Hello, i am a college student currently working for a project but got some problem and wanted to ask. So my intended project goes like this,
the ESP32CAM does a face recognition, and then if the face is recognized by enrolling a face, the ESP32CAM then makes a variable like matchFace=true, and then sends that variable into the arduino uno, then the arduino uno processes the variable with a scanned RFID tag by using if-else. Also assuming that i need to stay to look at the ESP32-CAM so the variable stays true, then i scan the RFID tag to open the door lock, by moving a servo.
Here is my wiring diagram i use (not updated picture):
from that diagram, i added a wire from 4 5 in arduino to 12 13 in esp32cam (for serial),
and added a wire from RESET pin to GND in the arduino uno (to make the esp32cam works/running)
iam currently still using my laptop to power the arduino uno
Here is a code i uploaded to the ESP32CAM (used the camera web server sketch)
#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! Make sure that you have either selected ESP32 Wrover Module,
// or another board which has PSRAM enabled
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT
//#define CAMERA_MODEL_ESP_EYE
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE
#define CAMERA_MODEL_AI_THINKER
#define RXD1 12
#define TXD1 13
#include "camera_pins.h"
const char* ssid = "ARJUNA 30";
const char* password = "wistichagroupA30";
void startCameraServer();
bool matchFace = false;
Serial1.begin(115200, SERIAL_8N1, RXD1, TXD1);
Serial.setDebugOutput(true);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
//initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1);//flip it back
s->set_brightness(s, 1);//up the blightness just a bit
s->set_saturation(s, -2);//lower the saturation
//drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
Serial1.print(matchFace);
here is also a line i edited from the app_httpd.cpp from the sketch
static int run_face_recognition(dl_matrix3du_t *image_matrix, box_array_t *net_boxes){
dl_matrix3du_t *aligned_face = NULL;
int matched_id = 0;
aligned_face = dl_matrix3du_alloc(1, FACE_WIDTH, FACE_HEIGHT, 3);
if(!aligned_face){
Serial.println("Could not allocate face recognition buffer");
return matched_id;
if (align_face(net_boxes, image_matrix, aligned_face) == ESP_OK){
if (is_enrolling == 1){
int8_t left_sample_face = enroll_face(&id_list, aligned_face);
if(left_sample_face == (ENROLL_CONFIRM_TIMES - 1)){
Serial.printf("Enrolling Face ID: %d\n", id_list.tail);
Serial.printf("Enrolling Face ID: %d sample %d\n", id_list.tail, ENROLL_CONFIRM_TIMES - left_sample_face);
rgb_printf(image_matrix, FACE_COLOR_CYAN, "ID[%u] Sample[%u]", id_list.tail, ENROLL_CONFIRM_TIMES - left_sample_face);
if (left_sample_face == 0){
is_enrolling = 0;
Serial.printf("Enrolled Face ID: %d\n", id_list.tail);
matched_id = recognize_face(&id_list, aligned_face);
if (matched_id >= 0) {
Serial.printf("Match Face ID: %u\n", matched_id);
rgb_printf(image_matrix, FACE_COLOR_GREEN, "Hello Subject %u", matched_id);
matchFace = true; // i added this line
Serial.println("No Match Found");
rgb_print(image_matrix, FACE_COLOR_RED, "Intruder Alert!");
matched_id = -1;
Serial.println("Face Not Aligned");
//rgb_print(image_matrix, FACE_COLOR_YELLOW, "Human Detected");
dl_matrix3du_free(aligned_face);
return matched_id;
here is a code i uploaded to my arduino uno
/*Door lock system code
* https://srituhobby.com
#include <Servo.h>
#include <SPI.h>
#include <MFRC522.h>
#include <SoftwareSerial.h>
#define SS_PIN 10
#define RST_PIN 9
String UID = "B3 44 9F A5";
byte lock = 0;
Servo servo;
LiquidCrystal_I2C lcd(0x27, 16, 2);
MFRC522 rfid(SS_PIN, RST_PIN);
SoftwareSerial Serial1(4, 5);
Serial1.begin(115200);
servo.write(70);
lcd.init();
lcd.backlight();
servo.attach(3);
SPI.begin();
rfid.PCD_Init();
lcd.setCursor(4, 0);
lcd.print("Welcome!");
lcd.setCursor(1, 1);
lcd.print("Put your card");
if (Serial1.available() > 0){
bool match = Serial1.read();
if ( ! rfid.PICC_IsNewCardPresent())
return;
if ( ! rfid.PICC_ReadCardSerial())
return;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Scanning");
Serial.print("NUID tag is :");
String ID = "";
for (byte i = 0; i < rfid.uid.size; i++) {
lcd.print(".");
ID.concat(String(rfid.uid.uidByte[i] < 0x10 ? " 0" : " "));
ID.concat(String(rfid.uid.uidByte[i], HEX));
delay(300);
ID.toUpperCase();
if (ID.substring(1) == UID && match == true ) {
servo.write(160);
lcd.clear();
lcd.print("Door is open");
delay(1500);
lcd.clear();
delay(5000);
servo.write(70);
lock = 0;
lcd.clear();
lcd.print("Wrong card!");
delay(1500);
lcd.clear();
Before i asked my main problem, how do you think my project will do? is it gonna be possible? please let me know what you think about my project.
So, my main problem is, i connected the reset pin in arduino uno to the gnd pin in the arduino uno, when i already uploaded each sketch to the uno and esp32cam, the esp32cam is running (the serial monitor is showing the address to the camera site etc.), but the RFID/LCD is not scanning (i deleted the serial available line from the arduino uno code to check this).
Then, if i disconnect the reset and ground pins, the RFID scans the tag (also by deleting the serial available line to check), but the esp32cam is not working (the serial monitor is not showing anything)
Is there a solution to this problem? please let me know what you think.
Also here is a youtube video reference i use
arduino uno rfid door lock:
esp32cam face recognition door lock:
Arduino ide version 1.8.19
eso32 board version 1.0.4
