Solar Tracker Servo Repositioning
I made solar tracker and I want to make a switch to on and off solar tracker.
When I on that tracker it will start following sun and when I off the Tracker so servo will come to their original position.
I am Using ESP32, Servo motor MG946R - 4 no’s, External power source for Servo motor from Battery Shield 2 cell which gives duel output
3.3 volt = 4 no’s and
5 volt = 4 nos.
Servo connected with 5 volt output.
Can anyone tell me what code should I use
You haven't said what tracks the sun.
Did you pre-calculate based on lat/long?
Welcome to the forum
This forum is not a code writing service although there is a category in which yo can post and ask for paid help
The forum works best when you do your best to get your project working and come here to seek help for problems that you have
The best advice I can give is to write your code in sections and test each component rather than trying to do everything at once
What programming and electronics experience do you have ?
To track Sun I am using 4 LDR
And yet, you didn't think to mention them.
Or your code.
have you tried doing a search for "solar tracker"? this has come up a few times
See this project:
" https://www.instructables.com/Arduino-Solar-Tracker/
This WEB has it all, just look for it.........
below Is my Code
#define BLYNK_TEMPLATE_NAME "{redacted}"
#define BLYNK_AUTH_TOKEN "{redacted}"
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <WiFiClientSecure.h>
char ssid[] = "{redacted}"
char pass[] = "{redacted}"
#include <ESP32Servo.h>
#include <time.h>
#include "ACS712.h"
#include "DHT.h"
#define DHTTYPE DHT22
#define DHTPIN 4 // Temparture and Humididty Sensor of Boost Converter
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
unsigned long previousMillis = 0;
unsigned long interval = 30000;
const char* host = "script.google.com"; // Host & httpsPort
const int httpsPort = 443;
WiFiClientSecure Client;
const char* fingerprint = "{redacted}";
String GAS_ID = "{redacted}"; //--> spreadsheet script ID
int solarvoltage = 34; // Solar Voltage Sensor
int batteryvoltage = 39; // Battery Voltage Sensor
float correctionfactor = 1.1;
float vout = 0.0;
float vin = 0.0;
float R1 = 30000 + 150000;
float R2 = 7500;
int value = 0.0;
int solarcurrent = 35; // Solar Current Sensor
int batterycurrent = 36; // Battery Current Sensor
ACS712  ACS(35, 5.0, 4095, 66);
double voltage = 0.0;
double current = 0.0;
int ldrlt =36; //LDR top left
int ldrrt =39; //LDR top  Right
int ldrld =34; //LDR down left
int ldrrd =35; //ldr down Right
Servo horizontal; // horizontal servo
int servoh = 90;  // start at degree
int servohLimitHigh = 180;
int servohLimitLow = 0;
// 65 degrees MAX
Servo vertical; // vertical servo
int servov = 90;  // start at degree
int servovLimitHigh = 180;
int servovLimitLow = 0;
void initWiFi() {
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, pass);
  Serial.print("Connecting to WiFi ..");
    Serial.print('.');
    //delay(1000);
  //if WiFi is down, try reconnecting every CHECK_WIFI_TIME seconds
  if ((WiFi.status() != WL_CONNECTED) && (currentMillis - previousMillis >=interval)) {
    Serial.print(millis());
   Serial.println("Reconnecting to WiFi...");
   WiFi.disconnect();
   WiFi.reconnect();
BLYNK_WRITE(V0)
  int value = param.asInt();
  Serial.print(value);
  if(value == 0)
    digitalWrite(23, LOW); // Solar Power On Off
    Serial.println(" : Solar Off : ");
  if(value == 1)
     digitalWrite(23, HIGH);
     Serial.println(" : Solar On : ");
BLYNK_WRITE(V1)
  if(value == 0)
    digitalWrite(22, LOW); // Battery Charging Power On Off
    Serial.println(" : Battery Off");
  if(value == 1)
     digitalWrite(22, HIGH);
     Serial.println(" : Battery On");
BLYNK_WRITE(V2)
  if(value == 0)
    digitalWrite(21, LOW); // Cooling Fan for Boost Converter Power On Off
    Serial.println(" : Fan Off");
  if(value == 1)
     digitalWrite(21, HIGH);
     Serial.println(" : Fan On");
BLYNK_WRITE(V3)
  if(value == 0)
  digitalWrite(36, LOW); // LDR Top Left Solar Tracker Power On off
  digitalWrite(39, LOW); // LDR Top Right Solar Tracker Power On off
  digitalWrite(34, LOW); // LDR Bottom Left Solar Tracker Power On off
  digitalWrite(35, LOW); // LDR Bottom Right Solar Tracker Power On off
  Serial.println(" : Solar Tracker Off");
  if(value == 1)
  digitalWrite(36, HIGH); // LDR Top Left Solar Tracker Power On off
  digitalWrite(39, HIGH); // LDR Top Right Solar Tracker Power On off
  digitalWrite(34, HIGH); // LDR Bottom Left Solar Tracker Power On off
  digitalWrite(35, HIGH); // LDR Bottom Right Solar Tracker Power On off
  Serial.print(" : Solar Tracker On");
   //delay(100);
void Sensorvalue1()
  int sdata = 0.0;
  value = analogRead(solarvoltage);
  vout = (value * 5.0) / 4096.0;
  vin = vout / (R2/(R1+R2));
  vin = vin - correctionfactor;
if (vin < 0.01) {
  vin = 0.0;
  Serial.print("Solar Voltage= ");
  Serial.println(vin, 2);
  sdata = vin;
  Blynk.virtualWrite(V4, sdata);
  //delay(100);
void Sensorvalue2()
  int sdata = 0.0;
  value = analogRead(batteryvoltage);
  vout = (value * 3.3) / 4096.0;
if (vin < 0.01) {
  vin = 0.0;
  Serial.print("Battery Voltage= ");
  sdata = vin;
  Blynk.virtualWrite(V5, sdata);
  //delay(100);
void Sensorvalue3(){
  for(int i = 0.0; i < 1000; i++);
      voltage = (voltage + (0.0264 * analogRead(35)));
  //delay (100);
  voltage = voltage / 1000;
current = (voltage - 2.5) / 66;
  if (current < 0.01) {
  current = 0.0;
  Serial.print("Solar Current= ");
  Serial.println(current, 2);
  Blynk.virtualWrite(V6, current);
  //delay(100);
void Sensorvalue4(){
      voltage = (voltage + (0.0264 * analogRead(36)));
  //delay (100);
  current = 0.0;
  Serial.print("Battery Current= ");
  Blynk.virtualWrite(V7, current);
  //delay(100);
void Sensorvalue5()
  float t = dht.readTemperature();
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
  Serial.println("Failed to read from DHT sensor!");
  return;
    Blynk.virtualWrite(V8, t);
    Blynk.virtualWrite(V9, h);
    Serial.print("Temperature : ");
    Serial.println(t, 2);
    Serial.print("Humidity : ");
    Serial.println(h, 2);
    //delay(100);
void Sensorvalue7()
int lt = analogRead(ldrlt); // top left
int rt = analogRead(ldrrt); // top right
int ld = analogRead(ldrld); // down left
int rd = analogRead(ldrrd); // down right
int dtime = 10; // dtime=diffirence time,
int tol = 100; // LDR Value tol=toleransi
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
  if (-1*tol > dvert || dvert > tol)
 if (avt > avd)
   servov = ++servov;
 if (servov > servovLimitHigh)
 {servov = servovLimitHigh;}
 else if (avt < avd)
 {servov= --servov;
 if (servov < servovLimitLow)
 { servov = servovLimitLow;}
 vertical.write(servov);
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
 if (avl > avr)
 servoh = --servoh;
 if (servoh < servohLimitLow)
 servoh = servohLimitLow;
 else if (avl < avr)
 servoh = ++servoh;
 if (servoh > servohLimitHigh)
 servoh = servohLimitHigh;
 else if (avl = avr)
 //delay(1000);
 horizontal.write(servoh);
Serial.print("Average Value Top : ");
Serial.println(avt);
Serial.print("Average Value Down : ");
Serial.println(avd);
Serial.print("Average Value Left : ");
Serial.println(avl);
Serial.print("Average Value Right : ");
Serial.println(avr);
//Serial.print("time diffirence ");
//Serial.println(dtime);
Serial.print("Vertical Servo Position : ");
Serial.println(servov);
Serial.print("Horizontal Servo Position : ");
Serial.println(servoh);
//Serial.print("LDR Value tolerans ");
//Serial.println(tol);
//delay(dtime);
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass);
initWiFi();
dht.begin(); // Initialize the DHT sensor
horizontal.attach(18);
horizontal.attach(16);
horizontal.write(90);
vertical.attach(17);
vertical.attach(5);
vertical.write(90);
pinMode(23,OUTPUT); // Solar Power On Off
pinMode(22,OUTPUT); // Battery Charging Power On Off
pinMode(21,OUTPUT); // Cooling Fan for Boost Converter Power On Off
pinMode(36,INPUT); // LDR Top Left Solar Tracker Power On off
pinMode(39,INPUT); // LDR Top Right Solar Tracker Power On off
pinMode(34,INPUT); // LDR Bottom Left Solar Tracker Power On off
pinMode(35,INPUT); // LDR Bottom Right Solar Tracker Power On off
pinMode(35,INPUT); // Solar Current Sensor
pinMode(36,INPUT); // Battery Current Sensor
pinMode(34,INPUT); // Solar Voltage Sensor
pinMode(39,INPUT); // Battery Voltage Sensor
pinMode(4,INPUT); // Temparture and Humididty Sensor of Boost Converter
  timer.setInterval(50L,  Sensorvalue7); // Solar Tracker LDR and Servo
  timer.setInterval(123L,  Sensorvalue1); // Solar VOltage Sensor
  timer.setInterval(143L,  Sensorvalue2); // battery Voltage Sensor
  timer.setInterval(163L,  Sensorvalue3); // Solar Current Sensor
  timer.setInterval(183L,  Sensorvalue4); // Battery Current Sensor
  timer.setInterval(5000L,  Sensorvalue5); // Temprature and Humidity Sensor
  timer.run(),
  Blynk.run();
ok, i will check this
thanks
What's with the crazy double line spacing?
Don't tell me - an AI wrote it, and ran away.
Comments are supposed to clarify - not confuse!
Better still, use names that don't need clarification!
sorry for inconvenience, i am new in this forum and don't know how to post code, but i will improve soon.
AI not Write this code and Run away, nice Joke
those are Shortcut and comments are their full form to identify LDR top left or Right or Bottom Left or Right. it is easy to identify
I checked this project and some other project, but not found anything which explain how to Reposition Servo motor on their original position when require,and again start tracking to sun when require.
Hello ajinkya_udamale
Use a local clock to follow the sun simply.
This suggestion:
Intended this:
to be more like this:
int ldrTopLeft     =36;
int ldrTopRight    =39;
int ldrBottomLeft  =34;
int ldrBottomRight =35;
My tracker is working fine, I only need to On solar tracker when need and when I don't need I will off tracker and servo will come to their original position.
I don't know what code will work for this action
Ok,
Thanks for advice
You should have only one pin attached to horizontal servo (unless you have two trackers)
You should have only one pin attached to vertical servo (unless you have two trackers)
  vertical.attach(5);
These two commands send your servos "home" (original position)
  vertical.write(90);
past threads with east and west LDRs, recognized the last direction a move was made and when both LDRs indicated dark (i.e. sunset), the system moved back to the pre-dawn position
in that position and during the day, the tracker is repositioned when the west facing LDR is more active than the east LDR and the tracker moved until both LDRs were equal
