Dear Sirs,
I have started a thread in Project Guidance section ([SOLVED] Arduino as PS/2 keyboard - issue (5-10% of commands are dropped) - Project Guidance - Arduino Forum), some time ago. May I try this question here?
I’ll try to be brief. I am trying to consolize an MS-DOS laptop by emulating PS/2 keyboard, i.e I'm trying to make this a thing:
To achieve it I’ve soldered this thing (based on Pro Micro, Atmega32u4) to act as a PS/2 keyboard:
I’ve made a code based on ps2dev library from here https://github.com/Harvie/ps2dev:
#include <Keyboard.h> // Emulate USB keyboard
#include <ps2dev.h> // Emulate a PS/2 device
PS2dev keyboard(A3, A2); // Clock, Data
// Define SEGA gamepad pins
#define UP_OR_Z 9
#define DOWN_OR_Y 7
#define LEFT_OR_X 5
#define RIGHT_OR_MODE 4
#define B_OR_A 8
#define SEL 6
#define C_OR_START 3
// Buttons database follows:
byte PS2_key_code[102][2][3] = { // Array [Button No.][MAKE or BREAK][byte No.]
{{0x14}, {0xF0, 0x14}}, // 0 - L CTRL
{{0x12}, {0xF0, 0x12}}, // 1 - L SHFT
// ...other 98 keys are omitted due to 9000 characters forum limitation...
{{0xE0, 0x2F}, {0xE0, 0xF0, 0x2F}}, // 101 - APPS
byte USB_key_code[102] = { // Array [Button No.]
0x80, // 0 - L CTRL
0x81, // 1 - L SHFT
0xED, // 101 - APPS
unsigned long sega_timer = 0; // Needed to track delay after SEGA checked its buttons
byte sega_pin[] = {UP_OR_Z, DOWN_OR_Y, LEFT_OR_X, RIGHT_OR_MODE, B_OR_A, C_OR_START};
// Buttons UP, DOWN, LEFT, RIGHT, B, C, A, START, Z, Y, X, MODE
boolean button_matrix[12]; // Array shows which buttons are pressed
boolean prev_button_matrix[12]; // Cache Array to pick up updates
byte key_press[] = {83, 82, 81, 80, 2, 0, 48, 45, 31, 32, 33, 44}; // List buttons to press
void segaRead() {
digitalWrite(SEL, LOW); // Set SEL to LOW to read additional buttons
delayMicroseconds(20);
digitalWrite(SEL, HIGH);
// Read START and A
for (byte i = 0; i < 2; i++) {
button_matrix[i + 6] = !digitalRead(sega_pin[i + 4]);
digitalWrite(SEL, HIGH); // Set SEL to HIGH to read primary buttons
// Read UP, DOWN, LEFT, RIGHT, B, C
for (byte i = 0; i < 6; i++) {
button_matrix[i] = !digitalRead(sega_pin[i]);
digitalWrite(SEL, HIGH); // Set SEL to LOW to read additional buttons
// Read Z, Y, X, MODE
for (byte i = 0; i < 4; i++) {
button_matrix[i + 8] = !digitalRead(sega_pin[i]);
// delayMicroseconds(20);
void PS2_press_key(byte key_number) {
for (byte i = 0; i < 3; i++) {
if (PS2_key_code[key_number][0][i] != 0x00) { // If keycode is not BLANK - Send key byte
keyboard.write(PS2_key_code[key_number][0][i]); // send byte though ps2dev library
void PS2_release_key(byte key_number) {
for (byte i = 0; i < 3 ; i++) {
if (PS2_key_code[key_number][1][i] != 0x00) { // If keycode is not BLANK - Send key byte
keyboard.write(PS2_key_code[key_number][1][i]); // send byte though ps2dev library
// Serial.begin(19200); // ps2dev SPAMs debugging data though here. Very annying! Makes controller lag
Keyboard.begin(); // starts 32u4 USB keyboard service
USBCON |= (1 << OTGPADE); //enables VBUS pad to check if USB is connected
//Prepare SEGA SEL pin
pinMode(SEL, OUTPUT);
// Set all SEGA pins to INPUT
pinMode(sega_pin[i], INPUT_PULLUP);
unsigned char leds; // next lines need it dunno why
keyboard.keyboard_handle(&leds); // ps2dev command. Allows to read HOST inputs and answer those
if (millis() >= sega_timer) {
sega_timer = millis() + 8;
segaRead(); // read buttonpresses
for (byte i = 0; i < 12; i++) {
if (button_matrix[i] == 1 && prev_button_matrix[i] == 0) { // Gamepad button pressed
if (USBSTA & (1 << VBUS)) Keyboard.press(USB_key_code[key_press[i]]);
else PS2_press_key(key_press[i]);
if (button_matrix[i] == 0 && prev_button_matrix[i] == 1) { // Gamepad button relesed
if (USBSTA & (1 << VBUS))Keyboard.release(USB_key_code[key_press[i]]);
else PS2_release_key(key_press[i]);
memcpy(prev_button_matrix, button_matrix, sizeof button_matrix); // Buffer the state of SEGA butons for further comparison (i.e. check if changed)
The problem is that the resulting device just not reliable! Most of my PCs fail to accept 100% of keyboard bytes (either key-PRESS or RELEASE). I don’t know why:
• 2 inbred Compaq LTE 5000 laptops (like the one in the photo): sometimes commands (especially longer, 2-3 byte long ones) are not transferred successfully. I can’t complete a single 30-second racing lap without steering getting stuck.
• 2 identical IBM Thinkpads 560. Thing fails to initialize during bootup. The quirk of those laptops is that they are trying to initialize PS/2 devices by constantly spamming 0xF2 requests. After about average 2 minutes since booting – Arduino-as-PS/2-keyboard initializes and works as bad as with those Compaq LTE 5000 laptops above.
• 2 Desktop computers: one hot late-90s PC (Win 98, Pentium 800, VIA Apollo Pro 133 Chipset, Voodoo3 video) and 2011-2012 Win10 piece of crap. Keyboard initializes and works flawlessly 100% on both desktops. Though kinda pointless as these two PCs have USB ports.
Can you advice why is that?
Please advise why PS/2 commands most of the times succeed to be accepted but sometimes not?
What may be the reason of such non-100% reliability? Power? Static? My lame programming?
Feel free to glance at my original message of earlier iteration of the project here.
Please spare an advice, if you have any.
UPD. Fixed a small logical bug in the code above. Does not make it better with the old laptops. ![]()
