[solved] arduino.local is not accessible, but the all wifi activities are ok
Hello Forum,
Maybe it is not directly a YUN problem, but I want to share as I am looking for a solution.
Going directly to the point, I have 2 YUN boards connected to the same wireless network, running 2 different sketches, and both of them quite close to the router.
They have been both working rock solid fore some days, but since yesterday their .local page is not any more accessible, while before yesterday they have always been accessible.
I have tried to both power off and wifi reset several times, but the behaviour keeps the same. The strange thing is that the http get request (client.get) are normally executed, meaning to me that the yun boards are perfectly connecting to the local wireless network and connecting to the internet.
On one of them I have executed a factory reset and at least the http://arduino.local/cgi-bin/luci/webpanel/homepage is accessible now, but I still have to try to reconnect it to the wireless network. I want to upgrade to the latest firmware first.
Do you happen to have any quick tip about this problem?
Thank you for reading,
L
Just to update you, after reset to factory settings I could access to the arcuino access point and once logged in I got a message notify there where problem connecting last time with following details.
Does this says anything to you?
Thanks for your support!
Leone
Untitled.rtf (13.1 KB)
Ok, again, to update you, I think I found the problem/solution.
No problems on the 2 YUN, and neither the Wifi router. It was quite silly but I'm sharing what happened anyway.
The problem probably was that I didn't realize that one YUN (which I changed the name) disconnected from the wifi e restarted as Access point. Later on when I was trying to connect a the second Arduino YUN, (still left with the factory name), but I was messing up between SSID names and .local name of the page.
I purchased 3 Arduino Yun's at once, so their factory SSDID are quite similar... and I got confused !!
power of newbbies 8)
Glad you solved :slight_smile: Can you change the topic title to "[solved]" ?
For future reference, if you get lost in understanding which yun is which, try plugging each of them to your pc via USB and use WiFiStatus example: it prints current SSID
Thank you Federico.
