I am trying to finish a project that requires a lead screw to have a home position and a limit switch.
BHL64 was a great help in getting me sorted. I have now got all functions sorted, except the final bit of positioning.
My requirement is that once the leadscrew is positioned, I can press the 'set button' and the leadscrew will back off by a preset amount.
I have the values required outputted to the serial monitor, and the value 'pulseCount' is correct.
pulseCount is a value that takes into account the microstep setting, the leadscrew pitch and allows the user to enter the gap value in mm.
So, in the code section 'void setSet()', I have used the pulseCount value in a FOR loop. but the leadscrew just runs in reverse constantly until the carriage hits the home switch.
Could anyone help please?
[code]
// setup libraries
#include <Wire.h>
#include <Keypad.h>
// Initialise LCD
LiquidCrystal_I2C lcd (0x27, 20, 4);
int lcdPowerPin = 13;
byte newChar[8] = {
B01001,
B01001,
B01001,
B01001,
B01110,
B01000,
B01000,
B10000
// setup Keypad
const byte numRows = 5; //number of rows on the keypad
const byte numCols = 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols] =
{'A', 'B', '#', '*'},
{'1', '2', '3', 'U'},
{'4', '5', '6', 'D'},
{'7', '8', '9', 'C'},
{'L', '0', 'R', 'E'}
int csr = 0;
byte rowPins[numRows] = {26, 28, 30, 32, 34};
byte colPins[numCols] = {42, 40, 38, 36};
//initializes an instance of the Keypad class
Keypad keypad = Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
// setup Motor control parameters
String gap = "";
int gapNum = 0;
int gapFlag = 0;
int mm = 0;
int gapSteps = 0;
String steps = "";
int stepNum = 0;
int stepFlag = 0;
int pos = 0;
int posMax = 0;
int pulseCount;
// Set up Stepper Control Pins
const int enablePin = 10;
const int dirPin = 11;
const int pulsePin = 12;
#define CLOCKWISE LOW
#define COUNTERCLOCKWISE HIGH
// setup switches
const int homeButtonPin = 52;
const int fwdButtonPin = 50;
const int revButtonPin = 48;
const int setButtonPin = 46;
const int clearButtonPin = 44;
const int homeSwitchPin = 33;
const int homeSwitchNegPin = 31;
const int limitSwitchPin = 29;
const int limitSwitchNegPin = 27;
// setup LEDs
const int homeLed = 53;
const int homeLedGnd = 51;
const int forwardLed = 49;
const int forwardLedGnd = 47;
const int reverseLed = 41;
const int reverseLedGnd = 45;
const int setLed = 37;
const int setLedGnd = 43;
const int clearLed = 39;
const int clearLedGnd = 35;
// Set up Switch Registry
int homeButtonState;
int fwdButtonState;
int revButtonState;
int setButtonState;
int clearButtonState;
int homeSwitchState;
int limitSwitchState;
int homeFlag = 0;
int dly = 0;
int flagTotal = 0;
int leadScrewConstant = 50;
int dely;
// setup pin functions
pinMode (lcdPowerPin, OUTPUT);
pinMode (enablePin, OUTPUT);
pinMode (dirPin, OUTPUT);
pinMode (pulsePin, OUTPUT);
pinMode (homeButtonPin, INPUT_PULLUP);
pinMode (fwdButtonPin, INPUT_PULLUP);
pinMode (revButtonPin, INPUT_PULLUP);
pinMode (setButtonPin, INPUT_PULLUP);
pinMode (clearButtonPin, INPUT_PULLUP);
pinMode (homeSwitchPin, INPUT_PULLUP);
pinMode (homeSwitchNegPin, OUTPUT);
pinMode (limitSwitchPin, INPUT_PULLUP);
pinMode (limitSwitchNegPin, OUTPUT);
pinMode (homeLed, OUTPUT);
pinMode (homeLedGnd, OUTPUT);
pinMode (forwardLed, OUTPUT);
pinMode (forwardLedGnd, OUTPUT);
pinMode (reverseLed, OUTPUT);
pinMode (reverseLedGnd, OUTPUT);
pinMode (setLed, OUTPUT);
pinMode (setLedGnd, OUTPUT);
pinMode (clearLed, OUTPUT);
pinMode (clearLedGnd, OUTPUT);
// setup common grounds
digitalWrite (dirPin, LOW);
digitalWrite (pulsePin, LOW);
digitalWrite (homeSwitchNegPin, LOW);
digitalWrite (limitSwitchNegPin, LOW);
// setup stepper initial conditions
digitalWrite (enablePin, HIGH);
// setup Serial Monitor
Serial.begin (115200);
//setup LCD Display
digitalWrite (lcdPowerPin, HIGH);
lcd.init();
lcd.backlight();
lcd.createChar(0, newChar);
gapFlag = 0;
stepFlag = 0;
lcd.setCursor (4, 0);
lcd.print ("Project Adept");
lcd.setCursor (0, 1);
lcd.print ("Gap= ");
lcd.setCursor (9, 1);
lcd.write (0);
lcd.print ("Steps=");
lcd.setCursor (0, 2);
lcd.print ("State = ");
lcd.setCursor (0, 3);
lcd.print ("Pos = ");
lcd.print (pos);
lcd.print (" / ");
lcd.print (posMax);
flagTotal = gapFlag + stepFlag + homeFlag;
Serial.print ("Home Button = ");
Serial.print (homeButtonState);
Serial.print (" Forward Button = ");
Serial.print (fwdButtonState);
Serial.print (" Gap (mm) = ");
Serial.print (gapNum);
Serial.print (" Step Delay = ");
Serial.print (dely);
Serial.print (" Microsteps = ");
Serial.print (stepNum);
Serial.print (" mm = ");
Serial.print (mm);
Serial.print (" Set Pulse Count = ");
Serial.print (pulseCount);
Serial.print (" Flag Total = ");
Serial.println (flagTotal);
//Sets the number of pulses to reverse when set button pressed
mm = leadScrewConstant * stepNum;;
pulseCount = (gapNum * mm);
homeButtonState = digitalRead(homeButtonPin);
fwdButtonState = digitalRead(fwdButtonPin);
//display values
if (gapFlag == 0) {
lcd.setCursor (5, 1);
lcd.print ("F1 ");
if (gapFlag == 1) {
lcd.print (gapNum);
if (stepFlag == 0) {
lcd.setCursor (17, 1);
lcd.print ("F2 ");
if (stepFlag == 1) {
lcd.print (stepNum);
if (homeFlag != 1) {
lcd.setCursor (8, 2);
lcd.print ("Set Home ");
if (homeFlag == 1) {
lcd.print ("Ready ");
if ((homeButtonState == LOW) && (homeFlag == 0)) {
digitalWrite (homeLed, HIGH);
Home();
digitalWrite (homeLed, LOW);
if ((homeButtonState == LOW) && (homeFlag == 1)) {
lcd.print("Home Set ");
delay (1500);
if (stepNum == 1) {
dely = 475;
if (stepNum == 2) {
dely = 300;
if (stepNum == 4) {
dely = 100;
if (stepNum == 8) {
dely = 50;
if (stepNum == 16) {
dely = 25;
if (stepNum == 32) {
dely = 7.5;
// Set Forward Motion
fwdButtonState = digitalRead (fwdButtonPin);
if ((fwdButtonState == LOW) && (flagTotal != 3)) {
lcd.print ("Set Values ");
delay (1500);
if ((fwdButtonState == LOW) && (flagTotal == 3)) {
digitalWrite (forwardLed, HIGH);
forward();
digitalWrite (forwardLed, LOW);
if ((fwdButtonState == LOW) && (limitSwitchState == HIGH)) {
lcd.print ("FWD LIMIT ");
//Set Reverse Motion
revButtonState = digitalRead (revButtonPin);
if ((revButtonState == LOW) && (flagTotal != 3)) {
delay (1500);
if ((revButtonState == LOW) && (flagTotal == 3)) {
digitalWrite (reverseLed, HIGH);
reverse();
digitalWrite (reverseLed, LOW);
if ((revButtonState == LOW) && (homeSwitchState == HIGH)) {
lcd.print ("REV LIMIT ");
clearButtonState = digitalRead (clearButtonPin);
if (clearButtonState == LOW) {
digitalWrite (clearLed, HIGH);
gap = "";
gapNum = 0;
gapFlag = 0;
steps = "";
stepNum = 0;
stepFlag = 0;
homeFlag = 0;
delay (1500);
digitalWrite (clearLed, LOW);
//Set Clearance
setButtonState = digitalRead (setButtonPin);
if ((setButtonState == LOW) && (flagTotal == 3)) {
digitalWrite (setLed, HIGH);
setSet();
delay (500);
digitalWrite (setLed, LOW);
//read keypad
char keypressed = keypad.getKey();
if (keypressed != NO_KEY) { //curly bracket 1
if ((keypressed != 'A') && (keypressed != 'B')) {
lcd.clear();
lcd.setCursor (3, 1);
lcd.print ("Invalid Input");
delay (2000);
lcd.clear();
loop();
switch (keypressed) {
case 'A': //When pressing F1
gapSet();
case 'B': //when pressing F2
stepSet();
[/code]
void forward() {
digitalWrite (enablePin, LOW);
digitalWrite (dirPin, COUNTERCLOCKWISE);
limitSwitchState = digitalRead (limitSwitchPin);
while (( limitSwitchState == LOW) && (fwdButtonState == LOW)) {
delayMicroseconds (dely);
digitalWrite (pulsePin, HIGH);
pos ++;
lcd.print (" ");
[code]
void gapSet() {
gapFlag = 0;
gapNum = 0;
gap = "";
csr = 0;
lcd.clear();
lcd.setCursor (1, 0);
lcd.print ("Set Gap Distance");
lcd.setCursor (1, 1);
lcd.print ("mm");
lcd.print ("(100mm Max)");
do {
char gapKey = keypad.getKey();
if (gapKey) {
lcd.setCursor ((csr) + 1, 3); //move cursor on LCD
lcd.print (gapKey); //display character pressed on keypad
if (gapKey >= '0' && gapKey <= '9') { // only act on numeric keys
gap += gapKey; // append new character to input string
csr++; //increase cursor count to move on lcd
} else if (gapKey == 'E') {
if ((gap.length() > 0) && (gap.length() <= 3)) {
gapNum = gap.toInt(); // YOU GOT AN INTEGER NUMBER
if (gapNum < 1) {
lcd.clear();
delay (2000);
lcd.clear();
gap = "";
gapNum = 0;
gapFlag = 0;
if (gapNum > 100) {
lcd.clear();
delay (2000);
lcd.clear();
gap = "";
gapNum = 0;
gapFlag = 0;
gapFlag = 1; // DO YOUR WORK HERE
gap = ""; // clear input
} else if (gapKey == 'C') {
gapFlag = 0;
gapNum = 0;
lcd.clear();
} while (gapFlag != 1);
lcd.clear();
[/code]
void Home() {
lcd.print ("Homing ");
// Drive the motor CLOCKWISE until home switch is detected
digitalWrite (dirPin, CLOCKWISE);
while (digitalRead (homeSwitchPin) == LOW) {
// at HOME position so call this zero
pos = 0;
// drive the motor in reverse until limit switch is detected
while (digitalRead (limitSwitchPin) == LOW) {
pos ++;
// at LIMIT postiion
posMax = (pos);
// Drive the motor back home
while (pos > 0) {
pos --;
lcd.setCursor (6, 3);
lcd.print (pos);
lcd.print (" "); // need to blank out last postion when transitioning from 10000 to 9999, 1000 to 999, etc.
// all done
homeFlag = 1;
[code]
void reverse() {
homeSwitchState = digitalRead (homeSwitchPin);
while (( homeSwitchState == LOW) && (revButtonState == LOW)) {
pos --;
lcd.print (" ");
[/code]
void setSet() {
// causes the lead screw to retract a preset number of pulses
for (int i = 0; i < pulseCount; i++) { // uses for loop to create a set number of pulses
while (homeSwitchState == LOW) {
homeSwitchState = digitalRead (homeSwitchPin); //prevents running into end stock
pos = pos - 1;
void stepSet() {
stepFlag = 0;
stepNum = 0;
steps = "";
csr = 0;
lcd.clear();
lcd.print ("MicroSteps");
lcd.print ("");
lcd.print ("(32 Max)");
do {
char stepKey = keypad.getKey();
if (stepKey) {
lcd.print (stepKey); //display character pressed on keypad
if (stepKey >= '0' && stepKey <= '9') { // only act on numeric keys
steps += stepKey; // append new character to input string
} else if (stepKey == 'E') {
if ((steps.length() > 0) && (steps.length() <= 2)) {
stepNum = steps.toInt(); // YOU GOT AN INTEGER NUMBER
if (stepNum < 1) {
lcd.clear();
delay (2000);
lcd.clear();
steps = "";
stepNum = 0;
stepFlag = 0;
if ((stepNum != 1) && (stepNum != 2) && (stepNum != 4) && (stepNum != 8) && (stepNum != 16) && (stepNum != 32)) {
lcd.clear();
delay (2000);
lcd.clear();
steps = "";
stepNum = 0;
stepFlag = 0;
stepFlag = 1; // DO YOUR WORK HERE
steps = ""; // clear input
} else if (stepKey == 'C') {
stepFlag = 0;
stepNum = 0;
lcd.clear();
} while (stepFlag != 1);
lcd.clear();
