I've got this old flux i've been using, wonder if anyone can tell me about it.
Little back story: (Skip to the bottom for direct questions)
Quite a few years back I was given about a pound worth of recovered solder.
This was used solder that had been recovered from pcb tear downs, etc.
Being the type of person who does not like to waste things I started using it for projects.
Seeing as it was just clumps and chips of solder I often would use separate flux.
I'd used the liquid flux in the past and it worked but I ran out during a project.
I went looking in the garage and found a tin of "soldering paste" (no idea where it came from) so im thinking this must be flux.
but it's not liquid it's a thick gel like form, the tin looked very old (no upc) the inside "paste" looked quite old as well but it was still very moist and look like it had never been used, so I said what the heck let's try it.
It worked, I dunno how old the stuff is but it worked a treat, I like it much better then the liquid flux.
just a tiny dab will do the trick and this stuff stays where you put it.
I've been using it for the last few years and i've barely made a dent in the 2oz tin.
recently I was looking at soldering supplies and I thought, ya know I wonder if I can find a "new" source for this stuff, I came up absolutely empty on google, the closest I found was a few listings on ebay for "vintage" flux.
on the back it says it contains "zinc chloride", so im thinking.. maybe I can just find flux paste that has that in it..
Im fairly ignorant with flux, up till that bag of recovered solder I didn't even have a use for flux, the rosin core 40/60 usually did the trick.
So after a little searching it seems like there is a wide world of flux out there (again I plead ignorance)
and that Zinc chloride is considered a corrosive, because it's usually obtained with hydrochloric acid.
So flux with zinc chloride is usually seen in automotive body work, etc, not electronics.
but then I read on a few more sources that say some of the "mildly active" (common) electronic flux also contain small amounts of zinc chloride.
So there seems to be some overlap here, im unsure of the zinc chloride content in this flux, it could be mild or it could be large, I've no way to know since I can't find any info on this product.
The little guy on the tin I thought was working on electronics, but now im wondering if he's not actually soldering stain glass or plumbing or something.. or maybe the little guy on the front is a lie altogether lol.
I've been using it for the last couple years and thinking back I don't recall having any problems with things i've used it on, but most of them was hacked cables, wire, and terminals, not much PCB work.
Who knows how fast "corrosion" might take, it's hard to check prior work because most of it is under shrink tubing.
So my questions are:
- What can you tell me about this particular "paste"? Estimated age?, was it ever suitable for electronics
- Should I be worried about prior projects that I used this with?, and if so can anything be done now?
- Can you recommend a GOOD non corrosive (no clean up) "gel" type flux?
Since I think this product predates barcodes (omgz) Im hoping someone here might know what this is about.
