tabb
March 19, 2020, 2:33pm
1
I have been struggling with an issue for a while:
I want to display time on an LCD screen. The variable VData.MNTime is a time in seconds. This could be few seconds or thousands.
I calculate how much hours, minutes and seconds this makes and I display the variables on the LCD screen.
The result is that seconds and minutes are working fine. But hours won't appear at all :
This exemple should indicates: Tn: 2: 7: 5
This one should indicates Tn: 2:29:43
Here is my code for calculation and display:
int ss;
int mm;
int hh;
int tt = VData.MNTime;
ss = tt % 60;
tt = (tt - ss)/60;
mm = tt % 60;
tt = (tt - mm)/60;
hh = tt;
char h[2];
dtostrf(hh, 2, 0, h);
char m[2];
dtostrf(mm, 2, 0, m);
char s[2];
dtostrf(ss, 2, 0, s);
writeLCD("Tn: ");
writeLCD(h);
writeLCD(":");
writeLCD(m);
writeLCD(":");
writeLCD(s);
Thank you for your help.
Post a complete program that compiles so we can test it.
Why do you need to convert the values to strings ?
Your character buffers used in dtostrf() look one character shorter than needed to allow for the terminating 0 of the string
tabb
March 19, 2020, 2:43pm
4
Thank you for your quick answer.
gfvalvo:
Here here my folder.
UKHeliBob:
It is some exemple code working to display a single variable so I kept the same logic.
But any other working way is fine to me.
HandShake.ino (211 Bytes)
Input.ino (963 Bytes)
LCD.ino (534 Bytes)
output.ino (8.22 KB)
SerialCOMS.ino (1.97 KB)
TabbKSP-6.ino (7.9 KB)
utilities.ino (14.1 KB)
tabb:
Very few people want to wade through a bunch of irrelevant code. Best to make an MRE .
tabb
March 19, 2020, 3:09pm
6
UKHeliBob:
I fixed this thanks to you with these changes :
char h[3];
char m[3];
char s[3];
Thanks a lot !
Is everything displaying OK now ?
tabb
March 19, 2020, 3:32pm
8
Yes, perfectly.
Just to polish it, is there a way to add "0" so that values inferior to 10 are displayed like that "04" instead of " 4" ?
if (val < 10) {
device.print('0');
device.print (val);
Of course. You could use the sprintf() function to build the char array
You did not answer my question as to why you are converting the ints to chars. Incidentally, why are they ints not bytes in the first place ?
tabb
March 19, 2020, 4:18pm
11
UKHeliBob:
I just had a look at this function, but I don't get how it work.
Do you have a simple example to help me understand ?
UKHeliBob:
I assumed I needed to do this to be able to display them on the LCD.
char buffer[3];
while (!Serial);
for (byte hour = 0; hour < 20; hour++)
sprintf(buffer, "%02d", hour);
Serial.println(buffer);
As suggested by AWOL it is easier to understand if you simply test the value of the variable and print a zero if necessary
You don't
