD = String(px_message.payload);
      if ( px_message.topic == topicRainfall )
        x_eData.RF = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSVolts )
        x_eData.WSV = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSCurrent )
        x_eData.WSC = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSPower )
        x_eData.WSP = String(px_message.payload).toFloat();
      if ( px_message.topic == topicDPnWI )
        xQueueSend( xQ_WindChillDewPoint, (void *) &px_message, 1 );
      if ( String(px_message.topic) == topicOK )
        if ( !TimeSet)
          String temp = "";
          temp =  px_message.payload[0];
          temp += px_message.payload[1];
          temp += px_message.payload[2];
          temp += px_message.payload[3];
          int year =  temp.toInt();
          temp = "";
          temp =  px_message.payload[5];
          temp += px_message.payload[6];
          int month =  temp.toInt();
          temp =  "";
          temp =  px_message.payload[8];
          temp += px_message.payload[9];
          int day =  temp.toInt();
          temp = "";
          temp = px_message.payload[11];
          temp += px_message.payload[12];
          int hour =  temp.toInt();
          temp = "";
          temp = px_message.payload[14];
          temp += px_message.payload[15];
          int min =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "rtc  %s ", rtc.getTime() );
          TimeSet = true;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void fDoTheDisplayThing( void * parameter )
  tft.init( 240, 320 ); // Init ST7789 320x240
  tft.setRotation( 3 );
  tft.setTextSize( 3 );
  tft.fillScreen( ST77XX_BLACK );
  tft.setTextWrap( false );
  struct stu_eData px_eData;
  ledcWrite( 4, brightness ); //backlight set
  const int MaxString      = 20;
  String oldTempString     = "";
  String oldHumidityString = "";
  String oldAQIString      = "";
  String oldRainfall       = "";
  String oldWindDirection  = "";
  String oldAirPressure    = "";
  String oldRMO            = "";
  String oldPM2            = "";
  String oldPower          = "";
  oldHumidityString.reserve( MaxString );
  oldWindDirection.reserve( MaxString );
  oldAirPressure.reserve( MaxString );
  oldTempString.reserve( MaxString );
  oldAQIString.reserve( MaxString );
  oldRainfall.reserve( MaxString );
  oldPower.reserve( MaxString );
  oldRMO.reserve( MaxString );
  oldPM2.reserve( MaxString );
  bool Tick = true;
  const int numOfColors = 40;
  /* https://chrishewett.com/blog/true-rgb565-colour-picker/#:~:text=A%20true%20RGB565%20colour%20picker%2021st%20Oct%202017,in%205%20bits%20and%20green%20in%206%20bits. */
  int colors[numOfColors] = { ST77XX_BLACK, ST77XX_RED, ST77XX_WHITE, ST77XX_BLUE, ST77XX_GREEN, ST77XX_CYAN, ST77XX_MAGENTA, ST77XX_YELLOW, 0xd55b, 0xee09,
                              0x2e15, 0xcb43, 0x6bad, 0x126f, 0x1264, 0xe264, 0xe7e4, 0x87e4, 0x87fe, 0x876a,
                              0xe304, 0x1cc4, 0xf4c4, 0xf4da, 0xcf66, 0xa879, 0x7f28, 0x4f37, 0xfa97, 0x6195,
                              0X8162, 0xc962, 0x517b, 0x325b, 0xea5b, 0x179b, 0xff80, 0xf960, 0x416d, 0x7bd1
  int colorCounter = 1;
  for (;;)
    if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
      tft.setCursor( 0, 0 );
      tft.setTextColor( colors[0] );
      tft.print( oldTempString );
      tft.setTextColor( colors[colorCounter] );
      oldTempString = "";
      if ( Tick )
        oldTempString.concat( "iTemp " + String(px_eData.Temperature) + "F" );
        oldTempString.concat( "Wind Chill " + String(px_eData.WindChill) + "F" );
      tft.println( oldTempString );
      tft.setCursor( 0, 30 );
      tft.print( oldHumidityString );
      oldHumidityString.concat( "iHum  " + String(px_eData.Humidity) + "%" );
      tft.println( oldHumidityString );
      tft.setCursor( 0, 60 );
      tft.print( oldAirPressure );
      //oldAirPressure.concat( "Pres " + String(px_eData.Pressure) + "mmHg" );
      oldAirPressure.concat( "Dew Pt. " + String(px_eData.DewPoint) + "F" );
      tft.println( oldAirPressure );
      tft.setCursor( 0, 90 );
      tft.print( oldAQIString );
      oldAQIString = "";
      oldAQIString.concat( "iAQI " + String(px_eData.IAQ) + "%" );
      tft.println( oldAQIString );
      tft.setCursor( 0, 120 );
      tft.print( oldRMO );
      oldRMO = "";
      if ( Tick )
        oldRMO.concat( "iRM0 " + String(px_eData.RM0) + "%" );
        oldRMO.concat( "iCO2 " + String(CO2) + "ppm" );
      tft.println( oldRMO );
      tft.setCursor( 0, 150 );
      tft.print( oldPM2 );
      oldPM2 = "";
      oldPM2.concat( "PM2 " + String(px_eData.PM2) + "ug/m3" );
      tft.println( oldPM2 );
      tft.setCursor( 0, 180 );
      tft.print( oldPower );
      oldPower = "";
      oldPower.concat(  String(px_eData.WSV) + " Volts" );
      //oldPower.concat(  String(px_eData.WSV) + "V " + String(int(px_eData.WSC * 1000.0f)) + "mA " + String((int(px_eData.WSP * 1000.0f))) + "mW" );
      tft.println( oldPower );
      colorCounter++;
      if ( colorCounter > (numOfColors - 1) )
        colorCounter = 1;
      Tick = !Tick;
    } //if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
  } //for (;;)
} //void fDoTheDisplayTHing( void * parameter )
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 86300; // 1st time update in 100 counts
  int maxNonMQTTresponse = 5;
  for (;;)
    vTaskDelay( 1000 );
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    mqttOK++;
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      fSolarCalculations();
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
float fCalulate_IAQ_Index( int gasResistance, float Humidity)
  float hum_baseline = 40.0f;
  float hum_weighting = 0.25f;
  float gas_offset = 0.0f;
  float hum_offset = 0.0f;
  float hum_score = 0.0f;
  float gas_score = 0.0f;
  gas_offset = oGasResistanceBaseLine - float( gasResistance );
  hum_offset = float( Humidity ) - hum_baseline;
  // calculate hum_score as distance from hum_baseline
  if ( hum_offset > 0.0f )
    hum_score = 100.0f - hum_baseline - hum_offset;
    hum_score /= ( 100.0f - hum_baseline );
    hum_score *= ( hum_weighting * 100.0f );
    hum_score = hum_baseline + hum_offset;
    hum_score /= hum_baseline;
    hum_score *= ( 100.0f - (hum_weighting * 100.0f) );
  //calculate gas score as distance from baseline
  if ( gas_offset > 0.0f )
    gas_score = float( gasResistance ) / oGasResistanceBaseLine;
    gas_score *= ( 100.0f - (hum_weighting * 100.0f ) );
    gas_score = 100.0f - ( hum_weighting * 100.0f );
  return ( hum_score + gas_score );
} //void fCalulate_IAQ_Index( int gasResistance, float Humidity):
void fDoParticleDetector( void * parameter )
    ug/m3     AQI                 Lvl AQ (Air Quality)
    (air Quality Index)
    0-35     0-50                1   Excellent
    35-75    51-100              2   Average
    75-115   101-150             3   Light pollution
    115-150  151-200             4   moderate
    150-250  201-300             5   heavy
    250-500  >=300               6   serious
  float ADbits = 4095.0f;
  float uPvolts = 3.3f;
  float adcValue = 0.0f;
  float dustDensity = 0.0f;
  float Voc = 0.6f; // Set the typical output voltage, when there is zero dust.
  const float K = 0.5f; // Use the typical sensitivity in units of V per 100ug/m3.
  xEventGroupWaitBits (eg, evtWaitForBME, pdTRUE, pdTRUE, portMAX_DELAY );
  const TickType_t xFrequency = 100; //delay for mS
  for (;;)
    //enable sensor led
    gpio_set_level( GPIO_NUM_4, HIGH ); // set gpio 4 to high to turn on sensor internal led for measurement
    esp_timer_start_once( oneshot_timer, 280 ); // trigger one shot timer for a 280uS timeout, warm up time.
    xEventGroupWaitBits (eg, evtDoParticleRead, pdTRUE, pdTRUE, portMAX_DELAY ); // event will be triggered by the timer expiring, wait here for the 280uS
    adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading from the dust sensor
    gpio_set_level( GPIO_NUM_4, LOW );//Shut off the sensor LED
    adcValue = ( adcValue * uPvolts ) / ADbits; //calculate voltage
    dustDensity = (adcValue / K) * 100.0; //convert volts to dust density
    if ( dustDensity < 0.0f )
      dustDensity = 0.00f; // make negative values a 0
    if ( xSemaphoreTake( sema_PublishPM, 0 ) == pdTRUE )  // don't wait for semaphore to be available
      //log_i( "ADC volts %f Dust Density = %ug / m3 ", adcValue, dustDensity ); // print the calculated voltage and dustdensity
      MQTTclient.publish( topicInsidePM, String(dustDensity).c_str() );
      x_eData.PM2 = dustDensity;
}// end fDoParticleDetector()
void DoTheBME680Thing( void *pvParameters )
  SPI.begin(); // initialize the SPI library
  vTaskDelay( 10 );
  if (!bme.begin()) {
    log_i("Could not find a valid BME680 sensor, check wiring!");
    while (1);
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  //wait for a mqtt connection
    vTaskDelay( 250 );
  xEventGroupSetBits( eg, evtWaitForBME );
  const TickType_t xFrequency = 1000 * 15; //delay for mS
  String bmeInfo = "";
  bmeInfo.reserve( 100 );
  for (;;)
    x_eData.Temperature  = bme.readTemperature();
    x_eData.Temperature  = ( x_eData.Temperature * 1.8f ) + 32.0f; // (Celsius x 1.8) + 32
    x_eData.Pressure     = bme.readPressure();
    x_eData.Pressure     = x_eData.Pressure / 133.3223684f; //converts to mmHg
    x_eData.Humidity     = bme.readHumidity();
    x_eData.IAQ          = fCalulate_IAQ_Index( bme.readGas(), x_eData.Humidity );
    //log_i( " temperature % f, Pressure % f, Humidity % f IAQ % f", x_eData.Temperature, x_eData.Pressure, x_eData.Humidity, x_eData.IAQ);
    bmeInfo.concat( String(x_eData.Temperature, 2) );
    bmeInfo.concat( "," );
    bmeInfo.concat( String(x_eData.Pressure, 2) );
    bmeInfo.concat( String(x_eData.Humidity, 2) );
    bmeInfo.concat( String(x_eData.IAQ, 2) );
    if ( MQTTclient.connected() )
      MQTTclient.publish( topicInsideInfo, bmeInfo.c_str() );
    xSemaphoreGive( sema_PublishPM ); // release publish of dust density
    mqttOK ++;
    xQueueOverwrite( xQ_eData, (void *) &x_eData );// send data to display
    bmeInfo = ""; // empty the string buffer
    findDewPointWithHumidity( x_eData.Humidity, x_eData.Temperature );
    // log_i( "DoTheBME280Thing high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete ( NULL );
  Important to not set vTaskDelay/vTaskDelayUntil to less then 10. Errors begin to develop with the MQTT and network connection.
  makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; //delay for ms
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status % s WiFi status % s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
void connectToMQTT()
  byte mac[5]; // create client ID from mac address
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe  ( topicOK );
  MQTTclient.subscribe  ( topicRemainingMoisture_0 );
  MQTTclient.subscribe  ( topicWindSpeed );
  MQTTclient.subscribe  ( topicWindDirection );
  MQTTclient.subscribe  ( topicRainfall );
  MQTTclient.subscribe  ( topicWSVolts );
  MQTTclient.subscribe  ( topicWSCurrent );
  MQTTclient.subscribe  ( topicWSPower );
  MQTTclient.subscribe  ( topicDPnWI );
} //void connectToMQTT()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
float findDewPointWithHumidity( float humi, float temperature )
  //Celcius
  float ans =  (temperature - (14.55 + 0.114 * temperature) * (1 - (0.01 * humi)) - pow(((2.5 + 0.007 * temperature) * (1 - (0.01 * humi))), 3) - (15.9 + 0.117 * temperature) * pow((1 - (0.01 * humi)), 14));
  //log_i( "%f", ans );
  return ans;
void loop() { }
I think you're adding the time zone twice.
In SolarTimeFormat, it should be:
temp = String(hours) + ":" + String(minutes);
Thanks for pointing out that error.
That sounds like a very useful development. I had a quick look at the Sunrise/Sunset example and it seams very compact.
A couple of years ago I built a 7-day time switch (actually I have now 4 to the same ESP8266 design) which allows the user, as well as being able to enter a normal time, say 08:15, in the schedule can also enter codes for Sunrise (SR) and Sunset (SS) with an offset. I used the TimeLord library for that but it is no longer supported. I was intending to publish the whole design but have not yet got around to it. If I revisit the project, I'll look again at your library.
I take it that Jan is month 0 and Dec is month 11 with this library?
Months are 1-12.
Same as the date (in 24h format) and compatible with the Time library for Arduino:
hour(); // The hour now (0-23)
minute(); // The minute now (0-59)
second(); // The second now (0-59)
day(); // The day now (1-31)
month(); // The month now (1-12)
year(); // The full four digit year: (2009, 2010 etc)
I ended up with:
  // Location
  calcSunriseSunset( rtc.getYear(), rtc.getMonth() , rtc.getDay(), latitude, longitude, transit, sunrise, sunset );
  calcCivilDawnDusk( rtc.getYear(), rtc.getMonth() , rtc.getDay(), latitude, longitude, transit, dawn, dusk);
  dawn    += time_zone;
  dusk    += time_zone;
  String temp = "";
  if( hours < 10 )
    temp = "0" + String(hours) + String(minutes);
    temp = String(hours) + String(minutes);
  return temp;
The ESP32Time.h library returns months 0 to 11. Once I figured that out, things are running smoothly.
fbiego/ESP32Time: An Arduino library for setting and retrieving internal RTC time on ESP32 boards (github.com)
getMonth()         //  (int)     0     (0-11)
As a note, I tried calcCivilDawnDusk( rtc.getYear(), 12 , rtc.getDay(), latitude, longitude, transit, dawn, dusk);. The calculations return wonky results with a hardcoded 12.
The correct times are:
> Date: 2021-12-6
> Latitude: 43.619 Longitude: -116.215
> UTC offset: -7
> Sunrise: 08:04
> Transit: 12:36
> Sunset:  17:08
> Civil dawn: 07:31
> Civil dusk: 17:41
Arduino IDE 1.8.13 and Uno
What did you get?
Thank you. This is really cool that you would take this time. I appreciate it.
  // Location
  //calcSunriseSunset( rtc.getYear(), rtc.getMonth() , rtc.getDay(), latitude, longitude, transit, sunrise, sunset );
  calcSunriseSunset( 2021, 12 , 6, latitude, longitude, transit, sunrise, sunset );
  //calcCivilDawnDusk( rtc.getYear(), rtc.getMonth() , rtc.getDay(), latitude, longitude, transit, dawn, dusk);
  calcCivilDawnDusk( 2021, 12 , 6, latitude, longitude, transit, dawn, dusk);
  dawn    += time_zone;
  dusk    += time_zone;
  String temp = "";
  if( hours < 10 )
  return temp;
Produces this output:
I][ESP32_Chappie_Inside_THP_1.ino:184] fSolarCalculations(): sunrise 084 sunset 178 dawn 0731 dusk 1741
[I][ESP32_Chappie_Inside_THP_1.ino:370] fparseMQTT(): rtc  13:22:00 Year 2021 month 12 day 6
It seems like you're getting the correct result, but need to insert an additional zero:
if (minutes < 10)
No problem
I saw the need to add an additional 0 for the minutes for print outs.
The ESP32's running the weather station will not be doing the calculations of sunrise, sunset, dusk, dawn, transit and horizontal coordinates. The MCU that will be calculating the values is now sending the calculated values (sunrise, sunset, dawn dusk, and transit) to a local MQTT Broker. From the Broker the weather station will receive a solar data payload for use. I'll be working on having the MCU calculating the horizontal coordinates for solar panel prepositioning and then I'll publish the azimuth and elevation data to the MQTT Broker for weather station use.
The MCU that is calculating the solar thing is displaying the solar data. The display function is doing the formatting of leading zeros. My plan is that any consumer of the solar data will format the data as required.
void SolarTimeFormat( double h, int i  )
int hours = 0;
int minutes =0;
  if ( h != 0 )
    minutes = m % 60;
  switch ( i ) {
    case 0:
      x_eData.SunRiseHr = hours;
      x_eData.SunRiseMin = minutes;
    case 1:
      x_eData.SunSetHr = hours;
      x_eData.SunSetMin = minutes;
    case 2:
      x_eData.DawnHr = hours;
      x_eData.DawnMin = minutes;
    case 3:
      x_eData.DuskHr = hours;
    case 4:
      x_eData.TransitHr = hours;
      x_eData.TransitMin = minutes;
    case 5:
      String sTopic = "";
      sTopic.reserve( 35 );
      sTopic.concat( String(x_eData.SunRiseHr) + "," );
      sTopic.concat( String(x_eData.SunRiseMin) + "," );
      sTopic.concat( String(x_eData.SunSetHr) + "," );
      sTopic.concat( String(x_eData.SunSetMin) + "," );
      sTopic.concat( String(x_eData.DawnHr) + "," );
      sTopic.concat( String(x_eData.DawnMin) + "," );
      sTopic.concat( String(x_eData.TransitHr) + "," );
      sTopic.concat( String(x_eData.TransitMin) );
      MQTTclient.publish( topicSRSSDDT, sTopic.c_str() );
    default: break;
  } // switch (event) {
} // void SolarTimeFormat( double h, int i  )
Would altitude come into play when calculating sunrise/sunset?
I ask because I've spent many a night camped up at +8K feet in the Frank Church Wilderness of No Return and the sun is still visible at 2130ish or so.
Definitely. But it's not taken into account in these calculations.
The variation with altitude is approximately linear, and so we conclude that sunset is later by 1 minute for every 1.5 kilometres in altitude, and that sunrise is earlier by the same amount.
Source: How do sunrise and sunset times change with altitude?
Latest version 1.0.2 should show up in the library manager any time and is significantly more lightweight after the removal of superfluous delta T equations.
I revisited this question recently and found a different answer in the Explanatory Supplement to the Astronomical Almanac (1992), p.484:
Sunrise or sunset at a height above the level of the horizon occurs when the Sun's altitude is approximately:
sun_altitude = SUNRISESET_STD_ALTITUDE - 0.0353 * sqrt(height);
which I included in the example sketch SunriseSunsetAltitude.
Oi! Thank you for looking into the question.
